Question about Dryers
Kenmore 66902690 dryer
Dryer won't start
heatman101
  • 43501 Answers
SOURCE: My Kenmore dryer won't stay
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jun 02, 2011
Testimonial: "you have been alot of help now I need to go home and double check the items you have listed to see if I can get my dryer to work"
canwoodjc
  • 3301 Answers
SOURCE: My Kenmore 110.66962501 dryer doesn't start.
if your sure the thermal fuse is good,, check the start switch,, making sure the dryer select setting is set to something other than off, also, the door switch . you can Jumper both these switches, I'd try the door switch first as they go out more often . if you have a meter and want to test the switch Some door switches have only two metal prongs extending from the body, while others have three. Those with three terminals will have a common (COM) terminal, a normally closed (N.C.) terminal, and a normally open (N.O.) terminal. Those switches with only two terminals will have either a common terminal and a normally open terminal, or a common terminal and a normally closed terminal. We are providing directions for testing a door switch with three terminals. If you are dealing with a door switch that has only two terminals, ignore the part of this test that does not apply to you.Use your ohmmeter to test your switch for continuity. Begin by setting your ohmmeter to measure resistance at a scale of R x 1. If yours is a two-wire switch, touch each tester probe to each of the switch's terminals. You should receive a reading of infinity. While the probes are still touching the switch's terminals, press in on and hold the switch. The reading should change to zero.
Posted on Jul 20, 2011
heatman101
  • 43501 Answers
SOURCE: My series 80 Kenmore dryer won't start
heatman101
Posted on Aug 05, 2011
heatman101
  • 43501 Answers
SOURCE: My Kenmore 600 series dryer
heatman101
'lll
Posted on Aug 18, 2011
richroth
  • 9472 Answers
SOURCE: Kenmore 80 series dryer won't
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch this part testing video.
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Aug 21, 2011
Kenmore whirlpool dryer won't start and has a bad burning smell
You may have an overheat sensor that is burning up. The dryer won't start because the heat would be uncontrollably high otherwise
Jan 29, 2013 | GE Profile DPSF495EW Dryer
Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
heatman101
Sep 19, 2011 | Kenmore Dryers
Won't tumble. Drum won't roll. How do we open it
heatman101
Sep 11, 2011 | Kenmore 62702 Electric Dryer
My Kenmore 600 series dryer won't start when I push the start knob...I can hear a hum when the knob is pushed in but it won't start. Any suggestions?
heatman101
'lll
Aug 17, 2011 | Dryers
Kenmore 90 series dryer..motor won't turn..hear the klicking sound..kind of hums...but won't turn. changed motor..same problem
heatman101
Aug 11, 2011 | Dryers
heatman101
Jul 30, 2011 | Kenmore 800 6983 Electric Dryer
I have a Kenmore 80 series Heavy Duty Quit Pak Dryer and it won't turn on. No sound or anything
heatman101
Jun 27, 2011 | Kenmore Dryers
I have a Kenmore stacking washer and dryer. The drum on the dryer won't turn unless I start turning it first. After I start turning it then it works, how do I fix it?
heatman101
Jun 19, 2011 | Kenmore Dryers
Dryer does not start Model 66902690
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Nov 26, 2010 | Kenmore Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
