Question about Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter
Sthil does the demo saw works with mix fyuel, or strait gas?
Sthil TS 510 concrete saw(not chain saw) has a tank for oil that is empty and a tank for gas/oil mix. Inside of the oil tank there is a hose that goes into the fuel tank. Why is there an oil tank if it is...
most concrete saws ive ever used that have a chain type blade have a water tank on them for cooling the carbide/diamond tips on blade , if it's a rotary (round ) type blade these are made of a material that is designed to wear down and provide the cooling needed
you sure dont want fuel getting on cutting surface one spark and it'll burn !
Mar 09, 2015 | Garden
Where can i find an exploded view of yhe shaft assembly for an sthil HT101
I would find a lawn and garden shop that sells and repairs sthil saws and ask for a copy of exploded view of your saw
Dec 07, 2013 | Garden
Whats the fuel oil mix of sthil ts400
Stihl two stroke oil mixed ar 50-1, do not use cheap two stroke oil or oil for designed for out board engines.
Jun 29, 2012 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Is it 25/1 petrol and oil for a sthil blower bg85 thanks
hi artwill3544
no
using sthil 2 stroke oil mix at the rate of 50:1 that is 20 mils of oil per 1.0 litre of petrol that you mix , or if you mix 5 litres you would pour in 100 mils of 2 stroke oil into a 5 litre petrol petrol can , then add 5 litres of petrol only and give good shake to mix , then fill your blower with that mix
cheers pauly46
Sep 21, 2011 | Garden
What is the fuel mix for 359
hi there troyandbec
pauly46 here
the ratio you should use is 50:1
that is 20 mils of 2 stroke oil for every 1.0 litre of petrol that you mix
so if you want to make 2 litre mix use 40 mils of 2 stroke oil , then add 2 litres of petrol only and give good shake
note use good quality 2 stroke oil , such as sthil or husqvarna oil from your outdoor power shop
but if using general 2 stroke oil from a garage use 40 mils of oil for every 1 litre that you mix
this ratio is 25:1 this mix is on the richer side
cheers hope this helps
May 01, 2011 | Husqvarna Chain Saw Maintenance Kit 357xp ...
I have a husqvarna chain saw 351. I did mistake , I put strait gas instead mix gas . Engine stoppt after 1 minuet . Engine won't start after that , spark plug is wet .
you can try a new plug but it sounds like the motor is bad.it only takes a minute to hurt a 2 cycle engine when they run on straight gas.
Dec 21, 2010 | Garden
Oil & Gas Mixture
if you are using sthil oil the mix is 50:1
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Ryobi 30cc trimmer won't run. Difficult to start, hard to keep ru
chnge the plug for the best you can get then depending on the mix petrol oil mix u could cahnge that ie if its 50:1 go down to 40:1 or visa versa if that doesnt work bin it and get a sthil or an ehco
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
What oil and gas mixture should i use 50:1 30:1 or 40:1
if using sthil oil the mix is 50:1 other wise 40:1
Jun 16, 2010 | Ryobi Cultivator
Just want the gas oil mix for a 25cc weed wacker
if using sthil oil the mix is 50:1 if not then its either 32:1 or 40:1 not to much dif
Jun 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter Logo
26 people viewed this question
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
Spud Howell
ray gallant
Are you a Stihl Saw Expert? Answer questions, earn points and help others
