Question about Dometic RM2852 Refrigerator
Door reversal directions for dometic RM2852
Need the instructions for door swing reversal on my new dometic DM2852 fridge
    Top Expert:
  • Dometic Master
  • 5,061 Answers
Switch handles and hinges
Posted on Jun 18, 2016
SOURCE: dometic rm2852 does not run on gas
So, the solution was simple but not obvious: the heat probe and the igniter are one and the same item, and all we had to do was bend the probe/igniter closer to the burner. After we did that the refrigerator started to behave properly.
Oddly enough, the repair manual for the refrigerator shows a igniter with a heat probe above it: the is not how the refrigerator is built.
Posted on Mar 24, 2009
  • 4 Answers
SOURCE: i replaced the cooling unit
Check the 12V supply, and if recall kit is installed, check the limit and thermal fuse.
Posted on Aug 23, 2009
projdoc
  • 2237 Answers
SOURCE: my dometic refrigerator rm2852 is freezing up.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 27, 2009
  • 332 Answers
SOURCE: Have dometic fridge in rv.......new in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
Posted on Mar 08, 2010
motor1258
  • 6674 Answers
SOURCE: my dometic fridge will not turn on
Check to see if you have a switch for storage, on, off etc. usually between doors, or near top right corner of fridge compartment. It may be in wrong position.
Posted on Jun 03, 2010
How do you reverse the door
If its a side by side like the one showing on your post, I doubt you can unless there is a spot showing for under the door, and the water and electrical lines are long enough to switch.
Mar 28, 2016 | Refrigerators
What do I check to fix my Dometic Americana refrigerator. It won't start using electric or gas.
Fist off before you get crazy replacing things make sure the camper is level when testing this. Gas will not run to it if you are not level. Also make sure the gas is turned on and make sure you have selected automatic or gas only on your fridge. Also give it about an hour before you test the temp. These take a bit longer to start feeling cool. If all of that does not work you will need to check the refrigerant, igniter(for the gas side) and the compressor. Also make sure the fuses are good to go at the main panel and that the breakers are in the "on" position
Sep 11, 2014 | Dometic DM2852 Americana Fridge...
Why dose my freezer get cold but not in the frig on gas or 115 volt ?
It has possibly started to leak. On all models that were manufactured after 1999 it is most common for them to leak just above the burner area. It can be accessed from the rear vent of the refrigerator. One the vent is removed look to the far right just below the ductwork. If you can see a yellow residue, it has for sure began to leak and will not last much longer. Please visit the Store link below to get a New replacement cooling unit for your refrigerator with a Lifetime warranty. Store There is also a video below of how to change a cooling unit.
Jul 29, 2014 | Dometic DM2852 Americana Fridge...
Why does My dm2852 works on electric, but not gas. It lights (small flame), but doesn't cool.
It is more than likely just a dirty orfice. It can be cleaned quite easily by soaking it in rubbing alcohol then blowing it out. Do NOT POKE ANYTHING THROUGH IT! 946177a3-e85b-4832-879e-b23434d529ef.jpg ArctiCold Refrigeration We keep it cold
Jul 22, 2014 | Dometic DM2852 Americana Fridge...
Dometic dm2852 freezing food in frudge
If the freezer is set to very cold, the fridge temp will drop as well, only set it as cold as you need it.
May 18, 2014 | Refrigerators
Fourwinds hurricane rv
We are Arcticold refrigeration, we manufacture brand new replacement cooling units for Dometic & Norcold RV fridges. Our cooling units all come standard with install instruction, installation hardware, and a lifetime warranty. Feel free to give us a call to free 1-888-782-6665 I can send you the install instructions by email if you would like to take a look at them. In most cases it takes approximately 2 hours to change the cooling unit. I will also need the model number of Refrigerator you have. Visit ArctiCold Refrigeration We keep it cold for some info. Below is a example of one model of cooling unit we build. It is a Dometic RM2852 shown in the picture. 39ede16a-9d21-4648-ad1c-33f0d0c45ff3.jpg 599bd524-a61c-4c24-afa2-1a1a9c84d92c.jpg
Mar 02, 2014 | Dometic Refrigerators
Rm2862 willnot comeon at all,frot panel does come on , no blown fuse Lp turns on the heather but unit will not cool
If you fridge is level, and the rear coils of the cooling unit are warm then you more then likely need a replacement cooling unit. If you do, we can help. We are Arcticold Refrigeration. We specialize in the manufacturing of New Replacement Cooling Units for Dometic & Norcold RV Fridges. Our cooling units are direct replacements of the factory units. In most cases the cooling units can be changed in a couple of hours. Arcticold cooling units come standard with new installation hardware, installation instructions, and a lifetime warranty. We also offer 7 day a week free tech support 1-888-782-6665 Our cooling units are available throughout North America. Don't hesitate to give us a call or visit our web site. ArctiCold Refrigeration We keep it cold f926e66c-02f3-4d45-9004-f68d1864e268.jpg
Dec 26, 2013 | Dometic RM2852 Refrigerator
How do I remove ge GBS20KBPACC handle for reverse door swing
You just grab the handle with both hands and pull/lift up like your trying to lift the fridge wirh the handle. It should disengage and then pull off.
Mar 30, 2012 | GE Refrigerators
Dometic RM2852 Refrigerator Logo
90 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
