Question about Olympus Optics
Collimate location of adjustment screws
3 Suggested Answers
SOURCE: collimation screws on the Celestar C8
If you are going to replace them contact "Bob's Knobs" and order the replacement thumb screws. Makes collimation much easier, no Allen wrench needed.
http://www.bobsknobs.com/
Posted on Oct 01, 2009
SOURCE: Difficulty with Skywatcher pro 150 collimation.
Watch this video on collimation.
http://www.andysshotglass.com/Collimating.html
Posted on Oct 04, 2009
How d I adjustthe band on 92Dodge Caravan
Low reverse band
Loosen, then back off locknut approximately five turns.
Tighten adjusting screw to 41 in.lb.
Back adjusting screw off 3 1/2 turns, then tighten lock nut
Kick down band
The kickdown band adjusting screw is located on the left side, top front of the transaxle case.
Loosen locknut and back off nut approximately five turns,
Ensure adjusting screw turns freely in the trans axle case.
tighten band adjusting screw to 72 in.lb
Back adjusting screw off 2 1/4 turns, then holding screw in position, tighten lock nut
Sep 25, 2014 | Transmission & Drivetrain for Dodge Ram...
How to adjust the gear engagement screw on a 1999 HD fsxtb night train
I believe you mean the clutch adjustment screw located inside the derby cover in the center of the clutch. If so, here is how you do it. Slacken off all the way the clutch cable adjustment screw located half way down the clutch cable. Loosen the lock nut on the adjustment screw and turn anti-clockwise a few turns. Then slowly screw it back clockwise until you feel a resistance or in other words it gets a bit tight. Slacken off a quarter turn and tighten up the lock nut making sure it does not turn while tighten it. If you get this wrong you will end up with a slipping clutch and burn it out over time. You then adjust the cable adjuster until you have about 3/16 play in the clutch lever. Tighten the cable adjuster nuts.
Sep 01, 2014 | 2000 Harley Davidson FXSTB Night Train
How do i adjust the transmissions gear engagement screw on a 1999 softail fxstb night train
Can't locate headlight adjuster screw 2010 siera 1500
Pop the hood and look straight down on the top of the light, behind the light there should be a screw hole (one round and one oblong) to the left and the right. You'll need a torx driver (I believe a T15) to adjust these. The round hole is for vertical adjustment and the oblong is for horizontal
Nov 07, 2012 | Cars & Trucks
Where is the air screw located
fcr carb has a fuel screw not air screw and it is located on bottom of carb toward the front of bike it is a small regular slot screwdriver adjustment that is resessed up in the carb their are aftermarket adjusters that do not neeed the use of a screwdriver and are worth the investment if you plan on keeping your carb adjusted correctly....
Jun 27, 2012 | Yamaha Motorcycles
What do you mean by LA in the chainsaw?
Locate the adjustment screws near the carburetor labeled with an "H," an "L," and an "LA." The "H" screw adjusts the high speed fuel-air mixture; the "L" screw adjusts the low speed fuel-air mixture; and the "LA" screw adjusts the idle speed.
Jan 14, 2012 | Stihl Saws
Can you tell me where the Water Fill Adjustment Screw is located?
Remove cover of front of ice maker, small brass screw on side w/small view port on front. small adjustments only on the screw. Factory setting is for 'hole' in view port to be in the middle. start w/ 1/4 turns on adjustment screw, clock wise less, counter for more. hope this helps.
p.s. place a towel under maker to keep excess water out of ice bin.
Apr 30, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
How do I locate the adjustment screws to reaim headlights on my 2007 Toyota Tundra
located in the lightlight assembly it's self are two screws....one for up and down adjustment, the other for side to side. refer to repair manual for proper adjustment procedure.
Jan 31, 2010 | 2007 Toyota Tundra
On a kazuma 50cc engine carb adj screw location
The lower of the 2 screws is the fuel/ air mixture- the upper screw is the idle adjust screw
Jan 22, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Headlight adjustment
This is your second response. I am calling amchrisler for the screw location
Dec 20, 2009 | 2000 Dodge Caravan
Optics Logo
Top Olympus Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Olympus Optic Expert? Answer questions, earn points and help others
