Question about Garden
Cub Cadet LTX1050 Has difficulty shifting between gears - could it really need a new transmission?
I have a Cub Cadet LTX1050 riding tractor. Of course the warranty expired in April. It does not shift between forward, neutral and reverse easily. It takes several tries to get it to go. I took it to a small engine repair guy who tells me it needs a new transmission. I know nothing about small engines and am a single mom of 4 so I always feel as though mechanics take advantage of our mechanical ignorance. This will be a very expensive fix but I cant afford a new tractor now. Could the mechanic be right? Any advice is greatly appreciated.
    Novelist:
    Scholar:
  • 80 Answers
This can be a trans problem, but it can also be because you are not pushing the clutch/brake in far enough to ease shifting. bad clutch adjustment can also cause this as well.
Does the transmission otherwise work properly. (move freely in all the gears when it's in the gears without any grinding or bogging or burning smells? Does it stop properly when you push the clutch and engage properly when you release it. If so the transmission itself is probably okay but the shift mechanism where it shifts going into the transmission may need work. Most of these tractors all use the exact same transmissions (even different manufacturers often are using the exact same motors and transmissions as other brands. So Craftsman, MTD, Cub Cadet, even John Deere may all have a briggs and stratton engine and the exact same 5 speed manual transmission or hydrostatic transmission under them but then just have different looks and features up top. Sometimes the shift points on the common manual transmission get a little rusty inside the transmission. It's basically a small spring loaded ball that pushes from one rounded hole to the next and each hole is a spot where it holds the trans in whatever gear you set it at. This can get rusty and sticky and inhibit shifting. If you are not a big do-it-yourself person, then this is probably not an easy fix as it requires pulling the transmission and opening up part of it to lubricate/clean where the shift lever moves inside the trans or replace that particular mechanism.
However, one thing that you can do that may help SOME but only as a temporary thing is to shift it back and forth rapidly between forward and reverse while stopped (the motor doesn't need to be running even). This is kind of like swinging a rusty door back and forth to break down the rust. it's not a true fix per-say, but it can help loosen up those shift points enough to get you through a season or so if you just need to keep it going for a while till you can find a cheaper more honest repair person. . On the other hand, if it's really bad, it could break that ball loose and just make the tractor inoperable until you get that fixed. The parts for that are much cheaper than the actual transmission though.
Posted on Nov 14, 2013
SOURCE: hydrostat pump leak,cub cadet garden tractor
One... these are pressure relif valves. There are O rings that probably need replacing is all, the valve can go bad but since both are leaking it will probably be just O rings from heat that went bad.
Remove the valves and replace O rings. Use a 'good' pipe thread dope on threads when re-installing.
Two... never use teflon tape on hydralic systems.
Three... boscia is no guro for sure.... lmao
Posted on May 21, 2009
SOURCE: Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Posted on Nov 30, 2009
  • 33 Answers
SOURCE: Craftsman 42 '' 19.5hp lawn tractor gear shift
Sounds like your drive belt may have came off or it needs to be replaced. Take the battery out from under the seat to see if belt is still around transaxle. Sometimes it will jump off when doing a lot of starting stopping
Posted on Aug 04, 2010
Testimonial: "Bang-on, Barny. Many thanks."
Fix4You
  • 32 Answers
SOURCE: how to replace the drive belt on a 2006 cub cadet
Use the link below to download the manual for free.
http://www.cubcadet.info/Manuels/2005/Tracteurs/LT1042-LT1045-LT1046-LT1050-Owner.pdf
Posted on Nov 14, 2010
woobie dog
  • 1273 Answers
SOURCE: I own a Cub Cadet Hydrostatic Lawn Tractor, not
Hello, W/D here.
Without a particular model number, I'll have to be somewhat generic, so forgive me in advance.
The fact that the mower will run and the blades will engage is good news; it eliminates about half of the things that would need to be checked.
Look for a lever at the (usually) back of the tractor, on the back plate, down low. Sometimes called a range selector or a disengagement lever. Normally, the position of this rod is "IN". If it has pulled towards the "OUT" position, the transmission is disengaged. Usually this rod is pulled out when you want to push the mower, and I expect you're tired of that by now! Chech and see if this is the issue, and post back if not.
Regards, --W/D--
Posted on Mar 07, 2011
A diagram of the transmission on a cub /zero turn/tank
Michael, The dealer may print the diagram off for you, just try asking them nicely. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Cub Cadet Riding Lawn Garden Zero Turn Tractor transmission diagram Google...
Cub Cadet Riding Lawn Garden Zero Turn Tractor transaxle diagram Google...
1 Hydrostatic Garden Tractor transmission rebuild 1 of 4 Hydro Gear
https://www.cubcadet.com/wcsstore/CubCadetCatalogAssetStore/Attachment/owners%20manuals/residential/ZF50_02005033-08-1.pdf
Jul 02, 2016 | Cub Cadet Riding Lawn Garden Zero Turn...
Mower ran fine, put it in the garage Started this weekend and the back wheels are locked up.
    2014 - Cub Cadet LTX 1046 KW - 21.5 HP Kawasaki 46 ...
    www.georgiamower.com/cub-cadet-ltx-1046kw-2014
    The Cub Cadet LTX 1046KW Series Lawn Tractor is one of the most innovative and ... pdf, 2013 Cub Cadet LTX1046KW, LTX1050, LTX1050KW Owners Manual ... 2012 - Husqvarna YTH22V42 - 42 Inch Hydrostatic Riding Lawn Mower.
Jul 31, 2015 | Cub Cadet 2012 - LTX 1046 - 21.5 HP...
Will a wiring harness from a ltx 1045 fit a ltx 1050
Since the LTX1050 has an electric PTO and the LTX 1045 has a manual PTO then I would say no.
May 10, 2015 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
Cub Cadet 1212
You have to press the clutch\brake pedal to shift up or down gears. Check your manual, you may even have to come to a complete stop in order to change speeds,or direction. Cub Cadet Garden Tractor Operators Manual ManualsOnline com
Apr 07, 2014 | Garden
New transmission on cub cadet LTX1050
I would take it to a couple of places to get ideas what the problem is and if two or three tell you the same thing then get prices as well. Go from there.
Apr 10, 2017 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Gets stuck while trying to shift between gears
If you have a manual transmission, all the manufacturers pretty much use the same one. It's generally a good transmission but a weak spot on them is where the shift control goes into the transmission. There is basically a small spring loaded ball that pushes from one round notch to the next to secure whatever gear you are selecting. These are prone to getting water contamination and getting rusty and sticky. You can pull the trans and service this part or replace it. Before doing that, obviously check all your linkages for wear/tear/bends/obstructions. As long as all the linkage is smooth and tight and unobstructed, then chances are this mechanism is the problem.
Jul 02, 2013 | Cub Cadet Garden
I need to change the hydrostatic V-belt on a 2009 Cub Cadet model#LTX1050. Can this be done by me or should I take it to a service repair shop?
NOT REALLY HARD TO DO , BUT MAKE SURE YOU MAKE A DRAWING OF HOW THE BELT RUNS BEFORE YOU STARE OR YOU NEXT QUESTION WILL BE HOW DOES IT GO LOL
Apr 14, 2011 | Garden
Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Apr 11, 2009 | Cub Cadet Street Sign- tractor lawn riding...
RIDING LAWN MOWER STUCK IN GEAR
Have someone to rock you while you attempt to move gear shift. Hopefully it is only stuck between gears and will disengage. Your grease in gearbox may have become hard causing problems. If you wash the gearbox with water when hot (after mowing) You may have created moisture in gearbox causing major damage to transmission.
Mar 19, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
