Firstline shows me error E6
Could you say me what the error E6 is for ? The machine is a Firstline 12 BTU split. The outdoor start working for a few seconds and then stops and gives me the error. The indoor fan not working . Thank you.
Speed boy
  • 76 Answers
SOURCE: York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Posted on Oct 22, 2008
  • 659 Answers
SOURCE: carrier split 42G250HF-1(indoor unit
I'm not sure exactly what unit you have and what controls you have installed on the unit. But....there usually is a flash code schematic on the unit. Usually on the inside of the blower compartment cover. This should tell you what is wrong with the unit. It could have a low voltage short somewhere and is loosing the call for cool. So the answer can be a possible yes to your question but without knowing the flash code, it's hard to tell from my point of view. You might end up calling a service professional out to check it.
Posted on Mar 30, 2009
SOURCE: DeLonghi Planus quick connect split heat pump.
I was told by a delonghi technician that it does this to defrost the unit.
Hope this helps.
Posted on Apr 22, 2009
  • 10 Answers
SOURCE: Outdoor unit does not start. indoor unit fan does run.
by the sound of it the relay in the outdoor section is bad
Posted on May 31, 2009
greenspan
  • 1734 Answers
SOURCE: LG split (3 indoor) LMU360CE
The LED #2 is only flashing while in disconnection or short in Thermistor (3 sec off / 0.5 sec on). If you want to change it, note: this is not an easy job to do! You will need to remove the top panel, then remove the control paneland then the front panel to gain access to the thermistor. The part isnot available to the public and requires an authorized service techfrom LG to take care of this problem. You will need a special tool toremove the front door seal spring clamp.
But you can call customer service @ 800 243 000 and see if theycan transfer you over to parts. Just give them the model and serial #and see if they would be willing to sell you the thermistor part. Youwill also need the door seal spring clamp removal tool to make the jobeasier.
Posted on Aug 02, 2009
Voltas verticool showing e6 unit not working !! What happend?
From search I found that on a Mitsubishi it said e6 and e7 that is an indoor/outdoor communication error. I had that happen once when I installed one of these split units, got e6 and realized I forgot to connect the wire on the indoor part, that triggers the outside to go on when thermostat inside starts the cooling cycle. Maybe a wire pulled loose. There was terminal blocks on each unit on one I hooked up, check breakers too.
May 03, 2016 | Heating & Cooling
My ONIDA split ac shows E6 error. What is it and how can it be resolved?
The blinking is an indicator that it needs service. Call a technician! Ask if they are experienced in mini split systems. You can check the air filters. Check the outdoor coil to see if its clean or covered up with dirt. And at the breaker or disconnect, turn off power, wait 5 mins, and turn it back on. Then give it 3-5 mins to see if it will reset itself. If this don't work, call a tech/service provider! These units are troublesome to troubleshoot. It states a "communication error". This means the outdoor inverter board is not "talking" to your indoor unit or vise-versa. Could be a sensor or the inverter board. Or any other component wired to that board.
Jun 07, 2015 | Heating & Cooling
Does not produce Heat
Sounds to me like it is defrosting the outdoor unit. Is this possible? The process takes a little bit to complete but it will then start up again.
Nov 14, 2014 | LG LA120HYV Art Cool 120HYV Ultra...
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
HOW DO I FIX FUJITSU AOU24CL1 SERIAL SIGNAL (REVERSE) ERROR, AT OPERATION STARTUP
Outdoor controller circuit board sounds faulty. This error means that the indoor and outdoor units cannot communicate. Replace the outdoor controller in this case. Check if there are more than one outdoor PCB as others can be damaged as well.
Jul 25, 2014 | Fujitsu HALCYON AOU24CL1 Mini Split...
What does error code E6 mean?
E6 usually means that there is a communication problem between the indoor unit and the outdoor unit. This could be due to a wiring problem or maybe you had a momentary drop in the voltage. Find the circuit breaker in the circuit breaker panel for your home/office that is connected to the A/C unit. Turn it off and back on and try using the A/C again. Sometimes the indoor unit is connected to one circuit breaker and the outdoor unit is connected to another one. Make sure you have disconnected and reconnected both before running your unit. If that does not solve the problem you may need to have some cable replaced between both units.
Apr 30, 2014 | Gree 18000 Btu 20 Seer Ductless Mini Split...
I have a samsung split system it's just shows error 6 and dosen't work .. It's the perpendicular style.. Please answer my question ...
Fault code. 6. From what I have read 1 of 2 items. The unit has completely lost freon charge. Or 2, outdoor has overheating problem, ie. condenser fan motor not running
Aug 01, 2013 | Heating & Cooling
Ac is showing e6
what does E6 error stand for
Jun 16, 2009 | Carrier Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
