Question about Refrigerators
Simpson 220 Fridge Freezer Manual - Refrigerators
2 Suggested Answers
woodchuck789
  • 4059 Answers
SOURCE: My Simpson BJ415BG fridge/ freezer
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
Posted on Jul 28, 2011
Where is the thermostat located on the Hotpoint fridge/freezer RSAV21
Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer
? 3:27
www.youtube.com/watch?v=YPglk963cXM
Sep 7, 2012 - Uploaded by Ezee-Fix Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer. Ezee-Fix .... Refrigerator Repair- Replacing ...Missing: rsav21
Free Hotpoint Refrigerator User Manuals ' ManualsOnline.com
kitchen.manualsonline.com > ... > Hotpoint > Kitchen Appliance Hotpoin
Products 1 - 50 of 299 - Hotpoint Top-Freezer Refrigerators Owner's Manual and Installation Instructions 18, 19 .... Hotpoint BL31 Larder Fridge Instructions for Use.
Oct 29, 2015 | Heating & Cooling
Converting 220v to 110v
No, I'm sorry, but this is not possible. But remember that 220 vac is just two legs of 120vac cycled 60 degrees apart. So 220 may be available there. Talk to the local electricians--you may only need a new plug and recepticle installed, or it may take extra wiring, depending on the buildings wiring and local codes.
Mar 27, 2014 | Freezers
Fridge not getting cold...but freezer is working
the fridge gets its cold air from the freezer fan blowing it through small air passages between the freezer and fridge. when you adjust the temperature in the fridge you are increasing/decreasing the amount of air being let into the fridge. Two common problems that could cause the freezer to freeze but not the fridge getting cool is the freezer coil is frooze like a ice cube blocking the air going to the fridge or freezer fan is not working could be bad or froze up due to too much ice. If fan works after manually defrosting problem could be in the auto defrost mechanism. If fan don't work after manual defrost replace fan. Manual defrost by putting a pot of very hot water in freezer with door closed change water foten until defrosted.
Jan 02, 2012 | Westinghouse Avalon Refrigerators
Do you have instruction manuals? I have a 6WRI24NG and it seems to be dripping water from under the freezer bit into the fridge, and everything in the fridge are is freezing.
The problem seems to be with the condenser. the freezer is leaking because of the breakage of temperature between freezer and the fridge. I will update you soon.
I have not found an online manual yet for free. But we could find the free manual from the company's website.
Jun 27, 2011 | Whirlpool Refrigerators
Simpson fridge stopped working. The freezer still goes but not the fridge part. At the time the power fuse box overloaded (around the same time as the fridge died). Not sure if that was connected but power...
If this is a standard upright fridge (freezer at top), then the usual principle applies: cold air drops.
A small fan (situated between freezer & fridge) should be functioning, which forces cold air from the freezer, down into the refridgerator.
I would recommend you first determine if this small fan is operating (this is the noise you would normally hear, when you open the freezer door) and if not, then replace the fan.
If fan is working, then I would suspect a faulty thermister which would require a technician.
With repairs of older devices, it's always best to obtain quotes first, as often the cost of repair could well amount to up to 40% of the price of a new one.
Good luck...
Feb 14, 2010 | Refrigerators
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Feb 08, 2010 | Refrigerators
No matter what temp setting I adjust my fridge to it freezes up within hours. I now have a giant freezer. Where do you think the problem lies. I want my fridge back. It is a Kevinator Impression Series...
In spite of keeping the temperature regulator 'Low' mode if it freezes up so fast, that means there is a problem in the freez pipe from where the cool air is coming into the freezer. Please check on that. Make sure, that u defrost it once in a week.
thanks,
saumya.
Jul 13, 2009 | Frigidaire FRT15G4B Top Freezer...
Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Mar 22, 2009 | Bosch Freezers
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
