I have looked online and even went to HomeDepot and asked them for help. No one knows how to get at the light bulb. There are no tiny screws to remove. No knob at the base of the globe. The globe itself doesnt budge even when sprayed with wd40. I dont know if I am going to have to just break the globe off or if I am missing something. The model number on the fan only said 48TP. ANY SUGGESTIONS?
Have you tryed unscrewing the globe. Have run across this before. Might be VERY tight but it can be unscrewed. Just be ease and keep working it back and forth. Let me know this turns out.HAHAHA.
The variable speed switch in my HB Fan broke and when I took down the unit, the wires fell out so...
(More)
The variable speed switch in my HB Fan broke and when I took down the unit, the wires fell out so that I could not tell which wires went to the four receptacles on the switch unit. I replaced the unit and guessed at the position. Fan works but does not have the middle speed. Is there a resource to tell which wire goes in 1,2,3 and L by color?
I need a wiring diagram for Hampton Bay model AC-374. I bought a display model unknowingly that the...
(More)
I need a wiring diagram for Hampton Bay model AC-374. I bought a display model unknowingly that the wires were cut inside the housing. There is a sleave of four (4) wires that has been cut in which i do not know where or how they are to be hooked up. There is a black and white wire that was not cut that is hooked up to the incoming power supply. The lights come on but that's it!...nothing else.
I am wanting to remove a hampton bay ceiling fan. I am not having any success removing the cover...
(More)
I am wanting to remove a hampton bay ceiling fan. I am not having any success removing the cover that covers the mounting bracket. Is it a snap in place cover or is it screwed into place? What do you suggest. I am messing up the sheetrock on the ceiling trying to pry it loose.
