Home Theater Systems
Problem for Home Theater Systems
Generic problem for all Home Theater Systems
DVD trays out - Panasonic SA-PM39D
By edibon on Aug 27, 2007
Hi, my DVD-Stereo's trays are all open. My nephew (child) inserted a DVD on top of another, as a result the trays got stuck.
I opened the system and managed to manually push out all trays to take off DVDs.
As a result i cannot push them back, neither can they by themselves when powered.
Also, the radio does not take any signal even if the antenna is connected. This second problem has been existing before the first.
Please help.
Same Problem
Mar 13, 2009
-   I have this problem with mine. It seems to be very common. Mine happened for no apparent reason, just went to use it one day and got the 'tray init...please wait' text. I took it to a panasonic repair centre and they costed the repair at hundreds of pounds and even admitted that when the multi changer goes wrong, they just aren't worth getting fixed. Sorry folks...it appears that like me, you just have scrap metal on your hands now. Scott-   Guest
Jun 21, 2008
-   Trays won't eject.
patrick@pchristian.com
-   patrick20
Apr 21, 2008
-   Same problem, cannot open any CD/DVD tray, system msgs are the same as others reporeted
-   Guest
Apr 17, 2008
-   opened dvd
-   Guest
Apr 12, 2008
-   I have the same problem with my Panasonic SA-PM39D, after powering on system, it does the demonstration itself, and if I press any botton it will notify "tray init , please wait" and nothing continue. If there are any solution, please sent to my email haiddt@yahoo.com
Thank you alot for your help.-   haiddt
Solution #1
posted on Aug 11, 2009
Somewhat Helpful)
jef8uk
Rank: Apprentice
Rating: 75%, 1 votes
the system i had, had exactly the same problem, happened years ago but only got around to it now.
The case is quite fiddly and there are also potentially dangerous voltages inside so i would only do this if you are trained, and even then you do so at your own risk.
I have fixed the problem but i am not 100% on what the actual problem was. firstly i opened the system up and seeing as the problem was the stuck trays i went straight for the dvd mech (part 1) however that may not be necessary and the problem may have just been the front switches not reading properly (part 2).
**make sure the unit is unplugged**
Part1
-take sides off
-loosen front panel from base of system
-i removed the white plastic top of the dvd unit allowing you access to the screws holding the metal panel on to the dvd unit, removed the metal unit.
-there are two ribbons connecting the dvd unit to the main unit, the smaller one controls the motor drives.
-i plugged in the unit to test the motors, to do this i ground each pin coresponding to a motor (they are labelled) located a the header at the end of the smaller ribbon. (This can be done from the other end of the cable located on the side of the unit, which is much more accessible but not labelled)
-forced dvd trays back to their starting position (makes lots of noises)
-on the side of is a sliding mech that selects which dvd tray i made sure that moved back and forth freely (quite stiff as you are working against the motor) you should hear the motor turning.
put everything back together.
-when switched on it would go through starting sequence but NOTHING else.
Part 2
-mech appeared to working but noticed front panel was not responding to button presses on the dvd area. the tape/dvd select and power button were OK though
-removed front cover and removed front panel circuit board, plugged back into system.
-without the front panel the buttons all worked and system all worked.
-replaced front bezel and system worked.
j uk
Was this helpful?
Yes
No
Popular Solutions for Home Theater Systems
Questions and Unsolved Problems for Home Theater Systems
Answer
I have 2 sony cd players that I want to hook up too a reseiver.I would like to know which model is... (More)
Answer
looking for a projector 500 to 900 buck range what should i get
Answer
i have a hitach1 50''ultravision dpl and a big yellow spot and a mountian pitcher in the center of... (More)
Answer
just bought a new gpx mp3 player and it will not play..tried to turn it on and only an hour glass... (More)
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 24, 2008
My daughter (3) tried to insert her 'Barbie' dvd....and now the dvd/cd won't respond. Please help!!!!
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Home Theater Systems:
Top Home Theater System Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Home Theater System Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
