Control panel will not work
SOURCE: I have a GE air conditioner with ditigal panel. I
Wash out outside coil from time to time.This is the most over looked part of window units. Take care not to spray water directly into fan motor. If not real humid in house check temp coming out of ac inside and make sure filter and coil are clean. run on high speed and the air should have good force. 20 to 30 degree temp drop of room temp should be about right. Much depend on outside temp and humidity and indoor humidity plus insulation factor of area. How many people are in the area and if you keep unit on day and night .
SOURCE: I have a GE window
Some of them controls has a small fuse mounted between the touch pad and the control board. If yours is not lit up then the fuse is all ya need. Take the old fuse to radio shack. Unplug the unit if you decide to look. If the control is bad and costly yall can bypass the controls.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: new ge 18000 btu air conditioner touch panel not working
Normally you shouldn't operate an a/c without remote. You have to replace touchpad.
