Question about Whirlpool GB2SHDXTS Stainless Steel
Follow up/ update on Whirlpool GB2SHDXTS00 coils freezing
I tried posting this but apparently it didn't post. I posted the problem with my refrigerator that started this thread. I had a repairman out to fix the refrigerator. He replaced the defrost timer. About a month later the coils iced up again. I called the repairman back. He said he wasn't sure what the problem was, but he would do some research and get back to me. Two weeks later I hadn't heard from him and he wouldn't return my calls. I finally called another repairman and he came out today. He said the Control Board is bad. It has a relay sticking. He turned the refrigerator and freezer off, but the refrigerator still kept making noises. He said one of the noises was the damper valve opening and closing, but it shouldn't be because he had turned the refrigerator and freezer off. He listened little longer and asked me if I could hear the humming sound. He said that was the compressor, which shouldn't be making any sounds because everything was shut off. He said the Control Board costs about $220. Does any of this sound logical, or did I get another fly by night repairman?
  • 958 Answers
SOURCE: Whirlpool 20.8 Top won't cool neither refrigerator nor freezer
that's about right, if the compressor is drawing more than 4 amperes, then it is no good.
A reminder also to check the condenser for dirt and debris that could have accumulated at the front, this is a major contributor to compressor failure. check also the fan near the compressor. it should be running at the same time the compressor runs.
that's nice to hear from whirlpool....
good luck tapperal,
tnx 4 using fixya,
drcool
Posted on Oct 07, 2008
bobicehouse
  • 1524 Answers
SOURCE: Bad Compressor, valve sticking in the compresser
Contact Whirlpool Customer Care about this. There has been a serious problem with the Embraco compressors they are using.
Posted on May 15, 2009
  • 103 Answers
SOURCE: Ice Maker on Whirlpool Side by Sidek stopped making ice
Go to sears.com, select "Parts Direct", enter model number and wait for unit to be displayed, find ice maker part number and price.
Posted on Oct 01, 2009
dmftrucker
  • 1922 Answers
SOURCE: Whirlpool refrigerator side by side freezer won't freeze
your over-load/contactor is defective, un plug it from compressor and shake it if it rattles its bad
Posted on Nov 02, 2009
kel1guy2002
  • 3740 Answers
SOURCE: refrigerator/freezer won't stay cold.
With the defrost timer being replaced already it sounds as if the repairman is not looking at the real problem. Unit works for 2 days then things start thawing. Hint Hint... it is not defrosting. There is a heating element inside the freezer section attached underneath the internal tubing that melts the ice every 6 to 8 hours via the defrost timer depending on the defrost timer installed. To prove that it is not defrosting..... just unplug the unit and place a stand fan blowing into the freezer for about 90 minutes. I would bet that once you plug it back in it wil work for 2 days and the problem once again repeats. With 2 calls on the same unit and you still have the same problem I would be calling the service people back and demand they fully troubleshoot the defrosting element and thermostat. Personally this is an unstatisfactory performance of an in home service by a repairman. With the exception of a new part if required, they should wave any labor and service call fees.
Posted on Jan 02, 2010
Testimonial: "Thanks! The repairman also replaced the thermostat, though. What should I ask him to do this time? Replacements were: timer, thermo, timer."
Where is the freeze plug located on a 1991 Acura Legend
more info on freeze plug failure? - The Acura Legend & Acura RL Forum
www.acura-legend.com/vbulletin/.../more-info-freeze-plug-failure-1436...
May 29, 2010 - 5 posts - ‎2 authors
my mechanic told me that my freeze plugs could have failed, i have already searched ... Car 1: 1991 Acura Legend ... Car 1: 94 acura legend ls. anti freeze leak
May 11, 2010
Easiest way to
Jul 17, 2007
Manual transmission fluid change help
Apr 7, 2007
engine block heater?
Dec 21, 2003
More results from www.acura-legend.com
Where is the freeze plug located on a 1991 Acura Legend ...
www.fixya.com/cars/t26009696-freeze_plug_located_1991_acura_legend
1 hour ago - where is the freeze plug located on a 1991 Acura Legend - Acura Cars & Trucks question.
Acura Legend leaking freeze plug Questions & Answers ...
Dec 16, 2015 | Acura Cars & Trucks
Indoor fan barely turning
the three post capacitor has c for line voltage in, the f or fan is for the outdoor motor,and com or comp goes to start winding compressor.youll have to follow wires from indoor motor to find capacitor. to find wires to outdoor motor to capacitor you have line voltage and capacitor wires .look for schematic it would help or send colors of wires from both motors and compressor common,start .run.
Jun 07, 2013 | GE Zoneline AZ55H07D Air Conditioner
My whirlpool cabrio wtw6600swo makes squeaking noise while spinning. I took the bottom rotor off and cleaned it out and greased the fitting and it still squeaks. I rotated it slowly and noticed that the...
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory systems .
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 09, 2012 | Cars & Trucks
How to unlock RCA 32F531T 32 '' tv. I tried the manual solution but didn't work.
You might have to enter its service mode option to unlock it. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 580 posts to different brand TVs.
Aug 13, 2012 | RCA 32F531T 32" TV
Check engine light is on code p01870
I didn't locate that one you posted, but this is the closest thing I ca e up with P1870 Transmission Component Slipping/ Transmission Mechanical Transfer Case 4x4 Switch Circuit Failure I don't know if that pertains to your vehicle since the info needed isn't posted on your question, but if you reply to this post, I will assist you more
Sep 06, 2011 | GMC Suburban Cars & Trucks
Wiring Kenwood KFC-W3003
If it's a single voice coil, it's probably 4 ohms. the sub only handles about 175w RMS, so don't expect earth shattering bass to come out of it. A single voice coil is easy. Positive from the amp to the positive post of the sub, negative from the amp to negative post of the sub. This sub sounds lots better if it's in a sealed enclosure. A ported enclosure allows too much cone movement, heating up the coils, and the sub fails prematurely. Hope this helps.
Aug 25, 2011 | Kenwood KFC-W3003 Car Subwoofer
I need to know how to bridge the mtx speaker 4500
I assume you mean wiring a dual 4 ohm voice coil sub to a 2 ohm load, right?
Follow closely
Go from positive of the source (amp or positive post in box) to the positive of both voice coils.
Then go fromt he positive of the source (amp or positive post in box) to the negative of both voice coils.
You will be running two length of speaker wire for this. It's the easy way and makes sure that each voice coil gets clean power.
This is called a parallel set up and will bring two 4 ohm voice coils to a 2 ohm load.
Happy Wiring
Aug 14, 2011 | MTX Thunder 4500 T4510-04 Car Subwoofer
Friends posts to the "Donnie
Apparently this is an issue for several fan pages, so this is clearly an issue on the Facebook side of things.
If they are aware of the situation, which they sometimes aren't, then they will deal with it.
You may not get these posts back, if they're lost, then they're gone for good.
var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Jul 31, 2011 | Facebook Social Network
How to twitter
1. Login to twitter.com or open up a new account.
2. Put up a short bio, click on Settings, click on Profile
3. Upload a photo if you like and then click on Save
4. Figure out who to follow, these are people or subjects that interests you. Use this page http://search.twitter.com/ to search for these people.
5. Tweet. That easy. Tweet is to update your twitter, for starters it might be similar to yahoo messenger status, saying You're available or make it more specific that will fit 140 characters, you might say "I'm posting a brief tutorial on fixya.com"
6. Your goal why you post your updates is for someone to comment or give you feedbacks not just to post something.
7. Conversation will start from it, just go with the flow, answer as honest as you can.
8. You may also send direct messages to people that will follow you. People follow for many varied reasons, could be they're interested in what you're doing, they share the same interests, they are simply fond of your postings.
Jul 21, 2011 | Twitter Computers & Internet
Catastrofic failure ox8000ffff
This is off a windows vista forum and the solution belongs to someone else but will work.
" n/a posts
RE: Cata. Failure Ox8000FFFF This was found in previous post and apparently it workrd:
Try renaming the SoftwareDistribution folder
Click Start, Choose Run.
In the Run box, type services.msc.
Click OK.
Right-click the Automatic Updates service.
Click Stop.
Stopping the service will take a moment.
Rename the "SoftwareDistribution" folder: a. Click Start, click Run, type
%systemroot%, and then click OK.
b. Right-click the SoftwareDistribution folder, and then click Rename.
c. Type SoftwareDistribution.old, and then press ENTER to rename this folder.
Click Start. Choose Run.
Click OK.
Click Start.
Starting the service will take a moment.
You will lose you history but not important. Try WU again.
Regards
Bob J
If advise given from anyone, solves problem or not, or if solved from
another source,post back & let us know.
Then we all benefit."
Jun 11, 2009 | HP Pavilion dv6000z Notebook
Whirlpool GB2SHDXTS Stainless Steel Logo
43 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
