Question about E-Mu 0404 Sound Card
E-MU 0404 input problems
Hooking up to both the l/r analog inputs give no signal at all. It was already too low in the past, now it's dead!! Although I see a signal coming in on strip 1 and 2!!! Could it be a drivers problem?
  • 3 more comments
  • guitarguru Aug 27, 2007
    By saying no signal at all I meant no sound through the speakers.
    Okay, I just did a repair session from the installation disc and now it's perfect again!!!
  • sir zee Feb 14, 2008
    Sometimes during playback of a cubase track thru my EMU 0404 USB, i get a nasty screech that completely distorts the sound either through the main output or thru the headphones. My deadline is tomorrow.
    Help needed real fast, like yesterday!
  • M. Aftab May 06, 2008
    I have same problem with me please help me
  • vasmo Feb 21, 2009
    My Emu 0404 doesn't receive audio signal. Eevn if i have reinstalled it several times and changed the sample rate still doesn't work.
    When I plug in a jack into the inputs, it does give a signal but it still doesn't give a signal when I produce sound either with the mic or any instrument i plug in.
    Can someone help?
    Thanks
Try to reset the inputs on your sound card ,CLICK ON the PATCHMIX ICON, GO TO OPEN SESSION (IT IS THE FOLDER ICON IN THE MIDDLE ON THE TOP OF THE PAGE) AND TRY TO OPEN SNOTHER SESSION, IF THIS WORKS YOU ARE GOOD .YOU MIGHT HAVE TO OPEN A FEW SESSIONS BUT IT WORKED FOR ME
Posted on Dec 20, 2007
SOURCE:
The sound level from analog input is very low, good quality but low, optical connections work well. Have checked cables, tried all the analog input jacks with same result.
test analog input with another receiver ,if it comes out same low , good quality sound level ,then issue/problem is on input source not on receiver. Sometimes the way source audio was recorded causes these issue on high quality receivers...
Dec 28, 2013 | Sony STR-DE845 Receiver
Low sound production from my EMU 0404
Are you sure the problem is with the sound card? May be it is the volume settings. There are several ways to increase the volume.
If you need further help, let us know the model, brand and OS of your computer.
Oct 30, 2011 | E-Mu 0404 Sound Card
When I hook my tv up to cable I get no signal, if I just hook it up with antenna it works fine. How do I get my tv to work with my cable cord? Would be nice to view cable channels instead of just 3...
nialbert,
It sounds like you are hooking the cable to the wrong input (digital instead of analog) or you do not have an analog input. If you do not have an analog input you could run the cable through a VCR to convert the signal to a separate audio/video signal and send it to the TV via an auxillary input. Without the model number I can't give you much more help.
Thanks for using FixYa and for the great rating.
hardrocko
May 09, 2011 | Televison & Video
I have 65 inch pro elite 710hd 6 years old. Do I have to get analog box
hello,
Yes you still have to get digital to analog converter. Although you can feed a hd signal through the component inputs, the tv is still set up to only receive analog signals through the coaxial input
hope this helps
Jan 14, 2011 | Pioneer PRO-710HD 64" Rear Projection...
Im trying to connect my unit to my tv to record shows and i having trouble doing so please help i am hooking it up wrong
For OTA or CATV signals, you need to daisy chain the coax from the source (antenna for OTA) to the coax input on DVD recorder and then the coax out to the coax input of the TV. If you have a set-top cable box with an incoming CATV signal, it should be connected between the DVD recorder and the TV.
The unit can tune in and record 480i (SD) ATSC (OTA digital), NTSC (OTA analog), analog CATV and digital CATV channels.
A satellite receiver or a non-CATV cable box should get the incoming signal first and then have their composite video output (A/V) connected to the DVD recorder composite video input and then their coax (RF) output (if present) gets connected to the TV. For these, you would record from the IN1 or IN2 (press Select Input) instead of selecting a channel. Then connect the composite video out on the recorder to the TV's composite video in.
Digital signals are either enough to tune in or give no signal. So check that your antenna is correctly oriented for OTA.
Separately, you can connect the video signal when playing DVDs via composite (good signal) out and component out (better signal) out to the TV's matching input. For the component video, the sound is carried on a separate cable. Then set the TV to the input source.
In the case of wanting to watch a VHS tape while taping to a DVD, do not use the Component video source, set the TV to Input 1 (composite).
I hope this helps.
(you can get a copy of the manual here: http://tv.manualsonline.com/manuals/mfg/panasonic/dmrez47v_dmrez475v.html )
Nov 25, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
E-MU 0404 Soundcard no longer functions
Reinstall the software driver for your soundcard to make it work. If you have the disc, just insert it and reinstall,
otherwise, you have to download it from the internet.
Nov 12, 2009 | E-Mu 0404 Sound Card
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
Problem with analog recording on Yamaha CDR D651
Your assessment that it duplicates CD's internally fits with an analog-only failure mode. Let's make sure the signal is getting past your RCA jacks on the deck...
Put the deck in a Rec/Standby mode and make sure an analog source registers adequate volume on the meters. If it's good there and doesn't change with cable swapping between the input channels, you're right, the problem is internal. Maybe the volume potentiometer itself has developed a dead spot. Manually rotate it throughout its range many times to wipe it clean.
If you have an external optical digital source use it to check the meters in digital recording mode to be sure they're about even. The same knob affects analog and digital levels.
If you have the deck connected via the traditional Tape Monitor circuit in a receiver you should be able to tell by ear if the one channel is dead or too low. This puts all of the recording circuitry including the volume knob in line with your receiver.
May 16, 2009 | Yamaha CDR-D651 2-Disc CD Recorder
Can't get analog stations
Good Day, Jamievass;
Please disconnect the NEW DVD Player, does analog stations come back? What input are you using; RF, Comp, hdmi? If ok try using another input or you may need a main bord that processes the signal.
Good Luck, big IRISH.
Aug 10, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
E-Mu 0404 USB Sound Card power ?
Do you have the speaker lead plugged into correct plug on back of computer the color is usually a green one
Jul 17, 2008 | E-Mu 0404 Sound Card
E-Mu 0404 Sound Card Logo
759 people viewed this question
Top E-Mu Computers & Internet Experts
Marvin
Marvin
Alun Cox
Ben Armstrong
Are you an E-Mu Computer and Internet Expert? Answer questions, earn points and help others
