Question about Acer AL1914 19" LCD Monitor
Troubleshooting screen is shifted to the left how do I center if
    Problem Solver:
  • 9 Answers
There is a setting on the computer screen, it will say vertical and horizontal shift, There is buttons on the monitor to get to the menu to get to screen shift settings.
Posted on Mar 07, 2015
Vertical black bar on my LG 47" LCD shifting the image to the right
Two possibilities are there. The first one is, with loose LVDS cable, that connects the T'Con board to display panel. The second is the fault with its main digital processor board.
May 21, 2013 | LG 47LC7DF 47 in. LCD HDTV
The screen has shifted to the right so that i cant see the [X]on any windows. Ive already maxed out the left shift but its still stuck to the right.
does the screen appear distorted;does it move as you shift left/right/up/down? IF THIS IS TRUE, YOU PROBABLYHAVE THE RESOLUTION SET WRONG....RIGHT CLICK ANYWHERE ON THE SCREEN;PROPERTIES;SETTINGS; ADJUST SLIDEBAR TO PROPER RESOLUTION FOR YOUR MONITOR
Mar 07, 2010 | AOC 2216Vw 21 inch LCD Monitor
There is a black 2 1/2inch bar on leftside of screen how do i adjust is?
if your lucky it's just your H-center is off tilt. to check this Press the menu button on your monitor. scroll through the options till you see Horizontal-center option. select this setting and move the screen to the left. The entire screen should start shifting to the left and fill in the screen. now if you do this and you get a black bar on the right. Center the screen where you have the same amount of black on both sides of the screen. scroll through your menu till you see the H-size. increasing this will fill in the black area. Hope this helps.
Sep 13, 2009 | X2Gen MG19MY 19" LCD Monitor
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Screen has a vertical black band on right hand side
You might have a centering control among the options of your monitor. Look up the manual, or just play with the buttons until you find it.
Apr 07, 2017 | Nu Mark Computers & Internet
Horizontal view on screen will not re-center
You want to locate Position or Horiz Position from the Menu screen. Press menu first then Up or Down to select the item you want then Left or Right, I can't be more specific as all monitors are different - but there isn't a single button to center. You could also try the different input settings (Analog, Digital, etc) if the Autoselect isn't working properly.
Dec 12, 2008 | Computers & Internet
Screen shift
Try setting the refresh rate to 60 Hz. (Maybe 75).
Is it xp?
Right click an empty part of the screen, properties, under monitor (I think; I'm on Vista) you can choose the refresh rate.
Most LCD's should be at 60 Hz.
Jul 04, 2008 | Envision EN9410 19" Flat Panel LCD Monitor
Philips 32pt television screen format off center, to the left
For me it was the cable box settings...
I'm not a tech person, so take this for what its worth. I had the same problem with my Vizio and my Time Warner Cable HD/DVR box using the HDMI cord connection. HD channels were always fine, and non HD channels were fine until I went to an HD channel and back. When switching back, the non-HD channels would be shifted to the left as you describe. After much back and forth with both Vizio and Time Warner (each saying its caused by the other), I stumbled across the following fix...
I went into the cable box (scientific atlanta 8300) "settings", under "display," under "output resolution." There was a list including 480i, 480p, 720p, 1080i, and "auto select." I unchecked both 480 options and left 720 and 1080 checked. Problem solved. The other "Display" menu settings are as follows: Picture Size = Stretch, Aspect Ratio = 16x9.
Hope this helps.
Mar 27, 2008 | InFocus SC-MANGRY-106H MANUAL PULL DOWN
Help
On Philips LCD and Plasma TV's you can center the picture left and right and also vertically. Use the round joystick in the center of the remote to see of you can shift the image to the left.
Dec 01, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Acer AL1914 19" LCD Monitor Logo
163 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
