Question about Sewing Machines
Elna 2030 manual
How do I thread the machine?
SOURCE: Sewing Machine Elna 6000 model
Cannot get top thread to catch and uplift bobbin thread, have changed bottom bobbin; think this may be shuttle problem. Need to get machine in to Polokwane in Limpopo Province to a repair center, cannot find a contact number of Elna there. Can you assist?
Posted on May 27, 2008
SOURCE: service manual elna 722010 sewing machine
www.whitesewingcenter.com has the manual for an Elna 722010.
Posted on Mar 27, 2010
  • 255 Answers
SOURCE: How to thread an Elna 2005
Hi. I've searched a number of my sources for a manual for your machine, but the closest I could find is for the 2002-2004-2006 models at http://www.mastersewusa.com/info_elna_2002_2004_2006.html
Threading should be similar enough between your machine and the ones covered in this manual that you can see what's going wrong.
Hope this helps!
Robbie
Posted on Jul 30, 2010
Tally Girl
  • 1129 Answers
SOURCE: I need a manual for
There is also a Yahoo group for Heirloom Elna owners which this model is.
You can find threading diagrams and manuals at www.sewusa.com. the supermatic will be closest to your Special. This webpage has images of threading the bobbin; all Swiss made Elna's have this wonderful top loading bobbin system and they are great. Important: use Elna bobbins, they have holes on the TOP ONLY. When you wind the bobbin, ensure the thread winds evenly by nudging the thread with your finger tip, keep the thread under tension as it winds by placing the handle of your scissors onto the top of the thread reel. Cut the thread, then place the bobbin into the bobbin case, holes upwards. The bobbin will turn anticlockwise as you pull thread from it. Follow the directions from the threading diagram, you need to "click" the thread into the tension spring. Now thread the top thread through the marked locations in the diagram. Hold the end of the thread as it comes from the needle and manually turn the flywheel to lower the needle down and up once to catch the bottom thread and bring it up to the needle plate.
ALWAYS hold both the two threads at the back of the needle plate when you start sewing, really important. I tally_girl.jpg You will have a knob with numbers going from -4 to 4, this is your stitch length dial. The negative numbers are "Reverse" normal stitch length is 2.5. The white knob is stitch width when the needle swings from side to side. Straight stitch would be zero, and then higher numbers for zig zag etc. The little wheel gives you different needle positions. And the metal slide at top of case is the reverse lever.
Hope this helps you a little. Early Elnas are all very similar and wonderful machines to use.
Posted on Mar 02, 2011
Tally Girl
  • 1129 Answers
SOURCE: I have no manual
There are several websites where manuals can be found:
http://www.tias.com/stores/relics/ has authorised reproductions of many Elna manuals for sale but not yours.
www.diplodocs.com is a free souce but no 1010 there.
www.sewingpartsonline.com is a great site too, and they have yours for sale $US15
link is
http://www.sewingpartsonline.com/instruction-manual-elna-1010.aspx
I don't know this model real well, but I'm guessing it is a front loading bobbin and bobbin case design maybe?? If so, you may well find that just looking at the instructions for any front loading bobbin machine will get you started,
try this link
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_225_threading_diagram.htm
These Elnitas 225, 244, 245 were front loading bobbin style but "made under licence" and sold by Elna. I think the 1010 may well be a similar design so see if these diagrams help get you under way.
Its always helpful to source the genuine manual if possible though so worth spending the money; manuals contain maintenance info as well as threading up, and different techniques and accessories usually.
Lastly, Blanket stitch. I presume you mean the big chunky stitch where you turn an edge over and it looks like a straight line with a diagonal stitch going to the folded edge at regular intervals like this.
tally_girl_77.jpg Some sewing machines do a similar "overcasting" stitch but it won't be big like you might want on polar fleece or a blanket edge. The commercial blanket stitch you see on blankets will be done by a special purpose industrial machine and it applies a single thread just as you would when doing a blanket stitch by hand. So look at the stitch selection dial on your machine and see if there is something resembling a blanket stitch but it usually would only be 4mm wide, the maximum your machine probably can stitch.
So if you want a genuine blanket stitch, its a needle and heavy thread hand job, there are instructions on how to do at www.sewing.about.com, link is http://sewing.about.com/od/beginner1/ss/blanketstitch.htm
Posted on Sep 22, 2011
I have an old Elnita 130 sewing machine with no manual. How to I thread it? It appears to work but shows signs that I did not thread it correctly.
elna make elinta machine and a 140 is the same threading as a 130
try entering the sites as most I go to require an account ( free) to procedure to read or down load and that process would be better for you
I went google and typed in--user manual for elinta sewing machine model 130-- and the sites show 130, 140 and more so select a site and go from there
thee is also a www.youtube.com>watch that runs for 1.29 and shows how to thread an old elna sewing machine
you might pick up a clue from that film
Dec 16, 2016 | Elna Sewing Machines
How do I thread a Elna Junior Club Electronic
Perhaps this manual would be helpful:
Instruction Manual Elna Club
You could also take the machine to an Elna dealer and have them explain it to you.
There doesn't appear to be much information on this particular machine.
Jun 21, 2016 | Elna Sewing Machines
How do I thread an Elna 715
I searched for manuals online but found only items listed on "questionable" web sites. You may try checking with the local Elna store. Bring in your machine and ask them to show you how to thread it. They may be able to provide you with printed threading instructions.
Also, if you can find a manual for a model similar to your machine, frequently it can be used as a guide. Most machines thread the same way.
May 20, 2016 | Elna Sewing Machines
Any manual for elna 1200 model?
I could only find one for the Elna 1010...http://www.scribd.com/doc/3714472/Elna-1010-Manual
Perhaps that and the youtube video "how to thread an old elna.." http://www.youtube.com/watch?v=xEn3dNeiTqs
will give you enough help to get you started.
Mar 24, 2012 | Elna Sewing Machines
On my elna supermatic 722010 sewing machine, the thread makes the bobbin pop out and the thread get tangled underneath. I have had it fixed twice, which is expensive. Should I just get rid of it and buy...
not unless you can find another swiss elna, like star series su. check bobbin in right way, holes on top to wind and load. you havent bought anothet type bobbin??? go to www.arizonaexpressionz.com and download a manual for supermatic. then read bobbin winding and threading carefully and rewinf bobbin and thread up again. make sure thread goes into tension spring all the way. bobbin should turn anticlockwise when yoou pull thread. also please brush clean bobbin holder area and check for any threads caught there. now a drop of quality clear machine oil in middle hole and gently run for 30secs to work in. do this every time you get your machine out. there are several oiling points shown in manual. oil them. these machines are quality but yours may need love tlc from a elna tech especially if it has not been serviced in a while. but a well maintained elna will out stitch a new plastic machine any day in my humble opinion. if you want to join yahoo group elna heirlooms, experts who service their own and share photos info manuals and love these vintage classics.
Jun 16, 2011 | Elna Sewing Machines
I have for gotten how to make the machine sew and im having trouble threading a bobbin for my moms machine elna 7000 i need a manual or a quick note to get started
YOu can down load a manual from here http://www.arizonaexpressionz.com/elna_instruction_manuals/Elna7000.pdf
Just remember to click the bobbin thread into the tension device correctly and hold the two threads behind the pressure foot when you start each seam - Elna top loading bobbins give great stitch quality but you just need to keep stray threads out or they'll jam up.
Also, you must use the Elna plastic bobbin that the manual specifies for this machine - the 5000, 7000 and 9000 were Elna Tavaro Switzerland's first foray into computerised machines and first released in 1986.
Also, please check the manual when you go to buy twin needles, there are two types now as computerised machines usually need the twin needles offset from the shaft position. They have red or black plastic block between the shaft and the twin needles - I think you need the red ones but just double check the manual to make sure. And you can't do all the wide stitches with a twin needle as it will strike the foot.
Hope this helps a little.
Jan 16, 2011 | Elna 2007 Mechanical Sewing Machine
Hope this helps!
Robbie
Jul 17, 2010 | Elna 2005 Mechanical Sewing Machine
ELNA CONTESSA 410
I have a Elna Contessa 710 Manual. If you think it will help I may be able to scan a copy and email it to your own email address. Plz supply email address if interested or still unable to thread machine.
Mar 14, 2008 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
21 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
