Carrier 38ckc03640 information on tons
Model 38txa060320 carrier how many seers and tons
There is a data plate on the outside of the cabinet that has that information. You can also get it from Carrier's website.
Jul 24, 2016 | Carrier Heating & Cooling
How many tons is this Carrier unit? Model #38AH-034---610AA Serial #OBO1F65263
This is a 30 Ton Hi Efficiency Gemini series unit from carrier you can matched to either of these air handlers.
40RM028 40RM034
Model is broken down in sections
38AH = carrier Gemini series units from 20 to 120 tons the numbers following the dash represent the size 024 = 20 028 = 25 034 =30 044 = 40 054 =50 the list goes on in increments of 10 untill it reaches 130 tons 134=130
Hope this helps
Best of Luck
Jun 01, 2011 | Carrier Heating & Cooling
Hi there I have a model number for my carrier a/c unit. I need to find out the tonnage. 38ykc042300 Please any help I will be very greatful.
This is a 3 and 1/2 ton unit.
The 042 in the model number is the tonnage of your carrier unit.
AC tonnage is based on 12,000 btu per ton.
12,000.....1 ton
18,000.....1 and 1/2 ton
24,000.....2 ton
30,000.....2 and 1/2 ton
36,000.....3 ton
42,000.....3 and 1/2 ton
48,000.....4 ton
60,000.....5 ton.
There is no 4 and 1/2 ton unit.
Apr 09, 2011 | Heating & Cooling
What tonnage is my new Carrier A/C model # 24ABC642A300 and how many sears is it?
The AC unit you inquired about is 3.5 ton unit. With a 10 seer rating.
Hope this information helps.
Mar 01, 2011 | Carrier 38CKC042 Air Conditioner
Hi i need to know the ton of the unit
TYou can find that information on the steel plate on the back of the unit, if it's a heat pump you will find it on the sied where tubing comes out of heat pump. It will have serial Number and model number and you can take that information and go to Carrier and find thw tonage list.
Aug 31, 2009 | Carrier Heating & Cooling
Tonnage of unit
Listed at Carrier at 2,330 Kilos so math says 2,330 X 2.2 = 5,126 lbs or about 2.5 tons though they listed it as a 3.5 ton max back when they sold this model.
May 12, 2009 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
