686 amibios n2003
To starting only the ventilator turns, nothing is posted with the screen and there is no sound beep.I thought of a breakdown of the case of food but even after having changed them, the breakdown always persists
holborn
  • 17 Answers
SOURCE: sytem wont post
remove the rct battery and try again power on again.
Also look for and replace bad cappacitors. If nothing works, you need a new momo!.317cfa4.jpg
Posted on Feb 12, 2008
map9966
  • 2351 Answers
SOURCE: 915PL-A2: no post, no beep, no keyboard lights
You may have a short between the board & the case. (check it).
Even if this means removing the board. That clicking you hear through the speakers suggest a short. Make sure your using (Stand offs) which keeps your board off the case's mounting surface. Check the back plate so the tabs are touching the ports comming off the board for good ground.
Double check the you have fully connected both the main power ATX_ 20 pin power connector & the auxiliary 4-pin power
connector. pg. 10. Connecting 20/24-pin power cable Remove & re-seat. If your PSU has a 20 pin connector make sure you connect the cable from the correct end.
Without POST you will not get video to load. Reset your bios
pg. 9 in your manual. Re-enter your bios and setup the bios settings for your board.
Let me know if this helps you reach POST?
Posted on Mar 14, 2008
iqbal_del
  • 652 Answers
SOURCE: GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
no beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
Posted on May 14, 2008
  • 9 Answers
SOURCE: hp computer beeps and blank screen what cud be the
Check to make sure the new memory and processor is seated in the slot correctly. If either is not inserted fully it will cause the PC to beep and blank screen as your is doing. If that doesn't fix it your memory could be the wrong type or to large for the PC to recognize. JQ
Posted on Jun 09, 2009
bronk50
  • 27725 Answers
SOURCE: I have a selfbuilt Syntax MB computer. No beep on start up Screen black
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Hope this helps.
Posted on Dec 10, 2012
Need wiring diagram for Amibios 686 ZL15 1317 Motherboard.
The manufacturer will have this information in PDF form most the time and keep this information for a number of years. Assuming you're looking for the pin outs for the motherboards power button, HDD light, and other indicator lights and functions. Also - If you look real close to the sides of the pins, you'll see indicators to show where everything goes. Hope this helps.
Nov 11, 2016 | Computers & Internet
686 amibios 1999
You could add a new NIC to the computer which is cheaper ($10), as long as you have the ability to add. You could also get a USB ethernet adapter. Have you tried to update the drivers and firmware of the NIC?
Nov 26, 2013 | Dell Ethernet Card Network Adapter
On startup there is 4 beeps then 2 then nothing. The laptop belongs to my grandouther.the power coard was frade,so my guess is that's where the problem started.
Beep codes are used by the BIOS during the POST to report certain initial system errors.
If you're hearing beep codes after you turn your computer on, it typically means that the system has encountered some kind of problem before it was able to display any kind of error information on the monitor.
Follow the steps below to determine what system problem the beep code is representing.
Difficulty: Average Time Required: Anywhere from 10 minutes to a few hours depending on the cause of the beep code Here's How:
  1. Power on the computer or restart it if it's already on.
  2. Listen very carefully to the beep codes that sound when the computer begins to boot.
    Restart your computer if you need to hear the beeping again. You're not likely to make whatever problem you have worse by restarting a few times.
  3. Write down, in whatever way makes sense to you, how the beeps sound.
    Important: Pay close attention to the number of beeps, if the beeps are long or short and if the beeping repeats or not. There is a big difference between a "beep-beep-beep" beep code and a "beep-beep" beep code.
    This is all important information that will help determine what issue the beep codes are representing.
  4. What steps you take to solve a particular beep code will differ depending on the BIOS manufacturer.
    Choose the correct beep code troubleshooting guide below based on your motherboard's BIOS manufacturer:
    Tip: Not sure what brand of BIOS is on your motherboard? See this How to Determine Your Motherboard BIOS Manufacturer guide for some helpful advice.
Aug 07, 2011 | Everex StepNote® VA4103M PC Notebook
I installed two 1G memory cards in my dell GX270 Optiplex and cannot start my computer! I am getting six beeps and nothing happens?!
  1. What steps you take to solve a particular beep code will differ depending on the BIOS manufacturer.
    Choose the correct beep code troubleshooting guide below based on yourmotherboard's BIOS manufacturer:
Aug 06, 2010 | Dell Computers & Internet
Screen won't appear upon start up and I get 3 beeps but no screen
3 beeps POST code (power on self test) means RAM problem.
Reseat the RAM module/s and boot up your computer.
If you have two RAM modules, remove them both and insert one at a time to test them, to determine which module is faulty.
If it still doesn't work then replace the RAM module/s
Apr 02, 2009 | Everex StepNote NC1500 Notebook
A driver that won't install
alberts18,
Here is the issue, ECS doesn't list a M925 solely board so please look at this link and verify what you have for me ..
Dec 11, 2008 | Computers & Internet
Iqbal
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Pc won't display but it switch on
8short Display memory read/write error The system video adapter is missing or defective
1 if it is an AGP card could be the slot for it is defective
2 Disable the onboard video chip in the bios try it again
3 If you have an old PCI videocard try that
4 if ou have 2 slots of ram chips try without one in then take it out and try the other
Feb 25, 2008 | EliteGroup P4VMM2 Motherboard
Beep sounds and their meaning
Hi All PC do what is called a POST a Power On Self Test and emit different beeps according to the make and model of the BIOS loaded. You can check out what they mean for different BIOSes here http://www.xmission.com/~comphope/beep.htm. This site lists the different post codes etc by the different bioses. So you will need to know what BIOS your PC is running just check the black screen at starup before any windows info comes up and look for something like AMIBIOS or AWARD etc, you can pause the screen so that you can read it more easily by pressing the pause button on your keyboard, this is normally the last key on the top row on the right. Hope that helps
Sep 04, 2006 | MSI 915P Neo2 Platinum Motherboard
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
