Question about Kenmore Sewing Machines
Thread breaking kenmore sewing machine 158.1789280
Machine will sew for an inch or so and then it kind of gets stuck and the thread breaks.
  • 8 Answers
SOURCE: Bobbin thread breaks
Make sure your bobbin thread is turning clockwise as it sits in the bobbin case. There is a screw on the outside of the bobbin case you can turn with your thumb slightly to adjust tension. If you dangle the case from the thread and give it a light ****, it should move down slightly when doing so-an indicator of good bobbin tension.
Posted on May 20, 2008
SOURCE: I have a Kenmore 385 (12116690) the thread keeps breaking
I have this same machine, it belonged to my husbands grandmother and was given to me after she passed. I let it sit for a few years before I got it out to use it, it was just too emotional. I had this same problem, and after cleaning, it worked fine. I followed the instructions in the manual for taking out the bobbin, bobbin case and metal parts that hold it in the machine. (there are pictures in the manual to help you take it out, take it apart, and put it back in... sounds hard but it's really not). I used a tooth brush to get all of the dust bunnies out (you could go over with a vacuum hose too, after the toothbrush cleaning). After I did this it worked fine. You may want to look in the manual about oiling the machine, if it's been years since it's been done, that might help to. Hope you get it working! I love this machine, it works well and is good quality. (they don't make sewing machines like they used to, the only one I'll buy is a Kenmore!)
Posted on Feb 27, 2009
  • 76 Answers
SOURCE: The thread breaks after sewing about 4 inches.
http://www.sewusa.com/Sewing_Machine_Manuals/Dressmaker_Manuals/Dressmaker_101_Instruction_Manual.htm
You do not say what model you have. Check this site out, if you need a manual.
What you need to do is to give it a good cleaning.
MAKE SURE YOU KEEP THE SCREWS WITH THE PARTS TAKEN OFF AND MAKE NOTE OF HOW YOU TAKE THING APART SO YOU CAN GET IT BACK TOGETHER
If this is the old metal machine, (I love them) remove the screws and plate on the top, (set this aside)
remove screw and part from the left side of machine, (set aside)
remove the needle (note how needle comes out, flat side in the back)
remove the needle plate
You are now able to see most of the inner workings of the machine
Using a can of air (do not put too close to machine parts) dust all the open parts. Can also use old fime paint brushes to get into dmall areas
now using ONLY sewing machine oil, TURN the hand wheel by hand, put a drop of oil on parts that go in and out of each other, rub over each other (on top, over the needle area and in the bobbin area, (IN bobbin area you can use a q-tip with oil to rub the area)
If turning the hand wheel by hand to oil moved freely, you can plug in machine and run machine to get the oil in all the parts (this will lubricate the parts you just oiled.
Put machine back together,
Use the air agsin to dust between the tension disks.
When winding the bobbin, make sure it winds even up and down.
thread machine and try
MAKE SURE YOUR BOBBIN THREAD AND TOP THREAD ARE PULLED TO THE BACK BEFORE SEWING AND HOLD THE THREADS FOR THE FIRST FEW SITCHES, IF NOT THE MACHINE WILL PULL THE THREADS AND YOU WILL GET BREAKAGE
GOOD LUCK
Posted on Sep 05, 2009
Testimonial: "Thank you for your advise. I know the machine needed oiled. The thread still breaks, but now it will sew a little longer before the thread breaks."
  • 149 Answers
SOURCE: Breaking threads... you so about an inch and it
It sound like it is not threaded properly or the tension is too tight, You should be able to pull on the thread manually without breaking it
look for your manual here
http://www.brother-usa.com/manuals/default.aspx?ProductGroupID=3
Posted on Jan 23, 2010
SOURCE: The bobbin thread breaks
if upper thread is breaking
1. needle in backward
2.upper tension to tight-check manual for proper setting
3.needle maybe bent-try rolling needle on flat surface to see if it's bent & if so replace
4.thread may hang on bobbin case-check area for lent or fragments of old threads
5. knotty or cheap thread-always use good quality thread
if lower thread is breaking
1.the most probable cause of lower thread breaking is an inproperly wound bobbin
2.bent bobbin
3.lint built up in case
4. thread catching on a spring or latch
Posted on Jul 29, 2010
Kenmore mini ultra The top thread breaks off from needle after a few stitches. The bobbin seems to Be catching the top thread. Thank you. ??
If the top thread sews a few inches and then breaks, something is catching the top thread and holding it until it breaks. Usually, this will happen when using the old style thread cones with the slit in the edge to keep the thread from raveling off the spool. To prevent the thread from hanging up, turn the thread spool over so the slit is at the top instead of the bottom. Sometimes top thread breaks will happen if the thread becomes looped around the thread spool pin.
Remove the thread, ALWAYS RAISE the presser foot and then rethread the upper thread. Verify that the thread path is correct and that the thread has not looped around a guide.
If the thread is fraying at the needle eye, the needle/thread are not compatible. Also, the tension may be too high.
Check that the upper tension disk is clean--no gunk buildup or thread pieces stuck.
If the thread is actually breaking when it penetrates the needle plate hole, there may be a burr or nick somewhere below that is catching the upper thread. You can wrap your finger with a piece of fine fabric, like an old pair of hosier, fine knit fabric, etc. and running your finger around in the bobbin area, under the needle plate. If you get snags, then you have a burr or nick. If it is small, you can sometimes smooth it with a fine emery board. If it is a large burr, you may need to purchase a replacement part.
Why Does My Top Thread Keep Breaking Sewing Machine
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Sep 05, 2016 | Kenmore Sewing Machines
Breaking thread while zigzagging
on most machines you must substantially reduce the needle tension when sewing zigzags
Mar 02, 2014 | Sewing Machines
My needle thread doesn't break, but when I go to sew, it unthreads itself.
make sure to keep long thread tail for the top & bobbin
of 4 to 6 inches & pulled behind the needle
Aug 04, 2012 | Kenmore 15516 Mechanical Sewing Machine
I have a janome 1600P, it will not sew without either the top thread breaking or the bobin thread breaking. It will sew for about a quarter of an inch and then the thread breaks, I have changed the bo
My experiences with thread breaking with machine on a quilting frame make me look at the upper tension being set too high, the needle being worn or movement of the machine is too fast. Reduce the upper tension first, then sew in straight lines at first. See if you can sew slowly, in straight lines and reduce the upper tension until the thread stops breaking. If so, try some 1-2 inch circles, again going slowly. If the needle thread is pulling to the back, you will need to increase the upper tension again until the stitches meet in the middle of the fabric. If you can't locate a balanced spot where the needle thread is not pulling to the back side and thread doesn't break, try taking the machine off of the frame and sewing on a table. If it won't sew this way, it needs some professional help. If it does, you will probably save a lot of time taking it in for service, making sure to explain to the repair center that you have problems on a quilting frame, not while sewing normally. When the machine is adjusted to sew normally on a table and you move it to the frame, you will probably need to reduce the tension by 1-2 complete turns of the tension knob.
Nov 17, 2011 | Sewing Machines
The lower looper keeps breaking thread
Hi,...if the lower looper thread is breaking before you sew six inches or more then I suspect a threading problem.When the lower looper thread breaks, You MUST unthread the needles before you thread the lower looper. Thread the looper and then rethread the needles.
Hope that helps,
Doug
Aug 05, 2010 | Simplicity Serge Pro SW432 Mechanical...
Jan 22, 2010 | Brother LS-2125 Mechanical Sewing Machine
I've lost my manual and video need threading info
One of the most common mistakes with overlockers is that the threads must always be threaded in order. So if you sew about 1 inch and the thread breaks try unthreading the eyes of the needles rethread the looper and then rethread the eyes of thew needles. If not you will get the same result of sewing about 1 inch and it will break again.
Aug 26, 2008 | Baby Lock Ellure
Tension problems (?)
Well, I could have written this. I bought a used model from a repairman about a year ago. I have a Model 537FA and I'm going to throw it out in the rain leftover from TS Fay if I don't find some kind of help. :) I'm thinking it's a tension issue, but I can't seem to find a fix.
Does your tension on your top thread sometimes tighten to impossible to move in the middle of sewing. I know that mine does this and it causes the top thread to break. I don't know what's causing the bobbin mess.
Maybe someone will help us? Please!
Aug 23, 2008 | Sewing Machines
Sewing Machines Logo
80 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
