Question about Dishwashers
Ge model #GSD5211J01SB
Where do I locate the drain plug
Location of discharge hose on model GTWN5050MOWS
See step 3 of manual. Sears parts provides great customer service with parts and manuals
Hope this helps?
http://www.searspartsdirect.com/partsdirect/user-manuals/GTWN5050M0WS-GE-WASHER-manual
Jun 26, 2017 | GE Washing Machines
Where is the draining hole in a ge profile model tbx25pa refrigerator with top freezer
Underneath the cooling coil (evaporator) located in the freezer, there is a drain pan with a heater to warm it during the defrost cycle. The drain opening is probably blocked by ice or debris.
Sep 26, 2014 | GE Refrigerators
Ge profile arctica model #ps123sgna bs, leaking water from fresh food side?
Plugged or frozen drain pan located under the evaporator (cooling coil), located in the freezer.
Aug 31, 2014 | GE Profile PSW26P Stainless Steel Side by...
I have a old ge refrigerator tbx22zIbbrww is there a drain plug an where located water draining inside
Usually at the bottom of the freezer. You may need a drain line heater.
Oct 24, 2010 | GE Refrigerators
I have a GE Washer (model # WWA5669MAL). The pump
That is supposed to be weep hole. If water is pouring out then that is a sure sign of a worn out old school GE pump. The good news it that is an easy pump to replace. the hardest part is replacing the drive boot from pump to motor. Nothing to it 0895584.gif
Apr 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Gasket were replaced but still leaks water
If leaking out front of door on freezer, then you have a drain plug that is stopped up or frozen. Drain plug is located in freezer, underneath evap coil, when unit goes into defrost mode, if drain is plugged up, water has no where to go except out thru doors.
Sep 30, 2009 | GE Refrigerators
GE dishwasher will not drain. Does not appear to be clogged.
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Aug 27, 2009 | GE Dishwashers
GE Model gsd5330d00ww will not drain. There are no drain obstructions and I have replaced the piston gasket in the rear of the tub. What is my next step in figuring out the problem?
HI. check the following areas for fualts.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer/control
Jul 30, 2009 | Dishwashers
Dishwashers Logo
164 people viewed this question
Top Dishwashers Experts
