HP Photosmart 3310 Printer
Problem for HP Photosmart 3310 Printer
Black ink does not print
By ekklesia on Aug 27, 2007
first issue was printer not printing at all but there were no error messages. I did all the suggested routine things from HP including reloading software, maintenance checks, printing self-test pages, cleaning contacts etc I have put new ink cartridges in place
It will print a document if it is in colour but will not print it in black.
Clarification Request
Posted by Duplex74 on Mar 29, 2008
Hello, by pressing "Cancel" + "OK", you go print two pages: "Extended Self Test Diagnosis Pages." The data are printed very clear but it can happen to read. What can you read in "Revision information?
Same Problem
May 12, 2009
-   cannot print in black, color is fine-   Guest
Mar 25, 2009
-   Same problem. No Black . Tried all HP suggestions- clean, intermediate clean, align. diag. report, machine re-set and repeated process with new cartridge without success. HP tech. support acknowledge problem occurs but3310 no longer supported. Their suggestion "trusted printer service provder or replace printer".
Will I buy another HP - NOT B..... Likely!
About to try strip & clean as suggested in solutions.-   jocov
Mar 19, 2009
-   same boat as everyone else black not printing
any solutions out there??-   Guest
Mar 14, 2009
-   yes , Ihave the same problem . Also wont print from my computor ( from word ) will print a email but not a attacthment.-   bigdadda
Feb 10, 2009
-   no black color-   Guest
Best Solution
posted on Jun 03, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
This is quite a common problem for these models, particulary with the black not printing, to check if this is your issue print a self test page, then try a cleaning process through the tools menu if you are still not getting any black print you have the classic blocked nozzle/ airlocked printhead issue, it is most commonly seen in printers that have used aftermarket black ink at some stage and/or have been sitting unused for a while.
try the following
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartiges in the printer so that it can reset.
if this doesn't work the only way to clear it is to disassemble it and soak the bottom of the printhead in hot water then reassemble and clean the head
good luck
PS it only seems to be a problem with black refilled/aftermarket cartridges, haven't seen any probs with any of the colour refills
Solution #2
posted on Mar 29, 2008
Somewhat Helpful)
Duplex74
Rank: Apprentice
Rating: 70%, 1 votes
This would usually be caused by a bad carriage board, or the cartridge contacts not making proper contact with the contacts on the carriage board.
Comments:
Mar 29, 2008
- http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00033152&lc=en&cc=au&dlc=en&product=79499&rule=44123
Was this helpful?
Yes
No
Solution #3
posted on Aug 27, 2007
Somewhat Helpful)
jackboy
Rank: Wiz  HP Expert
Rating: 77%, 4374 votes
I dont know about your particular model
But some printer do not print black on its own but rely on all colours to 'make'black.
Black itself is a sort of fill in .
Does your printer software give you the option to print 'Black' only?
Was this helpful?
Yes
No
Solution #4
posted on Jun 03, 2009
Very Helpful)
Ben Tilitert
Rank: Apprentice
Rating: 100%, 1 votes
If all else fails try this, get a syringe minus the needle, remove the ink cartridge and use the syringe to blow air GENTLY through the hole the cartridge connects to. Make sure you have a cleaning cloth to remove ink dislodged from pipe connected at the print head, do this gently to remove any obstruction and there should not be too much mess and can easily be cleaned up. I did this for my work printer which was out of warranty and it worked a treat.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Mar 05, 2009
Very Helpful)
lambchop99
Rank: Apprentice
I've not been able to get the black ink to print on my HP 3310 for the past 2 weeks after trying everything but followed advice on the following:
http://www.fixyourownprinter.com/forums/inkjet/55519#8
and it's slowly working!
It involves doing a semi-full reset:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01449119&lc=en&dlc=en&cc=uk&lang=en&rule=30780&product=439491
I've done it 5 times now and each time I do it the ink comes back a bit more and it's nearly back to normal now! I'm also doing a 'clean printhead' after everytime (setup then tools)
Don't give up!
Was this helpful?
Yes
No
Solution #6
posted on Jan 11, 2009
Very Helpful)
fixya210
Rank: Apprentice
Rating: 100%, 2 votes
i had the same problem. black stopped printing. i always used OFFICIAL HP cardridges, so this problem is not exclusive for refilled cardridges.
This solution (offered here) worked for me:
I wanted to stress that you should make sure that:
1) you keep the the buttons down untill it shuts off;
2) on restart you get a notification of service;
3) to turn it off again after service before you turn it on for actual use.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #7
posted on Jul 15, 2009
Not Rated)
allfixedup
Rank: Apprentice
Rating: 0%, 0 votes
Just wanting to share with you people
This is what just worked for me after a very stressful day - why do printer brake down when you need them most
i removed the blank ink cartridge and got the guys in the work shop to very carefully blow air from the air compressor into the little tube where the ink goes plugged printer back in and ran some tests and got the printer to clean heads after about 3 of those black ink working perfectly hope this helps someone.
Was this helpful?
Yes
No
Popular Solutions for HP Photosmart 3310 Printer
Questions and Unsolved Problems for HP Photosmart 3310 Printer
Do you recommend HP Photosmart 3310 Printer?
Answer
Answer
phone is no signal 3310 nokia
Answer
what does oxc18ao26 on hp mean my printer wont print how do i reser
Answer
I am getting an error message on my HP Photosmart 3310 as per below: INK SYSTEM FAILURE Ink system... (More)
Answer
cannot print a photo from the computer...photo tray is filled but it keeps asking for paper in the... (More)
Answer
I had my old dell crash and had to buy a toshiba a505-s6965 this weekend and I can't get the... (More)
30 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Feb 08, 2009
i have tried everting no idea
Comment by Guest, posted on Jan 11, 2009
exact same problem. All colors print, but black not. Always used official HP cardridges, so this problem is not exclusive to refilled cartridegs.
Comment by elise777, posted on Dec 07, 2008
I have the exact same problem of black ink not printing while everything else seems OK. Not a techno wizz so its not easy to solve.
Comment by jlodell, posted on Oct 23, 2008
I have the same problem no black ink is printing. Black ink said it was empty. Replaced the ink cartridge and it only printed color (blue for black) We replaced it again and it printed black for a day. HP did an automatic update just before the black ink went empty. Tests, cleaning all do fine and print in black. Any solutions to this problem yet?
Thanks,
Comment by Guest, posted on Oct 02, 2008
I have the exact same problems mentioned below.
I too think the HP updates defunked my printer.
What shits me the most is that the supplied PC software does not allow you to retreive fax's in the printer memory to the PC !!!!!
What an oversight by HP as it should be included with all the other comprehensive printer apps.
!!#% HP SUCKS %#!!
DONT BUY AGAIN
Comment by danhilliernz, posted on Sep 02, 2008
I have a common problem, by my observations. I have a hp 3310 that runs fine but is not printing black 100%, it's not printing any thing. Only the other colours are printing. It won't print typography either. I have cleaned the heads, run a print test, and aligned the print heads. It failed the alignment test.
What shall I do? Help?
Comment by Philippe71, posted on Aug 26, 2008
I have the same problem and have not been able to find a solution
Comment by Guest, posted on Jul 21, 2008
HP3310 will not print from BLACK cartridge only.
Problem started after using 3 refilled units by CartridgeWorld.
Pages begin with black un affected then slowly become tapered beginning on the right side of the page when printing large black test band patterns to check print consistency.
Replacing with a NEW GENUINE HP cart did not fix it.
P***ed at it, I left it for a month then decide to test it again.
Printed solid black for a few pages then turned back to the "invisible" ink syndrome.
Interestingly, there were 2 web updates to the printer through the WAN/LAN internet connection and that's about when I noticed the fault, and the LCD screen now flash's up 3 prompts forcing you to acknowledge (“OK” button) liability for using non genuine carts.
This screen prompt never appeared until those updates were forced in to it so I suspect that HP sabotaged my printer. – Also, CartWorld had “chipped” my refills so the printer WOULD recognise the ink level but I only get question marks for each non-gen cart which also happened the SAME time as those forced in web updates. (I should have blocked the printer from the internet in my router – Damm!)
Comment by ashish2you, posted on Jun 21, 2008
your suggested, doesnt solve the problem. The black cartridge is wokring only during the "Clean Cartridge" when color cartridge is removed. If both are installed. Black doesnt print. at all.
Comment by NackerMan, posted on Jun 08, 2008
Yes I have the same problem, I used refilled cartridges for the first time just before the problem occurred.  Trying the fix from below now...
Comment by Guest, posted on May 14, 2008
I have a 3110 all in one and it has been great up till now. Now it wont print in black at all. I have done everything in the book what can i try now. It prints all the colours fine.
Comment by Mega4simon, posted on Mar 26, 2008
I also have this problem..........will not copy in black, will not print black and white documents.
Comment by toene, posted on Mar 17, 2008
My printer will only print in colour - I have re-installed software and purchased new inks - yet still it will not print/photocopy/fax in black!!! Help
Comment by Guest, posted on Mar 15, 2008
when i print it will not prit at all, or it will print a test page only in color
Comment by brisbane01, posted on Feb 26, 2008
PHOTOSMART 3110 IS PRINTING PICTURES IN COLOUR
IT REFUSES TO PRINT TEXT IN BLACK
BASIC CHECKS FOR PREFERENCES SETTINGS, ALIGNMENT AND CLEANING PRINT HEAD HAVE BEEN DONE
ANY SOLUTIONS FOR THIS COMMON PROBLEM
SHES A BITCH ALRIGHT.. NO DOUBT ABOUT IT
Comment by Guest, posted on Feb 19, 2008
My printer only prints in color. When I want to print in black and white,the paper comes out blank. Ihave never had this problem before. I have disconnect the back cord several times. The printer will not give me the trouble shooter problem. It will also print from the internet in color.
Comment by jeth, posted on Jan 27, 2008
Have exactly same problem with my 3310 - loss of printing by black cartridge only. Before complete death, it would print the top quarter of each page and then fade-out.
Renders printer useless of course.Anyone worked-out the answer?
jp
Comment by Guest, posted on Jan 15, 2008
Same, machine will not print black, and all the above coments apply,any solutions found yet? If not can some-one truthfully recommend a brilliant printer that does not have this problem?
Comment by MJLattas, posted on Jan 09, 2008
I have the same issue. Color is fine, new black cartridge and still not able to get the black to print. Did all the activities as Ekklesia ??
Comment by SKSwin, posted on Jan 08, 2008
Yes - I have the same problem. I've used a refilled cartridge for some time but recently print quality became poor as if ink was running out - but only on some lines.
If I reprinted the document the same lines printed poorly in exactly the same way (almost as if I'd photocopied the first document) - in other words it looks as if it's a software/firmware issue rather than an ink issue. Now, suddenly, it has stopped printing black completely. No amount of printhead cleaning resolves it. Still loads of ink in the cartridge, though.
Comment by richk, posted on Dec 27, 2007
Yes I have had the same problem with the 3310. The printer was working fine for the first 6 mths and now black ink wont print. I too have tried everything HP support suggested. cleaning the cartridges, resetting the software, downloading the new beta software, etc, etc, but still nothing works. Help someone? Anyone? Rich
Comment by Guest, posted on Dec 23, 2007
Got the same problem over here. No Printing or copying in black at all.
I used refilled cartridges for about 2000 Pages in 18 month time.
The workshop says its the printer head needs swapping. But they cant find any printer head to purchase anywhere.
Anybody knows where to get this spare part?
Comment by Aus-Tex, posted on Dec 07, 2007
My HP Photosmart 3110 is not printing in black. Colour is coming through fine, but no black ink will print even though the cartridge is full. I've had this problem off and on for a few months now. Seems to always happen when I have a deadline and need to print a document. I'm ready to throw it out the window and start over with another brand. Any suggestions would be greatly appreciated as this is stressing me out!!
Comment by anum, posted on Nov 14, 2007
HP 3110 does not print in Black, and no error messages.
Please help
Comment by andyc1909, posted on Nov 06, 2007
No black ink makes it to the paper, colour works fine. no error messages.
all routine maintenance, resets and configuration tweaks to no avail.
Even took print head out and got cleaned by local print shop which worked for a couple of days but then ink just stopped coming through again.
HP useless! Please help.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Photosmart 3310 Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
