Question about John Deere Technical Service Repair Manual 316 318 420
318 john deere no throttle control runs at high rpm only...
5 Suggested Answers
nova2nv
  • 197 Answers
SOURCE: john deere 318 wiring diagram I replaced an bg 316
Purple wire goes to the solenoid on starter.If you installed starter with single wire post all you have to do is mount a solenoid to the frame just in front of starter,existing batt/starter cable goes to one solenoid post,purchase a short red cable and install on other solenoid post and run it to the starter,plug purple wire into new solenoid and the way you go.
Posted on Nov 16, 2009
Testimonial: "This was great advise bought a solenoid and away i go thx"
  • 52 Answers
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Posted on Apr 18, 2010
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
  • 146 Answers
SOURCE: my john deere rideing mower idles up and down at
The motor has a governor that controls its speed, and if one of the pivoting parts or linkages is sticking this would happen. Look for the throttle linkage on the engine carburetor (move your throttle up and down, watch what moves). The governor will be a second linkage attached to the throttle arm. Squirt some WD-40 on any rotating parts and make sure a foreign object isn't stuck in there. It could also be the part of the governor that's internal to the engine -- harder to get at, but not expensive to fix.
Posted on Jul 04, 2010
  • 4961 Answers
SOURCE: need a electrical diagram for John Deere 318
You might want to post this question in a different section. This is the computer section...
Posted on Aug 18, 2012
How to release the hydro. Trans. On a 318 John Deere
You just go to the link I attached I'm sure you will get the solution of your problem.
318 John Deere
May 22, 2017 | John Deere Garden
My John Deere 420 onan stops for no reason after running for ten minutes Restarts immediatly.
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure.
John Deere 316 318 and 420 Lawn and Garden Tractors Service Manual
Jul 07, 2015 | John Deere Garden
John Deere 318 runs hot
yes if you use throttle too much...also check out for engine hot or cold guage, and thermostat valve, and engine oil level, what fuel are you using??? use diesel not kerosene...
Jul 08, 2014 | Motorsports
1981 John Deere 1050 Diesel Tractor - Engine will go to high idle by itself. You can shut key off and engine will eventually die. What would cause the engine to high idle? Afraid engine will lock up.
There are 2 types of governors on diesels. one is controlled from the foot and is fixed speed at the foot setting. The other is variable speed which will run to high idle if the setting is not changed IE on start it will idle ok but if you use a fast setting on a hand throttle say to warm up the motor it will run to high idle. I suggest that if you have not had a problem before then you should have a diesel pump specialist look at it as there may be a fault in the governor control.
Jun 23, 2013 | John Deere Tractor Side Screen...
Need a electrical diagram for John Deere 318
Aug 17, 2012 | John Deere Technical Service Repair Manual...
John Deere 318 with an issue
black smoke is over fuelling and not spark related
check / clean carby especially the float, needle and seat area
Nov 23, 2017 | John Deere Garden
Fuse problem on John Deere 318 lawnmower
Does the mower have an electric clutch the clutch could be going bad if it has one unplug the clutch and see what happens
Oct 19, 2017 | John Deere Garden
John Deere Technical Service Repair Manual 316 318 420 Logo
49 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
