Question about Air Conditioning and Heat for Hyundai Entourage
To get a/c to work on my 07 Hyundai Entourage I must pull out the shunt in the drivers side fuse panel then go into the engine compartment fuse box and replace the a/c comp fuse (7.5),this happens ove
I replaced the a/c comp relay.Still having to pull shunt then put in new fuse then push shunt back in. Start car and cold air is good till vehicle is shut down.On restarting need new fuse but you have to pull shunt first then add fuse then attach shunt back in
  • 19 Answers
SOURCE: 2003 hyundai elantra wont start
hi there i would probably be giving it a compression check to start with , if it has over heated it may have blown a head gasket and now has no compression.
Posted on Sep 03, 2008
ghost4548
  • 776 Answers
SOURCE: from cold start engine warms to quater temp then
Does the Check Engine light come ON when this happens? Whenever the "Check Engine" light comes on, there is always a DTC (Diagnostic Trouble Code) stored in the ECM (Engine Control Module). You'll need an OBDII (On-Board-Diagnostics) scanner to retrieve any codes recorded/set in ECM. Otherwise, guesswork. I have MANY ideas that could send you on a wild goose chase. I strongly suspect EMS (Engine Management System) sensor beginning to malfunction as it warms up. First strong suspicion is the crank position sensor (CKP) - however,usually always sets a DTC (i.e., P0335, P0336). The next suspicion is the Engine Coolant Temperature sensor. The ECM uses this sensor's signal to adjust fuel, timing, engine RPM, etc based on engine temp. If malfunctioning at a particuar point during engine warm up, it could be telling the ECM the temperature is LOWER or HIGHER than it ACTUALLY is, resulting in the ECM to increase fuel (flood it) or give it LESS fuel (starve it). If this malfunction lasts long enough, the ECM will usually set a DTC for that sensor circuit, either a Range/Performance code, or a "LOW Input" or "HIGH Input" code.
Posted on Jun 07, 2009
alicantecoli
  • 22156 Answers
SOURCE: 2004 Hyundai Terracan, 2.5 turbo diesel, manual.
right renew the glow plug timer/relay if you put a meter on the glow plugs when cold and turn ign on (with help) it should supply power for a about 20 secs ,time depends on outside air temperature ,if all else fails then do a colin --- use a push button switch,wired to a relay so glow plugs can be operated by pushing the switch which you will mount on the dash ,cant beat a manual overide system
Posted on Dec 14, 2009
Testimonial: "alicantecoli provided accurate and correct advice for the diesel cold engine start problem I had."
  • 389 Answers
SOURCE: I can't get the driver side window to go up. I
This is an easy fix. It's your switch. To test this you unplug your switch after you remove it from the door. Remember where the wires go. You will see a little white, grey, or black box the wires are connected to. The box looks solid but you can pop a top off and inside there is conact points. Look very carefully how they go when you open it. Those copper pieces get corroded and stop making contact.
get some steel wool and clean them up nice and shiney. Put them back in the little box and test it. Don't worry if you mess this up to much. They are a dime a dozen at the wrecking yards. Just find you make and model and you should not pay over 10.00 for the switch.
I try to be of help a long ways a way so please be kind with a thumbs up. Keep me informed. The Raz shack
Posted on Apr 21, 2010
Testimonial: "Thank you very much."
SOURCE: 07 hyundai sonata cranks fine, won't start, fuses
Our 2007 Sonata refused to start after coming out of the store. It cranks but won't start. It has 41000 miles on it. Dealer said there were three codes stored. A technical Service Bulletin said the throttle body may be dirty and stuck. Sure enough. They cleaned it and now it runs.
Posted on Jan 06, 2011
I cant find the windshield fluid fuse. Its not where the diagram on the back of the fuse box says it is
According to the owner's manual (here http://www.myhyundaiforums.com/AGEO-EU75A.pdf ) the first fuse, a 10A, in the engine fuse compartment is for the front washer motor relays. If your issue is the rear washer, it is a 15 A fuse in the rear cargo fuse compartment.
Mar 02, 2015 | 2008 Hyundai Entourage
How do you replace a fuse for the hyundai entourage phone chargers (2007)?
you reach in to the box, Fuse box, and pull it out with finger tips.
the operators guide shows this, did you lose it,
get one.
Jul 10, 2014 | 2007 Hyundai Entourage Limited Minivan
Where is the fuse box in a 98 explorer sport?
There are 2 boxes
Passenger compartment fuse panel
The fuse panel is located on the left
hand side of the instrument panel
facing the driver's side door. Pull the
panel cover outward to access the
fuses.
Power distribution Maxi Fuse Box box
The power distribution box is
located in the engine compartment
near the battery. The power
distribution box contains
high-current fuses that protect your
vehicle's main electrical systems
from overloads.
Sep 25, 2010 | Ford Explorer Sport Cars & Trucks
Where is the fuse box located on 1999 mercury mountaineer
Hi, far left side of dash. Must open Driver's door to access the panel which simply pops off.
You can also view the Owner Guide online (which includes the fuse box diagram) at www.motorcraftservice.com
Take care
Aug 02, 2010 | 1999 Mercury Mountaineer
Where is the headlamp fuse on a 2007 hyundai entourage?
there should be a left and right headlamp fuse in the underhood fuse box the underside of the lid has the location of each fuse, hope that helps
Dec 10, 2009 | 2007 Hyundai Entourage Limited Minivan
Wher's the fuse box?
The interior fuse box is located under the driver's side of the instrument panel, it can be lowered for easier access by releasing retaining clips
Fuses are located either in the engine compartment or passenger compartment fuse and relay panels.
Oct 11, 2009 | 1998 Ford Contour
Where is the fuse for the ac blower motor in a 2003 Hyundai Santa Fe" The fuse panel under the driver side dash does not list it.I also checked the power panel under the hood next to the driver side strut....
dear friend the fuse that you are looking for is in the engine compartment,if you open the fuse box look to the right hand side,right at the bottom,there is a 40amp fuse marked BLR,that is your blower fuse
Sep 21, 2009 | 2003 Hyundai Santa Fe
Fuse box for 1998 mazda b3000
There are really 2 boxes
facing the driver’s side door. Pull the
fuses
Power distribution box
vehicle’s main electrical systems
from overloads.
Jun 01, 2009 | 1998 Mazda B-Series
Air Conditioning and Heat for Hyundai Entourage Logo
146 people viewed this question
Top Hyundai Vehicle Parts & Accessories Experts
Lawrence Oravetz
Colin Stickland
Colin Stickland
Are you a Hyundai Vehicle Part and Accessory Expert? Answer questions, earn points and help others
