Error code F-35-9 for konica 7022 - Office Equipment & Supplies
SOURCE: error code f-35-8
Ensure there is no jam in the fusing unit. Turn copier off. Turn the copier back on while pressing down on the 2 and 5 keys. Select 1, the software switch settings. Using the arrows on the touchscreen, select dipswitch 3-1. Touch the off key. Press return, then turn the copier off and back on. If the code returns, you may have to replace the temperature sensors in the fusing unit.
Posted on May 20, 2008
Nitrotrike
  • 589 Answers
SOURCE: Konica 1112 Error code 35
The procedure is as follows:
1. Turn machine off.
2. Turn machine on while holding the 2 & 5 keys.
3. Enter 47 on the keypad.
4. Press the Stop/Clear.
5. Enter 0 on the keypad.
5. Press the START PRINT button.
Power the machine off and on to exit the service mode.
You're done!
Posted on Mar 27, 2008
ollysss
  • 7 Answers
SOURCE: KONICA 7030 F-35-7 CODE
F35-7 is a low temp abnormality in the fixer.
To reset you need to enter the '25' mode and go to dip switch 3 - 1 and reset this to 0.
This should reset the code. ( dip switch 3, 1 to 7 control the high/low temps for the fixing unit i believe they should all be 0)
Hope this helps.
Posted on May 21, 2008
  • 18 Answers
SOURCE: error code f35 konica 7022
Turn on the main and sub power switches.
Keep pressing the
* button until the message
“Please enter service password.” appears.
Input 9272 as the password and press the
[Start] key. (The password is fixed and cannot
be changed.)
[Mode Select Menu Screen]
Press the key of the mode to be selected on the
screen. To return to the Mode Change Menu
Screen, keep pressing the
* button until the
screen appears.
When the adjustment ends, press
[1. Normal Mode] key and the basic screen will appear
Posted on Jul 16, 2008
SOURCE: I have Konica 7022 copy
I am not an expert. I am someone that is lucky a lot when I have to fix something. I also had the F28-3 error code. The copier would begin to copy. However, when the unit began the printing process, the error code would indicate.
1) I downloaded the Service Manual (not the user manual) and checked the error code. This is what it says: Abonormal separation spark detected 5 times in 20 ms intervals, 5 times in succession for the same job.
2) I went on-line and found a couple of blogs from techs which stated that it in their opinion, it was one of three things, the T/S Corona Unit; an insulation failure which should be indicated by discoloration and a burnt smell where arcing has occurred; and the high voltage unit.
3) After removing the drum assembly and inspecting around all corona units, I could not see or smell any signs of arcing. So, I inspected the T/S Corona Unit and found one of the wires broken.
4) I removed the T/S Corona Unit, disassembled it using the instructions in the Service Manual.
5) I reinstalled the T/S Corona Unit and gave it a try. So far, so good. Copies normally again and no more error codes.
Good luck.
Posted on Dec 24, 2008
Konica 7022 error F35-1
F 35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Aug 27, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Konica 7022 26-3
Yes I stated what I recommended to do in your last post!
Jul 12, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Why error code F-35-3"?"
http://officeimagingsystems.com/id169.html take a look at here
May 24, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Error code c3905 in konica minolta bizhub 950
When C-35**,C-38** or C-39**(fusing temperature related
abnormality) occurs, be sure to repair defective parts before
setting DIPSW3-1 to 0. Setting DIPSW3-1 to 0 with defective
parts not repaired results in a fire.
Dec 21, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
Konica 7022 copier at start up says call service and shows F-35-3
The thermistor TH1 on the fuser unit is coming up as faulty this will cause your f-35-3 error you can reset it in service mode 25 dip sw3 0 to 1 however i do not do this as there is an issue i would replace both thermistors and look at the fuser unit for wear if in bad shape replace the fuser unit assembly
Jan 22, 2011 | Konica Minolta Office Equipment & Supplies
I have a konica 7022, it says call for service code F-35-3. what's wrong with it. please help me.
Fixing upper roller low temperature error.Verify the continuity the heater lamps and remove and clean the thermofuse.If the thermofuse not working change it.
Sep 25, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 (code F-26-1) Pls call service 0870-2425050)
i have a konica 7022 it say call service code F-35-3, what's wrong with it, help me.
Mar 21, 2009 | Toshiba 2060 Copier
Error code f-35-8
May 19, 2008 | Office Equipment & Supplies
Konica photocopier
My service info doesn't go back that far either, but this procedure should work to reset the code. However, I would make sure there's no toner build-up on the fuser thermistor or thermostat first, otherwise the code will reappear.
Here's the instructions on clearing the code:
Enter the 25 mode by holding down the 2 and 5 keys while turning on the copier.
Press the P key, then enter 47, then press P again.
Enter 0 and press the Print key.
Turn the machine off/on to exit the 25 mode.
If the code reappears, then theres a problem. If it doesn't, you're good to go!
Nov 11, 2007 | Konica Minolta DiALTA CF910 Copier
198 people viewed this question
jasbo
jasbo
