Question about Razer Mako 2.1 Speakers
It does not turn on!
Hi there, I connected my speakers after a year of lying in storage and they do not turn on. I opened them up and the fuse was blown. I attached a new fuse but that did not solve the problem. I cannot think of anything else to make it work. Any help as to what to do or where in London I can give it for repairs or something would be much appreciated. Thanks
05 monte carlo no sound from speakers but raido shows its on and fine
If you have an extra speaker lying around you could wire it in by unplugging one speaker and seeing if it works. You have a fuse on passenger side fuse box for the amplifier. Check to see if its blown. A thumbs up would be greatly appreciated if this answer is helpful to you.
Dec 19, 2014 | 2005 Chevrolet Monte Carlo
I hooked Up my stereo receiver tuner to a CD player and am using 2 bose speakers Sat in a dry storage for 10 years After first hooking up sound was fine next time I turned it on speakers reverbatate I...
Foam rot, all old speakers get it, you can get them re-paired or buy a do it your self kit for 30 bucks, its happened to a few times, easy to repair and bose speakers are worth it usually
Sep 08, 2013 | Car Audio & Video
Everytime i plug in my speakers and turn the power on the fuse imediately blows...ive changed the fuse and the two fuses on the inside of the sud dont look blown what should i do...these are the best...
Yes I have had these for many years. Work great. However there is a resistor that has been known to fry. Due to the connector plug (which is a flaky round pin connection.) arcing and once that happens it. You get current overloads, hence fuse blows.
Unfortunately parts are scarce and not label easily to get replacements. So I just bought new
GL
hope this helps
don
Jul 11, 2011 | Klipsch ProMedia 21 2 Speakers
My mc2105 blows fuse as soon as you turn it on. this unit has been in storage nad the owner said it worked fine he lied I think but any way can you help
The Amp module might be fried, did you plug it into a speaker with an Ohms mismatch?
If the fuse keeps blowing, you need to get it repaired by a pro.
Jun 30, 2011 | Audio Players & Recorders
Power to subwoofer but no power to SA-HT692 receiver.
I had the same problem although not in storage but it just lost power to the console. It turns out that when I press down on the cable connecting the sub woofer and console, at the back of the sub woofer, I temporarily get power to the console. I did that for long enough to eject my DVD's and then opened the back of the sub woofer to fix it and cracked the board and broke it forever.
Sep 20, 2009 | Panasonic Audio Players & Recorders
Power Light, Pulsating Level Control, Blows Fuses
you may of caused a short in the connections or it got moisture why in storge if so the hole subwoofer is screwed
Jun 07, 2009 | Infinity BASSLINK Car Subwoofer
My constant power wire wont work
check all your fuses you could have blown one
some radios have fuse in rear of radio near connectors also
or you could have dammaged radio &-or other electrical components be careful !!!
some radios have protected speaker cuircuts that turn off when short is detected - reset radio with speakers disconnected or connected back to working order
some radios have terminal pin locations stcker on side of radio or stamped on it if not sure where wires go to what terminals.
May 16, 2009 | 1992 Toyota Celica
I have the lg secret mobile phone. I am having problems with my bluetooth. The problem being is that i am not able to receive anything via bluetooth. i have checked all my settings and cannot see where the...
hey guys, i had the same problem and fixed it :) you should only change your primary storage settings:
settings-memory manager-primary storage settings-external memory
your handset memory is full and that's why your phone rejects bluetooth transfers :)
Jul 06, 2008 | LG Secret ? KF750 Cellular Phone
Razer Mako 2.1 Speakers Logo
54 people viewed this question
Top Razer Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Razer Audio Player and Recorder Expert? Answer questions, earn points and help others
