Question about Sears Grinders
Switch and capacitor crapped out on 1/2 hp Sears bench grinder
Have a model 397.1949 1/2 hp bench grinder. Need a new capacitor and switch and wiring diagram.
  • Anonymous Mar 24, 2014
    Model 351-211540
  • 718 Answers
SOURCE:
Looking to replace obsolete switch on Craftsman 1/2 hp bench grinder. Sears lists part as 4984992
This switch is a very close fit, and it is rated for 20A 120VAC.
2LNA7 $11.09 / each
Grainger
I've used it on that vintage Craftsman bench grinder.
http://www.grainger.com/
Dec 12, 2015 | Craftsman Grinders
I have an old Craftsman bench grinder that I got at an auction. I need a capacitor and the one on it has no markings. It is a 1hp model 319.19063. Sears Parts direct says that it is no longer available and...
this is a "Split-Phase"motor it uses only a run capacitor and a typical capacitance rated MFD rating will be between 80 and 290 MFD, go to www. grainger..com and they will have your part,and even if its an older unit and the model/serial/number is available take it with you & they will have a replacement capacitor available in the correct size/dimension/mfd/etc
Apr 24, 2011 | Baldor 8" 1 Hp Electric Bench Grinder
I have a Buffalo B-10CB(CH) bench grinder and the on/off switch has broken, it's a push/pull type. What can I replace it with to make it work safely?
You could connect the wires of the switch together inside and bypass the switch. Then I would connect in the power cable a switch rated for 1 hp. You can use surface mount electrical box, with two cable connectors (one for the cable going into the grinder, the other for the cable going to the male cord end of the cable. Install a 120 volt switch inside the box (similar to the light switch in the wall). Make sure that the switch is rated for 1 hp. I would install the switch under the bench, under the grinder.
Joe
Feb 28, 2011 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
I have a 1/3 hp motor with a capacitor. There are four motor leads coming out of motor, the capacitor is mounted in the wiring box. This motor does not have a centrifugal switch, to isolate the capacitor...
I am in the process of replacing a capacitor on a Craftsman 6 in 1/3 grinder, 2.8 amp, single phase, 110v. Not sure on the centrifugal switch. model 319.190621, ser B9530. When I took the old one out the black wire from the capacitor went to the cluster of back wires (in my case 3) in the wire nut. The blue wire from the grinder went to red wire from the capacitor in a wire nut. Hope that helps you....
Maybe you can help me... the specs on the capacitor burned off when it failed. Can you tell me what the capacitor specs are on yours?
Nov 16, 2010 | Craftsman 6" Bench Grinder with Lamp
I have a Taiwan made 1/2 hp bench grinder that wont run only hums and now it wont even run if I spin it by hand and no capacitor. Is it junk now.
Hi there, with out seeing it I`d say your brushes are gone and ceasing. I hope this solves your problem.
May 18, 2010 | Grinders
Need an on/off switch for a buffalo bench grinder model B-6CB 1/2 hp. 41/2 amp. serial #775713
I had the same problem with a Northern Tools bench grinder. These are made in China and parts are hard to come by. I had enough room after removing the old broken on/off switch to install a single pole 15 amp light switch like you use in your home. I simply installed it horizontally and then put the switch cover on. It works perfectly. If you do not have enough room then look for any 15 amp or larger switch that will fit in the housing. Any on/off switch will work. You could even mount the switch on the bench in a switch housing and run the wires from the grinder to the switch and back if need be. Just be safe and make sure there are no exposed wires. As a last resort you could remove the switch connect the wires, eliminating the switch and use a plug in wall switch such as this. 4147a14.png
Apr 23, 2010 | BUFFALO 10" Bench Grinder
I need a replacement switch for a craftsman 1/2 HP bench grinder model#397.19441. I have no owners manual or parts list. This grinder is several years old.
this switch is no longer available from Sears, so I suggest making a wiring drawing and taking the switch to a local electrical supply house and try matching it up with a replacement. It seems to be a simple on/off type switch and I would think that you should have no problem. Let me know if you do and give me the information on the switch and I will try some other sites I know.
Dec 28, 2009 | Craftsman Grinders
Have an old sears craftsman 1/4 hp grinder model 397.19501 wires have been disconnected. I want to rewire and test. Does anyone know how to connect the wires? There are 2 copper tabs under the on/off...
the two copper tabs under the on off switch are to break the power source.connect incoming power to one of these(black) then a short piece of wire from the other tab under switch to one of the three tabs under plate that is marked hot or l1 is probably #2 but you need to be sure. the white is the nuetral or l2 which is most likely #3 and the green is the ground most likely #4 I would definately look online for a wiring diagram to be sure if they are not marked with L1 L2 and GND
Oct 10, 2009 | Black & Decker 3/4 Hp, 8" 205MM, Heavy...
Grinders Logo
2,149 people viewed this question
Top Sears Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
Tom Chichester
Are you a Sears Grinder Expert? Answer questions, earn points and help others
