Question about Dell Computers & Internet
Lime green My laptop screen hedges are broken
    Novelist:
  • 58 Answers
If your laptop screen has been bent or dropped/liquid spills/squashed, and has obvious signs of cracks or damage then you'l need to replace the complete screen (this involves taking all of the screen section apart and fitting a new screen panel inside - it's not a complicated job but is best done by somebody who's used to this kind of work, takes about 20 minutes).
Note that a screen can be faulty with no signs of actual damage, and can just go faulty for no apparent reason at all, at any time.
If you're lucky, it may just need the ribbon cable inside refitting/cleaning - they do come detached occasionally. There's plenty of video guides on the Internet about this kind of procedure.
If the screen does need replacing, they vary in price depending on which type it is - there are several types, and many are interchangeable as long as the size and connections are exactly the same on the rear.
The screen must be removed to check on which type you need first though, there are lots of guides on places like YouTube showing how to disassemble screens for all laptop models.
Note that it 'is' possible for a laptops mainboard to develop a fault (very rare though) where the display is not right, and it's best to check the laptop with a replacement screen 'just' for testing, before buying a possibly expensive new screen. There are only 4 parts that can be at fault in any case . . .
Screen ribbon cable (cheapest part)
Invertor (unlikely to be the problem on yours)
Screen itself (cost depends on type/model)
Mainboard (the complete inside circuit of the laptop)
Posted on Jul 12, 2013
Screen brightness brighter
Please try pressing the FN + F7 until you get your ideal screen brightness.
Oct 24, 2013 | Toshiba Lime Green 10.1" NB505-N508GN...
Screen suddenly turned lime green. Now when turned on turns lime green then goes to red color
sounds like you're using component cables for or HD, check your cables and make sure they're plugged in with the right color code and make sure they're tight. If you can't find anything wrong try replacing your HD cable whether it's HDMI or component.
Jun 25, 2011 | Sony KDS-60A2020 60" HDTV
Sound but the screen on my westinghouse 32 inch flat screen is solid lime green
By "sound but the screen on my westinghouse 32 inch flat screen is solid lime green" Do you mean that you have sound but the screen is green? If yes it means that an analog signal is being fed to a digital input. Did you recently change the input cables at the back from one port to another? If not then please describe what are colors of the cabels you are using(Yellow, Red, White or Red Blue Gren etc.,) and what port they are connected to so that I can tell you whether its a problem with the connections or the tv itself.
Jun 15, 2011 | Westinghouse 32" Flat Panel LCD HDTV
Poulan hedge trimmer GHT 225 it is a dash 2 How to adjust needle valves after replacing fuel lines (they are on the correct sides) the switch wires aren't pinched or broken and fuel seems to flow when...
The small green rubber thing sounds like the duckbill vent for a gas cap. Since the gas cap vent sits right over the open hole of the tank, I would check the underside of the gas cap. See if the little rubber vent is there. Normally, they will use a small clear nylon connector to hold the return line inside the tank. The small green thing sure sounds like a fuel cap vent. Here is a link to the diaphragm carburetors site with a tutorial on tuning these little carburetors. I will give you one from Zama and one from Walbro....Zama first.
http://www.zamacarb.com/tipspage.html
http://tech.flygsw.org/walbro_tuneup.htm
Jun 08, 2011 | Poulan Ght225 25cc Gas Hedge Trimmer
When watching a movie, on the bottom left of the screen is discolored. like on the blue screen, its lime green
This problem only happens when there is something magnetic in by the tv where the screen is lime green. Good luck!!!! hope this little bit of info helps
Jan 02, 2011 | RCA TruFlat 27F520T 27" TV
The viewfinder is showing a lime green screen, some colored lines and eventually comes back clear.
The problem is with a view finder cable ,it must have got broken as it gets hard while we using.
Good luck
Sep 30, 2009 | Sony Handycam DCR-DVD100 DVD Camcorder
How can i make my lime green ipod nano work again?
It probably needs to be reset. Just hold down the "Menu" button and the middle button for about 7-8 seconds.
Hope this helps!
Aug 24, 2009 | Apple iPod nano MP3 Player
Sony KDS R50XBR1 TV, LIME GREEN PIC
if all sources and hdmi cable are good--you need the hdmi input board--dont know sonys letter designation
Jul 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Computers & Internet Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
