Question about Asko Washing Machines
Asko w6022 washer
The washer won't start. the lights around the program button keeps flashing around white, color, perm press, etc. When I press start, nothing happens. My clothes were stuck earlier and I pulled the red ring to get my clothes out and found 3 quarters in the drain. took them out and still won't start.
SOURCE: Whirlpool Duet won't run
Ok... so I had the problem, tried a couple of things... nada. So I stared at it and thought for a minute and looked at all the buttons. I looked a the button to the way right that said something like hold down for 3 seconds. I did it and all of a suuden it worked. I hope this helps you guys out.
Posted on Mar 03, 2008
SOURCE: indestit widl126 flashing lights fault
was faulty heater
Posted on Mar 04, 2008
  • 351 Answers
SOURCE: Asko w6021 washer not working
replace the carbon brushs in the motor,they will be worn out part no 8801195,round motor.or 8801097 square motor.
Posted on Mar 23, 2008
SOURCE: Hoover Nextra HNWF 3137 washer/dryer
I have the same problem exactly please send me the solution with confirmation of the exact part requested my machine is HOOVER HNL3137 1300rpm/7kg thanks
Posted on Jun 02, 2008
SOURCE: flashing time lights...pressed cxl button...not working
Flashed f ...time light flash...pump starts to work...doesn't spin...doesn't cycle...
Posted on Oct 16, 2008
My Asko W6022 quattro 1200 rpm is giving me trouble. The delicate cycle doesn't work and just soaks the clothes. Please help.
may have defective timer (burned points at the delicate cycle mode) can but may be difficult take timer apart and sand paper clean the point contacts on timer DONT IT BEFORE BUT NOT EASY
Dec 16, 2014 | Asko Washing Machines
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
Asko w6022 flooding root cause
Yes that can cause a flood.
Sep 19, 2017 | Washing Machines
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The machine automatically starts at 3h 20m (the length of time for white bread) but when I press 'reset' to bring time up to 4h 28m (required for whole wheat), it won't start mixing until I...
If you have a B. Crocker bcf1690 machine you need to just plug it in and it will always default to the regular bread program. To change it to whole wheat you need to press the Menu button until the whole wheat program shows on the display ( #3) according to my manual if you go past it just keep pushing the menu button until it comes back around again to #3. then just push the start button.
Jul 12, 2011 | Betty Crocker BCF1690 Bread Maker
Asko D1996 lights flashing washer won't start
I'm having the same issues. What did you do to solve yours? My start button never lights up! Thanks for your help!
Oct 01, 2009 | Asko D1776 Stainless Steel Built-in...
Asko WCAM1812 Front Load All-in-One Washer / Dryer It does not start the lights are blinking on spin. the door remains unlocked
hold down the "cycle signal" button for 3-5 sec. unplug and plug back in. should clear and reset computer
Aug 08, 2009 | Asko WCAM1812 Front Load Washer / Dryer
Open Questions:
Washing Machines Logo
125 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
