Question about Magic Chef Refrigerators
Magic Chef RB214TF
Is there a filter in my MC RB214TF that will not let the freezer go below 10 degrees
  • 2920 Answers
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Posted on Aug 27, 2008
  • 404 Answers
SOURCE: Freezer won't go below 10 and fridge goes between 40 and 60 degrees
Ensure the condenser is not clogged with dust or other debris.
Ensure the condenser fan (usually found in back) is turning when the fridge is running.
Posted on May 26, 2009
SOURCE: where can I find magic chef wine cooler compressor for MCWC52B
My Name is Mike. I have the same unit. The compressor is not bad. Replace the start relay& overload on compressor.
Posted on Jun 05, 2009
SOURCE: I have magic chef mini refrigrater freezer not
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
  • 454 Answers
SOURCE: chipping away ice in magic chef freezer section i
No, the fridge will not get cold any more. The coolant goes to the coils in the freezer. The fridge takes a small amount of cold air from the freezer to lower its temperature.
I am sorry to say that unless you can find a way to repair the puncture and refill the system with freon, you are going to have to buy another refrigerator.
Posted on Feb 06, 2010
Where is the defrost timer on a Magic Chef Model RB23GA-3A top freezer Refridgerator?
It is located in the mechanical space of the unit. Please review the picture.
Feb 23, 2015 | Magic Chef Refrigerators
Refrigerator and freezer not cooling adequately
the ptc overload on the compressor is defective,replace this and it will again cool properly
Feb 16, 2012 | Magic Chef Refrigerators
I have a small magic chef freezer that opens from the top. I has about 3 or 4 cu. ft. of freezer space. Lately a buzzer has been going off every 15 or 20 minutes. It buzzes for about 5-10 seconds and then...
With the time as the compressor gets old the buzzing will increased, its not a bid deal, just set the thermostat to 1 during the winter, saves you energy and give the compressor more time to rest.
Sep 28, 2011 | Magic Chef Chest Freezer MCCF5WBX
Have a magic chef, top freezer, one size bigger than dorm size. freezer doesn't freeze and continually produces water that freezes all over bottom of freezer. what to do?
There are three chances for not getting freeze. Defrost activate quickly, due to: 1. Thermostat malfunction- Replace it. Thermostat setting. - Must be -5 degree or less than that. 2. Defrost timer for malfunction. If so, replace it. 3. Freezer heater malfunction.- Replace it.3. System chocked or short of gas. Check with run amps.
Solution: If system chocked, release all gas and replace filter drier. Flush out the system, vacuum and recharge gas. If short of gas, leak test and arrest it. Vacuum and do gas charging. Thanks.
Jan 31, 2011 | Magic Chef CTB2121AR Top Freezer...
The bottom part doesn't cool things. only gets 66/67 degrees Fahrenheit.
Usually when this happens it is either a evaporator fan or a defrost problem. Check that the fan in the back of the freezer is running. Or if there is frost on the back of the freezer. Frost indicates a defrosting problem.
Jun 27, 2010 | Magic Chef CTB1821AR Top Freezer...
What shoud I set my magic chef deep freezer at
It should be set between 10 and 20 degrees Fahrenheit
May 27, 2010 | Magic Chef Chest Freezer MCCF5WBX
My MCBR1020W 10 cu ft top mount freezer/refrigerator is not cooling correctly. It is -20 degrees in the top and 60 degrees in the bottom. This is a new item.
It is a cheap piece of junk. I bought one just this week and the defrost timer gets stuck so it's going back...........
May 14, 2010 | Magic Chef Refrigerators
Magic Chef Refrigerator door flys open
Sounds like you have the unit out of level front to back leaning towards the back. Try leveling or just tilted a little with the top leaning just a little toward you. This should keep it from flying all the way around.
Jan 05, 2009 | Magic Chef CTB1922 Top Freezer...
Refrigerators Logo
37 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
