Question about LG WM2688HWM TROMM SteamWasher
Why does water keep filling when cycle should be done?
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 187 Answers
You need to clarify EITHER Cold or Hot water. Usually it's the Cold water relay switch is "Stuck". You can remove the top of the washer (Un-Plug the dam thing first). Facing the washer like you normally do, Look to the mid-left, back of the washer. There are Two VALVES (COLD-COMPLEX AND HOT-SIMPLE). These are solenoids which are just a magnet that goes up and down when powered. You can "gently" tap each one with the handle of a screw driver. I herd that this works (It doesn't) so replace the Cold Water Valve (Expensive) about $40 +/- $10. The Easy one (Hot water) is only $12 and has one solenoid. Of course if One fails, the Other one is just waiting for you to complete THAT job to fail a week, month, or 10 minutes later. So do them both, throw them away, and then your water will fill as IT IS SUPPOSE TOO!
Posted on Oct 08, 2013
1 minute fill cycle,harvest cycle 3.5minutes water still filling the reservoir and down to a pan drain by the time reach the freeze cycle water seem to be in normal flow but the damage its been done before...
look for a stuck or otherwise malfunctioning water fill valve. one way to check, turn the machine off and see if the water is still running to fill it. start with that and let me know.
May 03, 2014 | Hoshizaki Cubelet Ice MakerDispenser Water...
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
The machine keeps filling up at the end of a cycle so I have to make sure I empty it in time.
If the water keeps filling, your water level sensor is probably bad. If it keeps filling at each cycle, your washer may be out of time.
Mar 03, 2011 | Bosch Axxis WFL 2060 Front Load Washer
My washer goes through the cycle but the cold
This sounds like your water fill valve is bad and will need to be replaced.
Feb 01, 2010 | Maytag LAT2300 Top Load Washer
My He3 begins to fill the drum with water (very slowly) after the cycle is done, I have to turn off the hose valves after the cycle to keep this from happening. Any ideas what is letting the water back...
sounds like you have a bad water valve..if water is come in try to unplug the washer if water stop you have a bad control if it keep filling you have a bad water valve
Sep 20, 2009 | Washing Machines
Washer keeps filling with water...
you hae a stuck float switch, it shuts water off when it reaches a certain height, fixing it involes removing the top of the washer (not easily done)
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Fill will not stop
you may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Oct 18, 2008 | GE WBB4500EWW Top Load Washer
Water just keeps running
check the drain hose to make sure that it is not stuck too far down in the house stand pipe it only need to be in the pipe 5-6 inches
May 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
