Trane xr12 how do wire go on
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: No heat on trane XR12 heat pump
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Posted on Dec 25, 2010
  • 767 Answers
SOURCE: my trane xr12 wont run.
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
Posted on Sep 02, 2011
  • 304 Answers
SOURCE: ac is set at 74 and it only cools to 80
system needs to be charged check filters and coils make sure they are clean first could be an air restriction issue to your intake
Posted on Jul 29, 2012
robbannon78
  • 19 Answers
SOURCE: Trane xr12, fan works but compressor doesnt come on.
Check the capacitor and contactor. You may have wires burnt at the compressor terminal from corrosion.
Trane xr12 heat pump switching to aux
Sounds like the compressor is not running. Possibly a bad capacitor. Check system in cooling, see if it cools. If it does cool then you likely have a reversing valve issue. Good Luck!!
Apr 30, 2017 | Heating & Cooling
Ac is set at 74 and it only cools to 80
Jul 28, 2012 | Heating & Cooling
Trane xr12 blower stays on after first cool cycle run
Hello, this is usually caused by a sticking fan relay on the intergrated comtrol board. You may be able to tap on it to shut it off but eventually the control board will need to be replaced.
Jun 02, 2012 | Heating & Cooling
My trane xr12 wont run. i checked the capacitor and its good but still nothing is working.
Sep 02, 2011 | Heating & Cooling
I have a Trane xr12 air conditioner. I turned off 230v breakers at the air handler, cleaned the filter and turned the breakers back on. now the compressor doesnt come on. I checked the relay on the...
Is the blower coming on inside? If it isn't, try tripping both breakers again. If the blower is working, your thermostat may be timed out or the air cond may have a timer in it that will keep it from coming on for a few minutes.
If none of the above work, make sure you didn't pull any wires off when you pulled the filters out.
May 28, 2011 | Heating & Cooling
heatman101
Dec 25, 2010 | Heating & Cooling
I have a trane XR12 Heat Pump. The cooling fan on the outdoor unit does not run nor does the compressor. The fan motor heats up and hums. I am guessing that the problem is the start capacitor on the fan...
Hello Rich,NO you have a dual capasitor that runs both fan & compressor motors.Shut it down and let it cool off.You need the uf rate numbers & the volt rating of the existing cap (printed on the side)to get EXACT replacement.The wires plug in to the top termanls C, HERM &FAN.Worth fixing good luck.
Jul 29, 2010 | Heating & Cooling
Air Conditioner compressor fan stops, Capacitor wired wrong?
Purple should be on "C".
The fan motor may be destroyed now. Switch the wire and see if it keeps running or not.
Apr 28, 2009 | Heating & Cooling
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
