Question about Aluratek 15" Digital Photo Frame - ADMPF315F
Aluatek admpf415f unit turns on screens says loading then shuts down. I have to unplug the unit to get it to turn on then it does the same thing
The receiver after turning off will turn it self back on, repeatedly.
The unit is drawing too much power and is being protected by a current/temp sensitive device that shuts down to protect unit. When it cools, the power is restored until it heats up again, and the cycle continues.
Sounds like something in the power supply area is the cause of the anomaly.
Mar 21, 2015 | Audio Players & Recorders
HP Photosmart PremiumC 309g-m started a day ago will not print anything even test page. Message says load paper into photo tray. Nothing obvious seems to work, shutting down printer and restarting,...
Unplug the power from the printer.
Press the # key and the 6 at the same time and hold them down
connect the power while continuing to hold down these keys
wait for a message about a semi-nvm reset or something like that to appear on the screen, and then release the buttons. If the unit shuts down while you are pressing the buttons, release them, and press power just long enough to turn the unit on.
If the printer does not react normally after this, post a reply here.
Feb 24, 2011 | HP Photosmart Premium C309A All-In-One...
Emachines w2828 keeps shutting down reboot/Screen Freeze
I dont thing this is a virus problem but a heat problem. if you dont mind getting inside the box see how clean it is and put your hand on the power box case .. then unplug all the hardware except the mother board then turn the unit on, if it goes on then plug 1 hardware at a time.
Sep 04, 2009 | E-Machines eMachines Desktop PC
Projector turns on the power light flashing and lamp light solid
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Jun 12, 2009 | HP Digital Projector Vp6120 Multimedia...
My e250 will not turn off & will not turn on-Screen is gray w/vert. lines in it
You need to remove the battery and let the system power down completely. I have had this problem and the others I have seen on this site. Removing and reinstalling the battery solves many problems. Just letting the battery drain is not good for it and may take a really long time.
Sep 28, 2008 | SanDisk Sansa e250 MP3 Player
Power is on but screen is black
I found this [temporary] solution at http://www.wiierror.com/wii-black-screen.php:
(via email, thanks Steven) This happened to me once, but I fixed it. Here is how:
Eject the disk
Unplug the wii at the back
Wait 1 minute
Plug it back in
Turn it on from the remote
Press reset if it does not show up
Hold the power button to shut it off
Turn it on once more.
I don't know how, but it seemed to work for me. The problem happened when I was trying to load the Mii channel. Hope this helps !
(via email, thanks Andrew)
The first time I shut down my Wii, the light went orange (as it should). When I turned on the power with my wii remote the next day, the wii\'s light turned green but the screen was black.
The treatment was the same as from Black Screen, No Connection: Unplug the Wii\'s power supply unit, then replug; turn system on with wii remote.
The difference is: this problem can strike in more places than just by loading the Mii Channel. Also, I think the green light being on (yet there being a black screen) is a common symptom as well.
May 18, 2008 | Nintendo Wii Console
AV 50D501 JVC projection T.V.
sounds like a bad connection in the deflection circuit. you need a repair tech
Dec 16, 2007 | JVC AV-56WP30 56" Rear Projection...
Change the lamp/ didnt help, lamp indicator is on
I actually fixed this myself!!!! Same thing, new bulb, fans work, turn on for first 20 seconds or so, see HP splash screen and then it shuts down. Try below....It worked for me.
Try it!
Jack-
Nov 12, 2007 | HP Digital Projector Vp6120 Multimedia...
Blue screen of death
What you Have Is a Main RCA Failure you Have a Cathode to Grid Short In your Picture Tube,The Tube shorts and Tells the Miainboard to shut Down...Good Luck
Jul 13, 2007 | RCA TruFlat 27F520T 27" TV
Aluratek 15" Digital Photo Frame - ADMPF315F Logo
Top Aluratek Video Cameras Experts
Are you an Aluratek Video Camera Expert? Answer questions, earn points and help others
