Bt vision box
Since bt vision upgrade 3 weeks ago my signal qualityhas gone from e g bbc 1 75 to55 dbuv can u help//
    Top Expert:
  • 12,223 Answers
You must call to the company supplier for to see if there are a problem with the upgrade, in the signal or model, and adjust.
If the problem is o.k so can reset the r.control in menu to factory default. Otherwise you must the TV with some repair shop TV for fix it. However you must setup in the MENU to go factory default. Retest any cable dirty or corrosion, clean it with solvent cleaner contacts, buy it from any stores from supplier electronic devices, like computer, etc
God bless you
Posted on Jul 12, 2013
4 Suggested Answers
SOURCE: I have a Bush 2878 TV and have just got BT vision
Thank you for the follow up. I have solved the problem by working my way through 4 figure numbers starting at 0001 and in fact the solution was 0009 - which was not a number that bt vision had suggested.
Nicky Spink
Posted on Oct 28, 2009
SOURCE: where do you get a replacement remote for a bt vision box
I called Tech help and they have placed an order for a replacement remote free of charge. 3-5 days and I'll get a Black remote (they are out of the silver).
this is what I did....
*Called 08001114567, option 1, option 1, option 1
Posted on Jan 03, 2012
ercupa190
  • 12223 Answers
SOURCE: I have a john Lewis remote that won't work my Bt vision box, despite the codes which I have entered from the instruction manual
I recommend that your contact the company cables, and consult if the john lewis control is compatible witht Bt box.
They will instruct if this will be work. Otherwise you must replace by other remote such as R.Schack that work very well.
sincerely. God bless you
Posted on May 07, 2012
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
Can I have a you view box free
Hi
I got my YouView box free when I signed up for BT Infinity (upgraded from standard broadband), and TV Essentials (replacing my BT Vision which had ceased). The link below will take you to a BT page which may help you,
TV Packages And Deals Online BT
although I found it difficult to sort out what I would get on line and in the end rang them
Cheers
Nov 13, 2014 | Computers & Internet
Why do's my bt vision box keeps rebooting its self
It sounds like it has a fault. Contact BT for a replacement.
It might be worth trying the following first: Restarting the BT Vision box Help BT com Help
Mar 03, 2014 | Apple Find My iPhone
BT Vision box re-booting
It sounds that the upgrade was not success. Contact any service technician. google.com/+GopakumarGopalan
Nov 25, 2013 | Toshiba 32AV500U 32 in. LCD HDTV
Where do you get a replacement remote for a bt vision box
Jan 03, 2012 | Televison & Video
Set top box reset has lost input signal
Do other inputs work like DVD player and so on? If so contact your service provider.
May 01, 2017 | Televison & Video
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Electro Med Services...
