Which buttons do i use on the instrument panel
SOURCE: how do I set the clock on my 2003 Ford Mustang 2 door coupe
Here is a link to your owners manual at Fords web site, download it and look on page 22 for the procedure to set the clock.
http://www.motorcraftservice.com/pubs/content/~WO3MUS/~MUS~LEN/42/03musog5e.pdf
SOURCE: Owner's manual for Peugot 407
hi, have a look here, this site should have what your looking for.....
http://www.books4cars.com/
SOURCE: peugot 407 heater not working
You more than likely have a problem with the temperature control blend door inside the air ducting, this door sits between the heater core and the AC evaporator core and mixes the air for the desired temp at the registers/vents. More than likely it is sticking due to being warped from heat. To replace this door and its actuator requires the dash be removed from the car.
SOURCE: the instrument panel flickers constantly both for the clock and for the oven settings
The Display is shorting out, bad news is it is part of the ERC (Electronic Range Control) Pricy to replace, go to marcone.com with your model Number and you can order the part, not hard to replace
