Question about Xantrex Electronics - Others
Xantrex freedom 2000 watt inverter/ charger
Maiden voyage 2013 toy hauler. the inverter is connected only to non GFI circuit. used only for television, satellite and receiver.and occasional slow cooker. boon docking had been using the slow cooker 300 watt when the inverter started smelling like burning electrical wire. called technician who installed it said it shouldn't be smelling like that. The unit was not hot just smells. it penetrates throughout the RV living area it is like toxic. There are 4 solar panels . It seems that the stench is while it is in charging stage.
    New Friend:
  • 46 Answers
Hi
Your x anter freedom inverter can't run all those items it is being over worked ( overloading ) that's why it is heating up and if not carefull wit will explode .
Posted on May 18, 2017
4 Suggested Answers
SOURCE: Xantrex Freedom 458 Combi inverter/charger 2000 watt
OK my 2000 Discovery does the same thing. Try and hit the inverter charger with your fist 3-4 times, then listen and see if the charger fan starts up. I will be bringing my inverter to Portland this week to have the tech look at it. The other thing is it could be the transfer switch. Will let you know.
Posted on Sep 08, 2009
mwoodring1
  • 496 Answers
SOURCE: I have a xantrex 2000 watt freedom 458 freedom
this isn't an answer but i would like to just clear the water a little. how old is the unit? you say it the inverter works when on shore power ( 110v A.C. wall plug or 220 ) but it will not charge the batteries while hooked up to shore power? are you trying to use a generator to run the inverter and charge the batteries? I just need to a little more so i can better understand you problem and help you better
Looking forward to hearing back from you.
M.Woodring
Posted on Jun 21, 2011
SOURCE: Freedom 20 Inverter/Converter Charger installed
Second Freedom 25 inverter/charger...first one repaired, this one went to fault...started microwave on fire, fried the satillite receiver and possibly other components....installing a Mangnum....."do not let anyone rebuild the Freedom 25" First time about $900.00 to rebuild...this time about $9000.00 with components it fried. Fleetwood LLC Corporate knows of problems and only offer to sell you the conversion kit for about $4200.00....bankruptcy sanctifies previous problems "they" left with us.
Posted on Jun 22, 2011
Why does my Freedom 100 Watt Inverter/Charger remains in bulk
It sounds like a bad battery mine did the same but it was a much larger unit changed the house AGM Batteries and works perfectly
Jun 09, 2014 | Xantrex Technology Xantrex 458 10 12...
Xantrex inverter/ charger smells like burning electrical
I would call or e-mail the manufacturer of the inverter. The dealer or dealers may know the issue but likely the manufacturer will be more help.
Some devices like an inverter will have a smell in the beginning, power supplies are like that. You said that the inverter didn't get hot but smell indicates something is hot.
Apr 13, 2017 | Xantrex Electronics - Others
Freedom 20 Inverter/Converter Charger installed on Alpenlite RV. When remote switch for solar use (2000 watt) is turned on, all 110 system is energized. Turn solar switch off and voltage check at...
Oct 27, 2010 | Xantrex Technology Heart Freedom 20 12...
Freedom Combi inverter/charger stopped working with the remote inside the RV. Replaced remote but still didn't work. I have to press inverter button inside RV, go to inverter outside RV and press...
Sounds like the link between the inverter and the remote is bad. Chaffed wire, broken wire, etc may be the culprit.
You should still have the shorting jumper that came with the Freedom. Put the jumper into the AUX port, and you should now have local control of the inverter. If so, then replace the wiring between inverter and remote.
Aug 08, 2010 | Xantrex Technology Xantrex 458 10 12...
The inverter dose not charge the batters on my coach.
From the manual I read on the Xantrex website shows 2 fuses. 1 in the F1 Position which is the outer circuit breaker, and the other in the F2 position. You can see the F1 tube-style fuse from the front, but the F2 fuse you have to tuck your head behind and see it from the other side. You can see if the fuse wire is burnt. To be sure, use an ohm meter to check the continuity of the circuit. Hope that helps.
Jul 27, 2010 | Xantrex Technology Xantrex 458 10 12...
Xantrex 458 freedom....has stopped charging house batteries off of engine alternator. Alternator is showing that it works (dash gauge). It does charge while on shore power or generator....but not charging...
Fis\rst of all is the inverter supplying 120 VAC? when turned on?. If so the inverter seems to be working.I think your problem is in the truck alternator/charging system. The inverter is independent of this charger..
Mar 23, 2010 | Xantrex Technology Xantrex 458 10 12...
Jan 15, 2009 | Xantrex Technology Heart Freedom 20 12...
Electronics - Others Logo
171 people viewed this question
Top Xantrex Electronics - Others Experts
Are you a Xantrex Electronics - Other Expert? Answer questions, earn points and help others
