Question about Refrigerators
Matsushita dd73c14gau6 16.9 lra
The compressor is hot and the fan dosent work also it does not cool
Master_Tech
  • 770 Answers
SOURCE: not cooling
The clicking you are hearing is your overload on your start system sounds like your compresser start ststem is out..or your compresser is locked up the only way to tell is to ohm out the compresser idf you dont have a meter you can install a start kit like a Supco Pro41 or a RCO410 or a factory replacement and see if it starts up the compresser.. Have you cleaned the condenser at all ??? although this will not fix the compresser it can be a cause of overheating..The part Number you need is a 2188831 for the factory replacemenet ($22.56)the supco parts part number SU RCO410 ($15.00) the Pro41 is part #
SU PRO41 ($17.97) you can get them at your local parts house they are all easy to change or if you dont have a parts house close you can oder it on the web at www.apdepot.com Hope this fixes ya
Posted on Feb 17, 2008
docjohn174
  • 943 Answers
SOURCE: not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
Posted on Sep 27, 2008
  • 1462 Answers
SOURCE: Refridgerator/Freezer stopped cooling
if the compressor was very hot to the touch, suspect you have a compressor fault
Posted on Oct 02, 2008
docjohn174
  • 943 Answers
SOURCE: fridgedaire side by side fan working, compressor hot, refridgerator and freezer not cooling
.thanks for your question i would try a hard, to start re lay on it after its cooled down. it might just do the trick. the appliance doc
Posted on Oct 30, 2008
  • 1122 Answers
SOURCE: refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Posted on Nov 04, 2008
Frigidaire/refrigerator Freezer not cooling Can hear compressor click here n but only runs 3/4 seconds
Hello
That's most likely the compressor overload
The start components are bad or the compressor is locked up take an amp draw then check the tag on the compressor it will give you the LRA rating
if you get lucky if it has a condenser fan motor check it
Thanks
Apr 16, 2017 | Refrigerators
U-Line 75FF Bar refrigerator stopped cooling
it could be a problem start/run capacitor for the compressor or compressor failure
get a fridge technician in to test and get a quote
Most small fridges are cheaper to replace than repair
Jan 09, 2016 | U-Line Refrigerators
I need the cooling capacity of a matsushita cnr05-980270 compressor. can anyone please assist?
I would need more information to properly answer your question.
What are you removing this compressor from?
The cooling capacity can vary greatly depending on the Evaporator size, the Condenser size and the fan speed that is moving the air. Also there are some other figures needed.
But if you could give me the application that you are using the compressor in I might be able to better answer your question!
Oct 11, 2013 | Matsushita DD73C14GAU6 1/4 HP R134...
Hot compressor
We cut compressor open to see what happened to it. Grounded and found couple more issues.
May 12, 2012 | Matsushita DD73C14GAU6 1/4 HP R134...
My true back bar cooler dosent cool it is not iceing over
If you can gain access to the compressor, you will see 2 copper lines going to the compressor. One is smaller than the other. VERY CAREFULLY lightly touch the smaller line while the unit is running. If the compressor is running, that line will be extremely hot.
Start there.
Let me know if I can be of further help.
May 27, 2010 | True TD-65-24 Commercial Refrigerator
I have a goodman 2,5 ton outside unit, i cant get the compressor to start even with replacing the start capacitor and using a super start on the compressor side of the capacitor? normally i wouldnt have a...
check to make sure you have 220 on both sides of contactors, double check wiring at capacitor. you can also check continuity between all three post at compressor , make sure power is off and wires are disconected, if you do not get continuity between all three u have an open winding in compressor, could be the over load if the compressor is hot. Did you take an amp draw at compressor? check the LRA (lock rotor amp) of compressor.
Apr 08, 2010 | Goodman CLQ36AR49 Air Conditioner
On the unit model/serial# tag there is three terms.what do they mean,compressor lra/rla and fan fla
Compressor LRA ( locked rotor amps)meaning that if you hold that rotor and do not allow it to turn, it would draw that many amps.
Compressor RLA (rated load amps) meaning the amps the compressor will draw at a certain outdoor temperature usssually 95°.
Fan FLA (Full load amps) meaning that's the maximum amps the motor will run at continuosly.
Feb 07, 2010 | Carrier Heating & Cooling
Refrigerator Compressor hot to touch & fridge/freezer not cooling
Nov 04, 2008 | Kenmore 53542 / 53544 Side by Side...
Fan is working on fridge, temperature is set correctly but fridge not cooling. the compressor boiling hot.
is the compressor fan working and the freezer fan working also? if you have a meter you can do a amp draw on the comp.,it sounds like the comp. being so hot your coils under the frig. are real dirty or the comp is about to lra out(burn out) let me know more-mike
Oct 21, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
