The Fan in my Nutone bathroom light/fan is not working...
I have a Nutone light fixture/fan in my bathroom. The light in it works however, the fan itself does not. Is there a way I can fix it myself or do I have to call someone?
Re: The Fan in my Nutone bathroom light/fan is not...
It is really easy to change the motor yourself. It is about a 15 minute job. You just need to find your model number and then you can buy the complete motor assembly. https://www.centralvacuumstores.com/model_number_help.php
I just installed one of these; the directions were not really helpful, and I'm fairly handy doing these things. Anyway, the 'specs' say this is 2 sones, and mine is pretty quiet. I did have to tighten the acorn nut that is under the light bulb, that holds the light fixture to the rest of the unit pretty tight. My noise was coming from vibration, not the fan 'noise'.
Nutone looks like an ordinary three-switch combo being marketed as a bathroom 'fan switch.' The screws on the device would tell the story.
Look at the Leviton screws: The switch has dark-colored screw on one side >> the hot from breaker always connects to dark screws. Other side of switch has 3 silver-colored screws, but these can be brass colored screws > the wires to fan light and heater connect to each of these screws.
Most likely the Nutone switch is identical to the Leviton I say this because the descriptor on Amazon describes it as a 'fan' switch. It's being marketed as a bathroom fan-light combo switch >>> so it looks like an ordinary three-combo switch
There's probably a thermal switch in the fixture which turns the fan on when the lights are on for a period of time and heat accumulates in the fixture. It sound like the heat from the attic is setting off the thermal switch. When the attic heat drops, the fixture works correctly.
This is a catch 22 situation, because if the upper housing in the attic is insulated from the attic heat, the insulation will prevent heat dissipation from the heat generated by the fixture's light bulbs. So, for safety reasons, the upper housing should not be insulated.
I'll need to work on this to come up with a fix.
