Question about Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050
New transmission on cub cadet LTX1050
My Cub Cadet LTX 1050 is having difficulty shifting from forward, to neutral to reverse. It takes several attempts to get it into gear. Of course the warranty expired in April and the problem began in May. I took it to a local small engine repair guy who claims I need a new transmission. As a single mom of 4 kids with no knowledge of engine mechanics, I am worried that he may just be trying to make money off of me. Could this really be the source of my problem? It is very expensive to fix but I cant afford a new tractor and my lawn is 1.5 acres with only 4 trees. Any advice or input would be greatly appreciated. Thanks. Jen
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
  • 4 Answers
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Posted on Jul 02, 2010
  • 32 Answers
SOURCE: Cub Cadet 2166 tractor, changed transission filter and oil
did you check to see if your belt was in good shape and if the hydro relef was in
Posted on Apr 14, 2012
  • 6468 Answers
SOURCE: Does a Cub Cadet Model 1170 lawn tractor charge it's battery ?
when a engine has factory electric start it will have a charging system but it is only a couple amps keep in mind a small mower battery is only good for a couple years
Posted on May 14, 2012
BAMOUT
  • 2478 Answers
SOURCE: need to replace rear wheel studs on Cub Cadet
They said 7/16-20nf x 1" auto studs are easier. Auto parts stores has
them.
Posted on Jun 19, 2012
Mower ran fine, put it in the garage Started this weekend and the back wheels are locked up.
    2014 - Cub Cadet LTX 1046 KW - 21.5 HP Kawasaki 46 ...
    www.georgiamower.com/cub-cadet-ltx-1046kw-2014
    The Cub Cadet LTX 1046KW Series Lawn Tractor is one of the most innovative and ... pdf, 2013 Cub Cadet LTX1046KW, LTX1050, LTX1050KW Owners Manual ... 2012 - Husqvarna YTH22V42 - 42 Inch Hydrostatic Riding Lawn Mower.
Jul 31, 2015 | Cub Cadet 2012 - LTX 1046 - 21.5 HP...
I need a picture showing the placement of the 2 springs on the mowing deck of a 2011 Cub Cadet Ltx 1040.
Cub Cadet LTX 1040 and LTX1045 Riding Mowers - YouTube
? 2:24
www.youtube.com/watch?v=XLT1v7h4at4
Jun 10, 2013 - Uploaded by CubCadetCA Cub Cadet LTX 1040 and LTX1045 Riding Mowers. CubCadetCA ... How to Change the Deck Belt on a Cub Cadet Riding LawnMower: Using ...
Jul 25, 2015 | Cub Cadet Garden
Will a wiring harness from a ltx 1045 fit a ltx 1050
Since the LTX1050 has an electric PTO and the LTX 1045 has a manual PTO then I would say no.
May 10, 2015 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
After cutting the grass with a Cub Cadet 1050 after it set for hours the engine
check for water in gas espeially if you leave outside in rain try shooting some starting fluid in it see if it starts up drain gas and fuel lines install new gas fresh not same gas
Sep 02, 2014 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
Cub Cadet LTX1050 Has difficulty shifting between gears - could it really need a new transmission?
This can be a trans problem, but it can also be because you are not pushing the clutch/brake in far enough to ease shifting. bad clutch adjustment can also cause this as well.
Does the transmission otherwise work properly. (move freely in all the gears when it's in the gears without any grinding or bogging or burning smells? Does it stop properly when you push the clutch and engage properly when you release it. If so the transmission itself is probably okay but the shift mechanism where it shifts going into the transmission may need work. Most of these tractors all use the exact same transmissions (even different manufacturers often are using the exact same motors and transmissions as other brands. So Craftsman, MTD, Cub Cadet, even John Deere may all have a briggs and stratton engine and the exact same 5 speed manual transmission or hydrostatic transmission under them but then just have different looks and features up top. Sometimes the shift points on the common manual transmission get a little rusty inside the transmission. It's basically a small spring loaded ball that pushes from one rounded hole to the next and each hole is a spot where it holds the trans in whatever gear you set it at. This can get rusty and sticky and inhibit shifting. If you are not a big do-it-yourself person, then this is probably not an easy fix as it requires pulling the transmission and opening up part of it to lubricate/clean where the shift lever moves inside the trans or replace that particular mechanism.
However, one thing that you can do that may help SOME but only as a temporary thing is to shift it back and forth rapidly between forward and reverse while stopped (the motor doesn't need to be running even). This is kind of like swinging a rusty door back and forth to break down the rust. it's not a true fix per-say, but it can help loosen up those shift points enough to get you through a season or so if you just need to keep it going for a while till you can find a cheaper more honest repair person. . On the other hand, if it's really bad, it could break that ball loose and just make the tractor inoperable until you get that fixed. The parts for that are much cheaper than the actual transmission though.
Jul 12, 2013 | Garden
Cub cadet ltx 1050 extension spring where does it go
In case anyone has a 2014 Cub Cadet LTX 1050 KW and needs to know where the damned spring goes when it falls off when removing the belt keeper, here's a photo.
Jul 15, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub cadet 42" ltx 1040
http://www.ehow.com/how_6808091_change-cub-cadet_s-drive-belt.html
May 04, 2011 | Garden
Hello I have Cub Cadet LTX 1050 VT Sv720 23 HPEngine Kohler
This situation is just a clogged fuel line IN the tank. It happens. Yeah, stuff that gets In builds up in the line an elbow and plugs it up. Just pull the connection out of the tank and clean it out. I have even found plastic bits clogging the line on mine. I have a LT 1050 also. And a Cub ZT I just love.
Apr 26, 2017 | Cub Cadet Garden
Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050 Logo
71 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
