Question about Cell Phones
Imei corrupted in lg c2500
Phone remaining in searching mode after showing sim card registration failed , suggest solution Model LG C 2500
Raysagem
  • 1017 Answers
SOURCE: SIM card registration failed
You might have filled up the memory to the brim and the phone doesn't have enough to switch on.
Try reformat to original settings. anything you stored on the phone will be lost.
How to reformat your phone, first turn it OFF. Press * 3 send at the same time and keep them pressed while you turn the phone on.
Give it time to work.
Remember, do not let go the 3 keys until you see the formatting screen.
After a few minutes when the process is over, your Nokia N70 will be back to the original delivered system.
Posted on Jan 03, 2008
i have the sme problem
Posted on Oct 06, 2008
  • 7 Answers
SOURCE: the phone keeps displaying sim card registration failed on phone
The sim card holder is too loose on a lot of new Nokia phones. Place some folded paper (3,4,5,6 times) between the sim card and the sim card holder. It should fix it. I have an E65 and had this problems for two days after buying it. Since I fixed it 3 months ago, never had this problem again. Hope it works for you too.
Posted on Mar 17, 2009
  • 7 Answers
SOURCE: my phone 5310 xpress music
  • 83 Answers
SOURCE: SIM card registration failed, whats wrong?
The first thing to try is put the SIM into another handset - if you get the same error message on that, the SIM is blocked. If it works in another phone, the most likely explanation is that the IMEI of your phone has been blocked by the network.
Posted on Jun 10, 2009
Sim card registration failure
Please Unlock My LG KG 110 Mobile. Service Provider Airtel & IMEI : 35470101612152200
Jul 23, 2013 | LG KG110 Cellular Phone
Tip
LG mobiles Test Menu, secret codes and tricks
Here are some common codes for LG cellular phones and there use. Use these codes at your own risk and note that these codes may or may not work depending on your phone model.
Following are the codes:
LG all models test mode: Type 2945#*# on the main screen.
2945*#01*# Secret menu for LG
IMEI (ALL): *#06#
IMEI and SW (LG 510): *#07#
Software version (LG B1200): *8375#
Recount cheksum (LG B1200): *6861#
Factory test (B1200): #PWR 668
Sim lock menu (LG B1200): 1945#*5101#
Sim lock menu (LG 510W, 5200): 2945#*5101#
Sim lock menu (LG 7020, 7010): 2945#*70001#
Sim lock menu (LG 500, 600): 2947#*
LG-U81XX SPECIAL CODES
Code to read phone version :
- Phone without SIM
- Enter 277634#*# or 47328545454#
- Select ‘SW Ver.info’
Code to reset phone :
- Phone without SIM
- Select ‘Factory Reset’
Code to enter UNLOCK MENU :
- Phone wit SIM inside
- Enter 2945#*88110#
Test Menu 8330 : 637664#*#
Test Menu 8180 V10a: 49857465454#
Test Menu 8180 V11a: 492662464663#
Test Menu 8130-8138: 47328545454#
Test Menu 8110-8120: 277634#*#
on Aug 05, 2010 | Cell Phones
My lg kp 220 shows sim card registration faild and then show invalid sim please give me the network unlocking code
You need to talk to your service provider. Your SIM card registration failed because it's not valid.
Nov 17, 2011 | Cell Phones
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
Jun 03, 2011 | LG Cell Phones
Id like to unlock my lgks360 for free but im finding it hard. could you give me a code to do this please?
Only trust best unlocking specialist for unlocking your mobile , it will be the best & safest way for unlocking . In order to unlock your Lg KS360 MOBILE make use of this site wickedunlock ,select the network you need , then get the unlock code here , using unlock code specified in it proceed unlocking your mobile & gain solution .
May 28, 2011 | LG Cell Phones
Dear sir,my nokia 6233 set shows corrupted IMEI no.plz help me to restore it back.
My Nokia 6233 has IMEI corrupted as told Mobile Repairing Centre. Problem is after SIM inserted no network sown and "Registration Failed" message displayed. Phone is automatic switch off after 30 sec. When I dialed *#06# Serial No. 1234561012345? shown.What should I do? Please help me.
Jan 16, 2011 | Nokia 6233 Cellular Phone
LG C2500 Cellular phone camera not working
I HAVE LG C2500 SOFT WARE I WANT SOFT WARE FOR THIS MOBILE
Mar 29, 2008 | LG Cell Phones
How to unlock a restricted code on a LG phone Model-G4015?
hi i just want to know how to be able to use a phone from another country with my sim card but i'm unable to use it because it says to put the restricton code and i don't know it. so i really need your help.the model is a LG phone and the MODEL is L1150
IMEI:010379-00-071280-8
PLS HELB ME
Dec 31, 2007 | LG C1300/L1200/4010/4050/L1150/G4015...
Cell Phones Logo
19 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
