Philips 32pfl5409 98
Black out only red led can be seen
2 Suggested Answers
SOURCE: 42" philips plasma, black screen and flashing red light
This fix was posted on similar problem, worthy of repeating: Replaced 3300mf 10V capacitors at PS. Both had bulged slightly. Upsized to 25V as the previous solution poster had suggested 16V but I could not locate 16V so used 25V and TV is back to normal!
Posted on Dec 08, 2009
Nov 29, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
I have a Philips 42PF9630A/32 Plasma TV, red led blinks 7 times
No,body can cofirm u have to troubleshoot change the boards to know the problem.
Oct 22, 2009 | Philips 42PF7220A 42 in. Plasma Television
Retuning Philips DTR 1500 digibox
Had same problem. Remedy is to put digibox back to factory reset. Dis-connect from mains. Keep pressing + button on front panel as you re-connect to mains. Red LED will be on, when orange LED blinks release + button. briefly press + button. You have solid red LED and blinking red LED. Enter code 9 9 0 0, by remote blinking LED will show green. Wait a few minutes and the instalation page will appear on screen. Go to update and start as you did before and C5 should be installed. Hope that helps.
Dave
Sep 30, 2009 | Philips Televison & Video
My philips 50p8341 beeps then flashes the red led 4 times
4 Blinks means that an incorrect voltage had been detected on the +5V circuit coming from PSU to digital control board.
The PSU must be tested and eventually repaired or replaced.
Aug 08, 2009 | Philips Televison & Video
TV does not turn on, blinking red LED
Problem is a bad audio IC esp if your are reciving 11 blink code
if it is a 5 blink code replace Crystal 1h00 On Ssb new part number is 24225430 1397
Jan 12, 2009 | Philips 42PF7321 42 in. Plasma HDTV
32 Philips hd flat screen #32pf7320a/37b on for a time,then black
check the capacitors in the power supply that is the first thing to do, just check if anyone is swallen or pregnant jajajaja that's how some people call it
Dec 15, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
My Plasma TV is not working any more
Sounds like a scan problem if yu suspect the y-sus i suggs\est changing the drivers to
Nov 16, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips turntable af 829
Specifically the turntable AF-829:
I had exactly the same problem, and fixed this succesfully.
The problem is in one of the opto-coupler combinations (LED + LDR).
There are two, both located in the mechanical part of the turntable:
1. The first is for the detection when the arm reaches the end of the record, so that it will return to base. This is a red LED with an optocoupler in a little black case. This is OK.
2. The second one is for detection that the arm has reached the beginning of the record area. You can test this by manually pulling the arm from base and moving it towards the record. Then the turntable should start to rotate. You will see it does not.
The problem is that either the LED has not got enough light-emission any more, or the LDR has become more insensitive. It's a transparent LED that radiates RED light.
I replaced the LED by a new (red) one with higher light output, and now it's working fine again.
Marcel.
Apr 14, 2008 | Philips Audio Players & Recorders
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
