Question about Refrigerators
Dometic rm2353 refrigerator
It cools on electric, but not on propane. It appears to light. Red indicator goes onto edge of green field and stays but it does not cool. Does anyone have a solution.
  • 19 Answers
SOURCE: Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Posted on Nov 18, 2008
  • 110 Answers
SOURCE: dometic refrigerator does not cool?
You need to check the Condenser coils, these are copper coils of tubing usually located on the back of the unit near the ground. They need to be free of all dust and grease to work at maximumefficiencyand it is recommended to clean them every 6 to 10 months. If those coils are already clean, the next thing to do is check the evaporator fan(The fan inside the unit). See if it's running. If it's not, check the coils behind it. If the coils are frozen up then you probably have to change out the fan motor.If they aren't frozen up then there may be a refrigerant leak or a bad compressor*. In order to legally reclaim, recharge, or test refrigerants you need a special certification2_bing.gif from the EPA. If you need to do so I recommend you call in a certified technician.
If the lights, fans, and compressor aren't working at all, check your fuse/breaker box to see if anything is tripped or blown.
If the lights are on but nothing is working, The thermostat may be having problems.
*To replace the compressor you need to reclaim and recharge the refrigerants from the system.
Posted on Apr 03, 2010
  • 79 Answers
SOURCE: Dometic refrigerator will not stay lit
sand your thermal cupler off or replace it not centing the flam
Posted on Apr 11, 2010
espressonist
  • 1711 Answers
SOURCE: dometic rm2611 refrigerator will not cool with on electric
We have a solution to this link that will help
http://www.fixya.com/support/r6019270-refrigerator_freezer_air_conditioner
Posted on Sep 15, 2010
SOURCE: My dometic refrigerator unit is not cooling
my domestic refrg will not work on electric but will lite on gas. freezer will get cold on gas but bottom will not cool.you can plug refrg in and it will kick the gas off. you unplug refrg on gas will lite.that part of the power board seems to be working.
Posted on May 15, 2011
CAN YOU MANUALLY LIGHT A DOMETIC RM2652 PROPANE FRIDGE IN A 2006 TRAILER
It will not light manually as the ignition probe is electronically controlled. If it doesn't stay lit normally then it will more then likely not stay lit when trying to light manually.
b2d344ab-6ceb-4320-bc24-f6c38ab91df8.jpg ArctiCold Refrigeration We keep it cold
Jul 24, 2014 | Dometic RM2652 Refrigerator
My dometic rv refridgerator is not cooling at all on propane or electric?
disconnect thermistor let run if ok replace if not replace board
Dec 23, 2012 | Dometic Refrigerators
I bought at Dometic propane/ electric fridge for my cabin last year. It has not run properly since. The fridge will light and run for a while with a blue flame but sometimes in the idle mode it goes out....
I have to ask, what is idle mode? I've never seen one that runs on idle mode, in a RV in 15 years. Has anyone used a manometer and tested Inches of water column in propane supply to fridge, as well as other appliances?
Any I've seen run on propane, are either on, (flame present, or off, no flame present.) Flame goes out completely when not calling for cool.
Jun 13, 2010 | Dometic RM2620 Refrigerator
Apr 11, 2010 | Thetford Norcold RV Cooler/Freezer
I connected our Dometic 2620 to propane line, no problem, but when I plugged it into power - nothing. No lights, no gas activity, nothing. Any hints?
Check your AC breakers, mine was on the same circuit with a GFI outlet that had tripped, took a bit of looking to find it, Good luck.
Jun 13, 2009 | Dometic RM2620 Refrigerator
Dometic RM2652 will not run on electricity only Propane
Most likely your heating element burned out or else the circuit board is bad. To test the heating element unplug it from the circuit board (j6 and j7 usually gold colored) take the two heating element wires and using an ohm meter make sure there is no resistance between them, if there is resistance the heating element is bad, Or can just put a plug onto the heating element and plug it into a 110 wall outlet and see if it gets hot. If it is not the heating element it is most likely the main circuit board. (between 1993-1996 dometic used a yellow epoxy filled circuit board that went out pretty quickly) if you have the yellow filled circuit board rather than the green one it is most likly the circuit board
Dec 18, 2008 | Dometic NDR 1292 Refrigerator
Oct 12, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
