Question about Sharp AL-1217 Copier
Blinking light the light blinking 4 and H continuosly
Blinking drum
Posted on Feb 02, 2012
  • 32 Answers
H4 is a fuser error, check the continuity of the fuser lamp.
Posted on Aug 27, 2007
SOURCE:
TV SHUT OFF, HASPOWER, RED BLINKING LIGHT, WON'T TURN BACK ON, WHATS THE PROBLEM ?
If the red light is blinking, then it either does not have a good power connection or its in a diagnostic mode. The red light should be solid not blinking.
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Feb 15, 2016 | Televison & Video
Green light blink
Make and model?
Nov 21, 2013 | Dishwashers
The timer light is continuosly blinking when i plugging in the tv (mitshubishi wd-5252) and won't reset?
Thats one of the famous capacitor issue most likely. Thats the V26 Chassis DLP and usually that symptom is caused by failed DM and Power Board capacitors. There is a repair kit that will work in alot of cases with that symptom. Its called The V26 Chassis DM / Power repair kit available at the following link with detailed instructions http://tvrepairworld.com/mitsubishi_repair_kits
Apr 03, 2013 | Mitsubishi WD-52525 52" Rear Projection...
My suzuki grand vitara v6 CHECK ENGINE light Blinks continuosly when the switch turned to on position
If a warning light is on, there's a trouble code stored in the computer. There are well over 800-1,000 possible trouble codes in the average late model vehicle, so asking us to guess what's causing your problem without knowing the code is a complete waste of time. Get the code read. Post it here. THEN we can help
Jan 12, 2018 | Suzuki Grand Vitara Cars & Trucks
O/D light blinking
have your trans oil checked it is telling you that something is not right
most cars dont have a trans oil check light so they use the OD OFF light as a warning
check the oil in it i bet you it is low
Dec 27, 2008 | 1998 Ford Explorer
Continuosly blinking green light and tv won't turn on.
Either bad capacitors -vented - on power supply board or bad E2P eprom board on DM board.Probably the capacitors-4-1000Ufd and 2-3300ufd.You should get expert help from reputable tv shop.Not really do it yourself fix either way.
Dec 15, 2008 | Sony KDS-60A2000 60" HDTV
61 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
