Lg front load washer manual WM3875H*CA, PG. 18
Need pg. 17, Cycle guide
SOURCE: LG WM2688H Front Load Washer
I do not have a solution, but have the same exact problem and would like to know if you ever found out where the thermistor is and if you were able to fix it.
Thank you,
Treegirl
Posted on Oct 29, 2007
SOURCE: lg wm0532hw front load washer
LG wm0532hw, can not turn on washer, it's not the plug, i try to reset it by unplug for 2min then plug it back. help
Posted on Jan 08, 2008
  • 210 Answers
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Posted on Jun 03, 2008
  • 489 Answers
SOURCE: lg wm1832cw front load washer
One of 2 things may be causing the loud noise.  Either the rear bearing on the drum has failed and will need to be replaced (very expensive) or the drain pump has a bearing problem and is making a very loud noise when it is draining (not too expensive).  Either way, you will need a qualified LG technician to diagnose and repair the problem.
Posted on Jun 26, 2008
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
Need valve specification on 86 chevy nova
from my 1985/1986 official shop manual:
figure 6A1-39 valve stem and guide clearance
max intake clearance 0.08 mm (0.0031 in)
max exhaust clearance 0.10 mm (0.0039 in)
pg 6A1-17 If clearance is greater than the values given in 6A1-39, then replace the valve and guide
pg 6A1-17
standard overall length
intake 106.88 mm (4.2079 in)
exhaust 106/78 mm (4.2039 in)
do not grind more than 0.5 mm (0.020 in)
Mar 11, 2015 | 1986 Chevrolet Nova
Lg wm3875h*ca water keeps coming in after it is shut off/ It takes about 4 days after I have washed before the water starts coming in. I checked the filters in the washing machine and changed out the...
If it is doing it with absolutely no power to the machine i.e. unplugged, then it still has to be a water valve letting water in and not closed/seated correctly. If it only happens when there is power supplied to the washer then it is likely to be the control board not feeding the correct voltage to whichever valve it is (turn either the hot or cold off at the tap/fawcet to determine which it is).
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 04, 2011 | LG WM3875H Washer
After loading blueray movie on a blueray disc player clicking on play mode shows prohibited
Check ur movie Rating like PG,PG 13, R,NT 17 on the Blu ray player.Check might have children lock passwords require on it?
Oct 23, 2010 | LG Televison & Video
How do I set the channels?
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf You will find programming instructions beginning on pg 17.
Best regards.
Oct 21, 2010 | Motorola T6510 XLR Talkabout Two-Way...
Gives message...oe
On pg 18 of the service manual for this combo, front-load LG washer/dryer, it basically says if the drain's not working and you see an OE error code, clean the drain pump filter and retry. So first do that.
http://www.retrevo.com/support/LG-WM2277H-Washers-manual/id/438ag213/t/2/
Manual above.Below is a great DIY self help washer site, use with manual to sort your problem out.
http://www.washerhelp.co.uk/diy-repair-help.html
Jun 18, 2010 | LG WM-2277HW Front Load Washer
On board sound
Hi nrls14, it can get pretty confusing with Gigabyte.
Go to page 9 in your manual or Pg 13 if using Adobe Reader. Motherboard layout. If you download the manual which is in pdf format you'll be able to enlarge the manual which will help you to see everything much better.
Download manual from here: http://china.giga-byte.com/FileList/Manual/motherboard_manual_7n400pro2_e.pdf
This is the English manual. (Downloading from china is a faster site).
Find SUR_CEN located between PCI slots 2 & 3 on the motherboard. Than go to pg 32 in manual or pg 36 in pdf. Set the pins SUR_CEN. Set a jumper over pins 1&2 & 5&6.
Front Audio Connector, leave a jumper across pin 5&6 & 9&10 (Default). On page 22 in manual, pg 26 pdf. Follow Method1:
Instructions. (Test your speaker system). You may need some tweaking & this can be done with the software included on the Gigabyte CD by installing the sound effects manager. Go to page 78 in your manual or pg 82 in pdf. Page 80 in manual, pg 84 in pdf. For six channel 5.1 sound. If you decide to use the Advanced 6 Channel Analog Audio Output Mode (using Audio Combo Kit, Optional Device). Follow the instructions on page 81 in manual or pg 85 in pdf. (Do not let the picture on pg 81 spook you). Pg 81 shows a set of pins not located in-between the two PCI slots. You make this connection by removing the two jumpers on SUR_CEN & plug in the SURROUND-KIT on to SUR_CEN pins. Lastly, both motherboard manuals are the same for the GA-7N400 & the GA-7N400 Pro.
Good luck nrls14!
Mike
Aug 25, 2008 | Gigabyte GA-7N400 Pro Motherboard
Kenmore Dishwasher 665.15891792
It's unfortunate that this question has been posted since Nov. 18, 2007, but this is a non-problem.  If any curiosity (still) exists, the dishwasher is (or was) in its "Control Lock" mode -- provided as a safety measure to prevent injury to small children, etc.  This mode is exited, or entered, in the same way -- by holding the "No Heat Dry" button (or pad) for 4 seconds.  I hope a new dishwasher wasn't purchased because of this, as it's explained in the operator's manual (the "Use & Care Guide" pg. 16).
Nov 18, 2007 | Dishwashers
Washing Machines Logo
Top Washing Machines Experts
