Question about Xerox CopyCentre C123 Copier Copier
61-321 error don't start to print
Mg 5220 wont print now.
My printer drypro model 832 is giving me an error 4122 what should i do the hospital is stuck,my email address is anan4937@gmail.com please help.
Jun 29, 2013 | Computers & Internet
Why Canon MX310 won't scan error 114.0. how to fix
I have this copier too but only use it as a copier in my classroom. It's a stand alone. But can't print. There is no software to install on a computer so I don't know how to fix it if there's no software.
Feb 26, 2012 | Canon PIXMA MX310 All-In-One Printer
Duplex Error When Trying to Print PDF
I found that one of the papers i was trying to print was set for double sided printing, well i don't have the duplex part of it. So I kept getting the error. You have to cancel all the print jobs thru the buttons on the printer. Doing it in your computer did not help and turning off the printer did not help me. So after I cancelled all docs from printing and turned off double sided printing it was fixed.
Jan 30, 2012 | Konica Minolta magicolor 2300DL Laser...
E000602-0502
Don't really know, but probably the copier's hard drive is bad or going bad. You may be able to simply reload the firmware, but if that doesn't work, it may require replacement of the hard drive.
Call Canon, they should be able to help.
Oct 19, 2011 | Canon (6981A002AA) for imagerunner 2200,...
My Canon Pixma MP258 printer can't print the red color but other colors are okay.When I print out any words or pictures that needs red color,it becomes green color.I don't know what's wrong...
Solution
1. Press START - Devices and Printers
2. Right-click the Canon MP258 series - select Printing preferences
3. Click Maintenance - Cleaning
4. Select All Colors BK, C, M, Y - Execute
5. Wait until the process is finished (Do not start another operation until the cleaning has finished).
6. Click Print Check Pattern OK
If the results print out like this, there are two possibilities:
1. Red ink in the cartridge runs out. Solution: injecting with red ink
2. If the red ink has been filled, and check pattern is still not out, meaning the color cartridge error.
Solution: replace the cartridges
Oct 15, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I want to print using my lexmark X6170 but I don't want to print color so I didn't put a color cartridge in. It keeps coming up with an error message and won't print at all.
Some printers require you to have the color cartridges in them even when you are printing black and white. You usually can in your print options choose black and white over color.
Sep 03, 2011 | Office Equipment & Supplies
Error code P03. It won't print, it doesn't make any noise when I turn it on, and I don't see any traces of paper.
Error code PO3 is caused by Timing Disk dirty / damaged.
Please use this methods
1. Check the timing disk sensor located to the left of the printer
2. Check and clean the board.
And start to print... thanks
Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
My printer, freshly installed on my computer, keeps giving me the error for "Load Cassette A4" anytime I print something. I have letter-sized paper in the printer. How do I correct this? Also, it...
You don't specify the printer model, don't specify the operating system... How can we help you, if you don't help us understand your problem?...
Vaguely (as I don't have any details from you) you need to check the default print settings. In Windows they are located in the printer folder options and in the printer driver settings, and have to be both changed to be sure.
Also you might have documents formatted for A4 paper.
Some printers in their settings have an option to automatically substitute A4 for Letter and vice versa, might be worth to find this setting and enable it.
Please come back and leave a rating/testimonial if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Aug 08, 2011 | Office Equipment & Supplies
When I try to print I get an error and it won't print. The error message never shows up so I don't know what the error is. I have removed and reinstalled this printer 6 times now. I have rebooted...
Sounds to me like a bad USB cable,
Also when you're re-installing the printer are you using new/different drivers?
I would try a new cable and the latest drivers direct from Lexmark.com
Jun 01, 2011 | Lexmark X4650 InkJet Printer
My Canon MP490 is displaying error 5200. I can't get it to work again -- help.
Here what I found for you. If it fixes your issue, don't forget to give me a good rate. Thanks
Print head temperature rise error or Error Code 5200
Condition: The print head temperature exceeded the specified value.
Problems and Solutions:
  • Turn off the printer and then turn on if error still persist replace Ink cartridge or print head
May 26, 2011 | Office Equipment & Supplies
Xerox CopyCentre C123 Copier Copier Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
