Question about Savin Office Equipment & Supplies
Unplugged our Savin C3030 PCL5C, plugged it back in and now it says "Please Wait." Why is it taking so long?
drichards
  • 87 Answers
SOURCE: Savin C3030
SC 553 is a fuser overheat error. If you have a fuser great, but you will still have to reset the code. Clear modes, 1, 0 ,7, press and hold clear/stop key. Menu will change, select copy sp. From there, select 5, (mode), scroll till you get to 5810. Select it, and press execute, then exit back to copy sp. Select 7 (data log) then scroll until you get to 7807. Select it, and press execute. Exit all of the way out, and recycle the power.
If it comes to ready, great. Try it. If it codes out again, you have a problem, possibly thermisters, (in the fuser), power supply getting stuck on, I/O board not regulating the power supply. Could be any of these things.
But start by resetting the code. Could be a a thermister got some toner stuck under it, and the other thermister detected a difference. It really could be that easy.
Posted on Mar 12, 2008
  • 143 Answers
SOURCE: Can you number pages with a Savin C3030 without
Yes, you can load the documents in the tray, tell it to number them and copy a blank white original.
Posted on Sep 20, 2009
  • 22 Answers
SOURCE: how to replace savin c3030
The used toner collection bottle is located behind the cover, just left of tray 1. To empty/replace this bottle, follow these steps.
  1. Turn machine off with red rocker switch, this is located on the left side of the machine.
  2. Open front cover.
  3. remove screw on the bottom-left side that holds the toner collection cover closed.
  4. close the front cover
  5. pull out tray 1
  6. open toner collection bottle cover(swings to the left)
  7. pull out toner collection bottle
At this point you can empty it or replace it, and reassemble in the reverse order of removal.
Posted on Dec 06, 2009
spinal
  • 287 Answers
SOURCE: touch pad control panel on Savin c3030 doesn't
Hello.I can ASSURE you absolutely what the problem is.Your Savin copier(which is a perfectly fine device) is actaully manufactured by Ricoh.I work for a Savin dealership and Ricoh contacted all dealers WORLDWIDE with the news that due to a manufacturing defect that the touch screens of al models such as yours WILL fail.They sent out free of charge replacement touchscreens to all dealers as they have a record of how many of what type was sold by whom.I mean we had a crate of touchscreens show up at our dock at about the same time we started to get a barrage of service calls for this problem. It was one of the wildest things I've seen.Now it is just the "glass" of the touchscreen that is defective as it actually an "active" part of the op panel's circuitry of the op panel.It is relatively easy to replace.Now the question is, how do YOU aquire one,as it is a known defect and is covered by warrranty.I have to assume you purchased this device on your own and that you do not have a service agreement thru an independent dealer.My advice would be to contact whomever you bought the device from or perhaps Ricoh directly and tell them the problem and that you are aware that Ricoh is aware of the problem and see what they say.I cant tell you how many of these things I have had to replace as it is not a matter of IF there will be a problem with the Savin c3030 touchsreen, but merely when.Good luck, and although I did not "FIXYA" I hope you will acknowledge to the sight that I gave you the facts that you need. :-) Take care
Posted on Jul 11, 2010
  • 7 Answers
SOURCE: Savin C3030 copier. refilled staples, but copier thinks empty. How can I get the copier to sense the staple refill?
There is a sensor that tells the machine if there are staples present. Check to see if it has been moved out of position or if the wire going in has been broke or crimped
Posted on Mar 29, 2012
SC672
do not know the language post in english
Jun 26, 2014 | Savin Toner C3030, C2525
Im getting magenta backround on all color copies. I replaced the drum and developer, this did not change the problem
I had the same issue. I removed all the drums and DV units, removed the transfer belt and open the manual infrrd door and pulled to fuser. I found huge piles of magenta tone all over the place. Cleaned it up, put it back together and runs like a champ
Feb 08, 2013 | Savin Transfer Belt for C4540, C3535,...
Mar 29, 2012 | Savin 8035e Copier
Touch pad control panel on Savin c3030 doesn't work - the rest of the control panel buttons do just not the touch pad for any function?
Jun 22, 2010 | Savin Office Equipment & Supplies
Can you number pages with a Savin C3030 without actually copying the documents
Hello sir; Yes, there have SP mode it does the job,the procedure as follow; press "clear mode" + "107" thenpress and hold down for 3 seconds, then touch screen on copier SP, enter number 5212-003, 004 to open the program. press "exit" twice to end the service mode.
Sep 18, 2009 | Office Equipment & Supplies
Savin error code E-547 error code?
Fusing unit trouble.Clean the thermofuse and thermistors,check the heater lamp.After ,enter in the service mode turn the power switch OFF unplugged the crd.Wait 10 sec. plugg the cords and turn ON the machine.I think the Savin is based the Ricoh copiers machine.The service enter code is : Press the toral clear key - 1 - 0 - 7 -hold down the C key more 3 sec.
Aug 17, 2009 | Savin Office Equipment & Supplies
New internet service now Savin C3030 won't work
Reinstall the printer on your operating system. For example, Windows XP is probably still trying to print to the old IP address. You will need to find out the new IP address of the printer and tell your operating system to print to that new ip address.
Mar 06, 2009 | Computers & Internet
Savin C3030
Mar 12, 2008 | Ricoh Aficio AP3800C Laser Printer
Top Savin Office Equipment & Supplies Experts
CheckitRight
CheckitRight
George Mclaughlin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
