Question about Toshiba Televison & Video
Toshiba dvd/dvr error codes
What is the meaning of error code 3 in a dr570ku dvd recorder?
  • 2427 Answers
SOURCE: Remote codes
for universal or supplememnrt
please supply the remote bran and model you are looking for..
Posted on Jan 27, 2008
SOURCE: ERROR CODES
If you are trying to record from a vhs tape to a dvd, first of all you'll need to buy only 1x-8x dvd-r dvds. You can find the 4x or 8x on ebay. This recorder has a problem with the up to 16x. Put the DVD-R in and let it load. Put the videotape in. Press play on the videotape side - not dubbing but play - and let the videotape play for 6-10 seconds and THEN press the dubbing button. If you have somewhat of a lead-in on the videotape you won't lose anything. At most otherwise you'll lose 6-10 seconds. If the error code comes up, rewind the tape, and start again. Letting the videotape run for a bit first before pressing dubbing seems to prevent this problem, at least for me, and I was getting the error code every time.
Posted on May 26, 2008
cyberguru4u
  • 90 Answers
SOURCE: I, need a hack for Toshiba DVR-610
1. Press the Open button on your remote control to open the drive tray
2. Press the 2 button on your remote control
3. Press the 4 button on your remote control
4. Press the 0 button on your remote control
5. Press the 3 button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 0 button on your remote control
9. Press the Enter button on your remote control to change the region to 1 for region 1, 2 for region 2, and so on, or 9 for multi-region playback
10. Press the Open button on your remote control to close the drive tray
11. Power off the DVD player
12. Power on the DVD player
Posted on Feb 26, 2009
SOURCE: Funai VCR/DVD recorder DVR 2737. My -R discs
I was advised to try another make of blank discs. I bought Sony discs & they worked ok. I had been using supermarket own brand.
Posted on Oct 18, 2009
  • 172 Answers
SOURCE: recording (toshiba dvr player se-r0265
Number SE-R0265 is not a Player. It is the model number of the Remote Control for a player.
However, your question is somewhat generic for all Player/Recorders. First you must use good original manufactures DVD media for recording. TY (Taiyo Yuden) is the Toshiba recommended media in many of its manuals. Verbatim and Fuji are also very good. They are more expensive, but very much worth the extra cost in reliability and headaches. Also, some older recorders will have trouble recording/playing back/finalizing newer 8X or 16X faster media. Try to by 4X and slower media if you are having problems, even with the three recommended above.
Second, DVD-R or R/W media has to be 'Finalized' before it can play on other recorders. DVD media do not. Try using DVD media if you continue to have trouble. Also, there are two recording/format types you can choose to record with on your DVDR Recorder, Video and VR, on -R/W media. Video is automatic Video format only on DVD media and do not need to be formatted (I think) before use or finalized after done recording.
If you are still having trouble using -R/W DVDs on other players, Try DVD DVDs in Video Format.
Finally, Toshiba is know for DVD media sensitivity. Many of their recorders have Firmware upgrades. Be sure you have the latest by looking in your manual to find your Firmware Version, then check out Toshiba's support site for any upgrades. But, start with good media, finalizing -R/W media, using Video disc format, then using DVD media, in this order.
Posted on Sep 19, 2010
What does Toshiba DVD error code E 21 mean?
It seems to suggest that you are using unsupported media to record on.
Feb 10, 2015 | Toshiba Televison & Video
I have a toshiba dr570ku/i only get 2 hours recording time
If you have the manual it should give you the instructions under timer recordings. If not you should be able to find the manual on their website.
Oct 30, 2012 | Toshiba DR570 DVD Recorder
MY TOSHIBA DVR MODEL DR420KU WILL NOT RECORD ON DISC. IT KEEPS GIVING AN ERROR CODE AND NOW IT WILL NOT PLAYBACK DVD-R DICS, BUT IT WILL PLAY MY DVD+R DISCS. WHAT COULD BE THE SUDDEN PROBLEM?
see the cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU optical pickup contain lasser beam, NOT are reading the TOC from DISK+ Syscon can be defective, you must go to the repair shop TV for fix it see the diagram attached, is a complex equipment.
God bless you
Jul 16, 2012 | Toshiba RS-TX20 DVD Recorder
Every time I try to use the remote on my Toshiba RD-XS32SU Video Recorder I get the following code displayed on the unit: DR-OFF I do not know what it means and how to resolve the problem.
It is confusing to many people this function, but not impossible to investigate (perhaps experiment with some of the functions). You can get a copy of the INSTALLATION GUIDE (if you don't have a copy for any reason) from the following:
http://tacpservice.toshiba.com/consumerproductsupport/Manuals/dvr/RD-XS32SU_Inst_E.pdf
and if you don't have a copy of the original OWNER'S MANUAL, you can also download that from the following:
http://tacpservice.toshiba.com/consumerproductsupport/Manuals/dvr/rd-xs32_om_e.pdf
(copy and paste into your browser if required - these are both FREE documents)
(Page 48 of the installation guide (not the owner's manual) tells you about IR CODE setup option using remote - read that first if you like, then try your recorder).
Hopefully this helps you a tiny bit.
Mar 23, 2011 | Toshiba RD-XS32 DVD Recorder
Cannot record onto DVD
we are borrowing the unit and do not have the user manual. we cannot figure out how to record a self made vhs to a dvd. how do we do it? please help, its for a project that is due tomorrow.
Feb 14, 2009 | Toshiba DVR610 DVD Recorder/VCR
DVR K17LF Insert a disc
Hi, according to what I understand the unit works for some situations especially but you cannot visualize the content, in this case the problem that you one presents shows off to be Cd-DVD's unit that this trumping, if the equipment this one even in guarantee, you must come to an CAS or Center of Authorized Service, in order that they diagnose and replace the unit
Dec 27, 2008 | Toshiba Satellite A205-S4617 Notebook
DVR-510H
Not sure which code you mean. If you are talking about the region code, you need to use the service remote, which is available only to dealers. However, you can do a search and find that there is a company in UK that will rent you a service remote for this purpose. Be prepared to pay up to $50 for this service.
see for example http://www.dvd-hacks.co.uk/mods/piondisc.htm
Good luck
Dec 27, 2007 | Pioneer DVR-5100H DVD Recorder
Cyberhome 1200
I have a cyberhome 1600 dvd recorder and I need a code to program it to my bell remote but can not find any codes for the cybehome. can someone help with the codes
Nov 23, 2007 | Cyberhome DVR 1600 DVD Recorder
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
