Question about HP Officejet 4355 All-In-One InkJet Printer
Service manual cartridge error
    Novelist:
  • 58 Answers
All HP printers are quite fussy on cartridges. Sometimes they just need the cartridge taking out and the contact panel cleaning off very very gently with appropriate electrical contact cleaner (Electrical Solvent Cleaner).
I find the easiest way to diagnose these kinds of error is to use another cartridge and see if you get a different error / response.
Even an empty cartridge is handy for this - it will just show up as being empty instead of showing an actual cartridge error.
If the error is accompanied by the print head moving to one end of its travel and slamming to a halt, then this normally indicates that the plastic strip inside needs cleaning - a simple job but does require the whole casing being removed :(
The service manual doesn't really tell much, beyond the main parts of the unit itself (I don't have a copy for that specific Officejet). As the cartridges are an all-in-one separate item it's not mentioned beyond saying where they fit.
In general, it's down to either cleaning the contacts, or replacing, the full cartridge to get past most errors on most modern printers.
Posted on Jul 12, 2013
Keeps saying turn off an restart printer error 5200 ? check manual nothing in manual?
Hello and Welcome to FixYa!
Error number 5200 is a
service error. To solve this error follow the given steps:-
First of all unplug the printe
r then open the top and bring the ink cartridge holder to the middle and now raise the gray bar and remove the print head assembly with the cartridges in it. After it lower the gray bar with the head missing and close the top with the head out. Now restore the power and wait till the printer starts.It will tell you to put in the cartridges, Put in the cartridge and restore the print head, close the top and the printer will resume working and Error will be removed.
If you have already tried all of the above and still you have error then it is probably that your Canon printer is in need of servicing by a service professional.
Feel free to let me know if you have any questions
I hope this solution helps you
Thank you for using FixYa!
Aug 28, 2011 | Canon PIXMA MP470 All-in-One Printer
Canon pixma mp272 printer. replaced black cartridge for the first time and now it wont print. getting error p08 on the printer and error 5200 on my laptop screen
Hello Hellen,
the error P08 is error for abnormal temperature in print head. Aa possible cause the ink cartridge is faulty and needs to be replaced.The same error description is for 5200 on your PC.
I recommend that you try to replace ink cartrigde under warranty in store where you bought it. If after that you still have error, take the printer to the service center because they logic board ( pcb ) is faulty.
Hope that helps!
Aug 25, 2011 | Canon Pixma MP270 All-in-One InkJet...
Error 6000
This is the error code printer Canon IP1200, IP1300, etc. light blink Indicator:
3x orange 1x Green = mechanical error
if you dont have any knowlegde about printers, better bring your printer to Canon service center.
4x orange 1x green = printer absorber full
reset your printer using software ressetter or try using manual reset. different printers have different manual reset.
5x orange 1x green = black cartridge/color cartridge error
can be chip error or connector is dirty.
7x orange 1x green = black cartridge/color cartridge error
8x orange 1x green = printer absorber full
12x - 17x orange 1x green = cartridge detection error
How to Reset waste ink counter Manually 1. Unplug power and USB cable. 2. Open door and hold power button. 3. Connect power. 4. Close door, then release power button.
How to Reset waste ink counter using Resetter
1. Download software for Canon iP1200 printer. DOWNLOAD 2. Unzip downloaded file to any location using, 7ZIp, WinRAR, Winzip, etc 3. Run GeneralTool.exe 4. select connected USB port number from USB port 5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION 6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. the selected waste ink counter will be reset.
Thank you for posting. Hope this helps.
Jul 06, 2011 | Canon PIXMA iP1200 Photo Printer
Iam getting a 59.51 printer error I have changed he cyan cartridge and the error goes away but after 1 hour it comes back
Hmm, checked the service manual, the 59.51 does not show as a valid error. The 59.5X errors all deal with the cartridges, however error should be 59.5K or C or M or Y to indicate cartridge. Based on experience, I would check the black cartridge as it is the first in the list and it is possible that they used numbers instead of the letters on some versions of the firmware.
Apr 22, 2011 | HP LaserJet 5550dtn Printer
Plotter works perfectly except......doesn't print. It works as if it is printing, no errors, all normal (have replaced cartridge)
I will try two things:
  1. HP Service Manual page 1-3 recommends that whenever a Print-Quality problem appears, it is advisable to run a Print-Quality Plot to help diagnose the problem. It will help you differentiate between possible cartridge errors and other problems. Method: Follow Service Manual page 6-3 and all other related pages.
  2. Also HP Service Manual Page 4-12 described how to run a Carriage Test which checks the connection between the carriage flex circuit and cartridges.
The first method may be able to diagnose the problem and also is easier. The second method is more complicated, but you should be able to do it if you can spend a little bit time on it.
Nov 30, 2010 | HP DesignJet 450c InkJet Printer
Canon mp190 error e5, with refilled cartridge will not reset, even though the error only came on after the printer had already worked with the newly refilled cartridges. Ive tried the reset/power button...
Hi. Try to reset the printer using the procedure below.
Manual Reset for Canon Pixma MPC190 Printers
  1. Enter the service mode SERVICE MODE – pressing buttons Menu, Copy, Scan, Copy, Copy
  2. Choose TEST MODE.
  3. Select 8 PRINTER TEST TEST MODE.
  4. Choose 3, EEPROM CLEAR
  5. Select 0, INK COUNT
  6. Press the Set button.
  7. Click Stop / Reset button (return to item 3), and again press the ON / OFF
Aug 21, 2010 | Computers & Internet
My Canon s4500 not working, with 6 beeps error
This is because the BJ Cartridge is not installed. Please refer to your manual page 214.
Two beeps: Out of paper, or paper feed error
Three beeps: Paper jam
Four beeps: BJ Cartridge out of ink
Five beeps: Cartridge not installed correctly
Six beeps: BJ Cartridge not installed
Seven beeps: BJ Cartridge defective
Eight beeps: Waste ink tank almost full
Nine beeps: Automatic print head alignment failed
The POWER lamp flashes orange and green alternately with beeps: Service error
YBC (/\)
Oct 08, 2009 | Canon Office Equipment & Supplies
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Oct 01, 2009 | Canon S400 InkJet Printer
Print cartridge problem: tri-color
lestave my j4580 trouble lt says ck blk cartrige
Jun 09, 2009 | HP OfficeJet J4580 All-In-One Laser...
Canon iP4300 service error on my printer
dear
Don't waste money on Printer Ink. Save up to 65% on toner cartridges, ink cartridges and printer supplies. <a href="http://www.concordsupplies.comhttp://www.concordsupplies.com">http://www.concordsupplies.com</a>
May 28, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
HP Officejet 4355 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
