Question about Miele G880 Dishwasher
Miele dishwasher Have cleaned the filter combination and the drain pump as suggested but there is still a water pool at the bottom of the dishwasher. Dishwasher does not go further than the first fill of water. Have only used it once since we moved in and it is 2 years old.
  • 59 Answers
If your amp is less than 5 years old you maybe able to get it fixed for free at http://www.domgen.com check it out we have all our contents covered. This is better than your normal home insurance. Don't matter you could claim 100 times and never loose out. check it out! Also don't 4get to leave me feedback cheers raverbaby01
Posted on Aug 27, 2007
Dishwasher is not working. The red 'Inlet/Outlet' light is flashing. Any advice please Thank you
There are a few things you can check. First set the washer cycle to Stop and turn off the unit. Next make sure that the stopcock on the inlet valve is fully open. Then close the stopcock/valve and disconnect the inlet hose. Remove the seal and then the filter (use pliers). Clean this inlet filter with running water. Replace the filter and seal and reconnect the hose to your inlet valve. Reopen the valve (check for leaks from threading problems). Make sure the valve is fully open when you try to restart the dishwasher. Check your incoming water pressure at this valve as well - low water pressure will also trigger the inlet error. Make sure the hose is not kinked.
If the washer did any parts of the wash cycle, then try cleaning the outlet side of the system.
Next clean the combination filter, drain pump and non-return valve. For the filter (near the lower spray arm), turn the handle counter-clockwise. Lift the filter out and remove all debris. Rinse under running water and use a nylon bristle brush to get stubborn stuff out. Pull back the yellow clip and open the filter flap. Clean the underside of the filter with running water again.
Remove the water from the cabinet with any container that works. Raise the locking clamp for the non-return valve. Lift up the valve and clean it under running water. Carefully check the drain pump (now visible with the non-return valve out) and remove any debris. Sharp objects may be present. Move the impellers and completely check the pump for foreign objects and remove them. Replace the non-return valve and secure it with the locking clamp. Replace the combination filter so that it lays flat and secure it with the handle. Make sure that the drain hose is not kinked.
If neither of these solve the problem, you need to call for service. The Waterproof safety system has been triggered and water got into the electrical system of the unit.
Many Miele appliance manuals are here: http://www.miele.co.uk/customer/OperatingInstructions.aspx . The manual for the Miele G641 is here: http://www.miele.co.uk/Resources/OperatingInstructions/G%20641%20and%20G%20841%20Plus.pdf . See this manual for pictures of the filters and drain pump area.
I hope this helps.
Sep 14, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Piece of glass dropped through the filter housing when cleaning. Now there is a sound like the motor is jammed.
Hi ghedinger,
Seems something is stuck on your drain motor, now to thoroughly clean the unit and part, do the following:
- Remove as much residual water as possible from the sump and drain hose.
- Open the door.
- Remove the bottom basket.
- Remove the bottom spray arm.
- Unscrew the bottom spray arm flange.
- Remove the filter combination.
- Lay the dishwasher on its back.
Now you will see the Drain pump, like so:
Now you need to remove the drain pump from the housing to clean it thoroughly:
- Disconnect the pump plug connections.
- Open the safety retainer clip with a screwdriver
- Turn the pump clockwise and pull it from its holder
Now clean the impeller area, and then re-fit everything (Remember: When refitting, apply a little water or soap solution to the pump seal as a slip lubricant.) Then Test
Hope this helps :-)
If you found this solution helpful, please rate accordingly
May 07, 2011 | Miele G2732SCIWHWH Dishwasher
Water will not drain out of bottom of machine.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Mar 19, 2011 | Miele G880 Dishwasher
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Water collected in bottom of dishwasher
This could be due to several reasons. The most logical is that the pump filter is getting clogged.
follow the instructions in the owner's manual to clean up the filter. Also the impeller arm will need cleaning if the dishes are not clean.
If the above does not fix it then more likely the drain outlet under the sink is getting clogged. Try and clean the drains.
Regards
Sam
Dec 15, 2009 | Miele Dishwashers
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Miele Dishwasher Problem
This just happened to me (my hands are still dripping from cleaning out the water at the bottom of the tub). Frustrated because I had cleaned the filters, bailed out the water with a cup, yet the light was still flashing. I finally followed the troubleshooting guide in the operating manual and held down the start/stop button for 5 seconds, while the machine was on, which seemed to reset everything. Works fine now.
Mar 02, 2008 | Dishwashers
Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
In the user manual there's a section on how to clean the non-return valve. It's the plastic piece under the wire below the triple filter. Why did you pull out the machine? Did you kink the drain hose? If you don't find a clogged valve, spin the impeller wheel several times. It's under the valve inside the bottom hole where the valve came out.
Now here's the important step- Reset the fault! Power off/on the unit. If the light blinks when you turn it on, Press and hold the start button 4 seconds with the door open. Find the combination of off/on buttons to press to reset the machine in the user manual.
(Note: If the machine runs continuously as soon as you pressed on the power button, then you have water under the unit in the safety pan. Call Miele for help.) Now select the normal wash cycle close the door and start it. The drain motor always runs first. This verifies to the brain how much water is inside the machine when it starts filling. The drain pump runs for half a minute. If you hear it running with no drain check the drain hose especially if it's connected to a disposal. Clean the disposal.. If it's not running at all the light will go on again before filling, call Miele. If the machine fill up with fresh water, the drain works. Watch and listen when the light comes on. Is it filling or did it start circulating? Open the door, are the baskets are dripping wet? Then it filled and circulated. If the light comes on several miutes later then call Miele.
Feb 04, 2008 | Miele 23 in. Novotronic G841 Built-In...
Miele G646SC Plus dishwasher Drainage / inlet warning light
I had the same problem a few days ago. I followed the instructions to clean the filter and check to see that the impeller was free to rotate in both directions. The problem persisted. After reading this thread, and a similar one on another site, I tried what mikeboerma suggested in "solution #3", and bingo, problem solved. The magic combination is to push and hold the on/off button and the start/stop button.
Sep 15, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Miele G880 Dishwasher Logo
295 people viewed this question
Top Miele Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
