Question about Canon imageRUNNER 1630 Copier
Ir2230 error code e000010-0002 - Canon imageRUNNER 1630 Copier
How do are clear these error code E000002-0000 from my canon IR2230
Reset in service mode COPIER<FUNCTION<CLEAR<ERR.Replace main thermistor or DC controller PCB
Apr 27, 2015 | Canon IR 2230 COPIER FOR 220 VOLTS ONLY
Error E000024-0001 on Canon iR 2870 Photocopier
that error is related with the toner sensor located in the developing unit. clean the connector or replace that sensor
Feb 17, 2015 | Canon Office Equipment & Supplies
Photocopy IR2230 error code 0001/0002
First clear that error from service mode. Press additional function
press 2 and 8 together
press additional function agian
service mode should appear in screen
select copier
select function
select "clear"
select "err"
select ok.
unplug power cord for a few seconds and restart the machine
try to make some copies if problem persist replace the fixing heater assembly
Jun 02, 2014 | Canon imageRUNNER 2200
Error e00051-000
You will have to check with Operating system MFG or device MFG depending on who"s error code it is but it looks like a Windows error code if so do a search at microsoft web site with code number. Hopefully that will get you in right direction of whats wrong with server. If in a network setting check with administrator.
Apr 15, 2014 | Canon (6981A002AA) for imagerunner 2200,...
My IR2230 displays E000110-0001, i have replaced the laser unit but the error code still comes. Pls help- Sam.
the only thing that remains for you, that you can check/replace/reconnect is DC controller.
Hope that helps!
Jun 10, 2011 | Canon imageRUNNER 1630 Copier
Hi, How do I remove the optional hard drive on a Canon IR2230 without the machine generating a code E602-0411
The Hard Drive is not a option..... You need it to use the copier..... The operations of the copier are on the hard drive, it is like the hd on your computer. The error code you are getting is telling you that the hd is not working...
Nov 23, 2010 | Canon IMAGERUNNER 2230 Copier
Canon IR2230 is givng an error E000732-0001 and is saying to shutdonw and restart the Printer. Pls help
There is an error in the communication with the scanner.
0001 There is a DDI-S communication .CHECK THE COMMUNCATION CABLE
Mar 08, 2010 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER 1630 Copier Logo
114 people viewed this question
old marine
old marine
