Question about Pool & Spa
Jandy lite lj400n
My pool heater started fine at the beginning of the season, then an error code FL 4 appeared on the LCD. Upon closer inspection it seemed about 50% of the metal of the ignitor was burned. I replaced the ignitor, and still the same error code. So I decided to replace the high voltage control board that the ignitor plugs into. STILL I get the FL 4 error code. Everything else appears to be operating fine, except that the ignitor does not glow. I get no voltage out of the ignitor terminals. Any help is diagnosing this is appreciated.
5 Suggested Answers
  • 21 Answers
SOURCE: FL 4 error, Jandy Lite 2 pool heater
I believe you may have a draft restriction and this may stop the start up diagnostics. The draft detection switch is sometimes restricted or weak. Common problem. Tap the gas valve to see if the winter has caused the valve to seat heavily and stick.
Posted on Apr 25, 2010
  • 6 Answers
SOURCE: jandy lite2 heater has fl5 error code, all voltages look good
If all voltage test points are within range, then it's 1 of 3 problems: Power Conversion Plug is faulty; Power Control Board is faulty; or Controller is faulty. Jandy says there is no way to test any of these directly. They recommend that you replace both the Power Conversion Plug (~$35) and the Power Control Board (~$230). Apparently when one fails, it can cause the other to fail as well. They said that unless the Controller has a lot of corrosion on it, then it probably is not the issue.
Posted on May 20, 2010
  • 19 Answers
SOURCE: jandy pool heater wont stay on the blower kicks on
most likely problem is incorrect gas pressure or a clog in the gas line. If this is a propane heater (you did not specify) then the owners manual is wrong on the gas pressure, you should call the manufacture to get the correct settings for propane.
Either way you need an experienced gas person to come set the gas properly.
Also I had serious problems until I had the gas company install a regulator right next to the heater (so the entire under ground gas line was high pressure). I use to have a regulator next to my house so low pressure fed all the way from my house to the heater (200ft) and this caused serious problems like this.
I also had a regulator break on me one year. It basically stopped putting out the right pressure.
Lastly the flame sensor could simply be bad. If you are still having this problem I can explain how to remove and test the flame sensor. It is easy to test and easy to replace.
Posted on Sep 20, 2010
SOURCE: Solution for Jandy Lite 2 Pool Heater display flashes on & Off ..
Can a model LJ250P Propane 2005 model be installed indoors . The rating plate says it can. But manual says it cannot. What the hell????
Posted on Jun 14, 2011
How to retrofit a ingeniter kit
you can still get mini 4" ignitors if not get pentair mini max
Jun 04, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy lit 2 heater error fl 6
gas signal being sent to gas valve not by controller either stuck gas valve or bad control board
Apr 14, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
FL 4 code Hot surface igniter problem on Jandy Lite 2 - FixYa
check the fuses from the red wires if blown replace if ok replace ignitor
Aug 27, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
JANDY LITE2 LJ HAS A FL-2 CODE WHEN HEATER STARTS
check gas flow, check for cobwebs in gas orfices also check if 24 volts ac to the brown gas lead if not check safety circuit if so bad gas valve
May 31, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
I am getting an FL 2 error code on my jandy lite2. I changed the flame sensor and still get same error message
Look at the list of codes inside the cover of the heater. Your owners manual should have a complete remede for all codes.
May 27, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
fl 4 bad ignitor or bad fuses if fuses ok replace ignitor
Apr 01, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Jul 29, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy heater not starting
FL 4 is igniter failure.
1. check the fuses on igniter wire as well as the wires.
2. replace igniter
Jun 13, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
