Tpi 21f20tc23 electric heater wiring diagram - Heating & Cooling
2 Suggested Answers
  • 70 Answers
SOURCE: electric hot water heater
If you can find me a serial and model number i might be able to help you better.
Posted on Apr 24, 2008
How to check sensor tps Hyundai 2001
How To Check TPS‎
www.fixya.com/how+to+check+TPS
Technically Challenged?
Our Experts Fix Anything for Free
TPI Heater at Amazon.com‎
www.amazon.com/‎rating for amazon.com
Buy TPI heater at Amazon!
Free Shipping on Qualified Orders.
Nov 23, 2015 | Tpi Industrial Heating & Cooling
85 tpi corvette wiring diagram
Are you trying to use your harness and ecu from the existing v6? Please say no cuz the ecu for a v6 will not work well for the v8. I would suggest getting the ecu harness from the vette you got the motor from. GL.
Dec 06, 2013 | Cars & Trucks
I need the diagram
You want wiring diagram? With recommended wire size?
This particular water heater has a factory-pigtail, and is direct-wired into octogon box, and appears to be 240Volt 6500 watts. Connect water heater to 40 amp breaker and 8 gauge wire.
Here is illustration:
http://waterheatertimer.org/images/Main-subpanel-Tankless-4a-8.jpg
Look at nameplate on device for amp and wattage rating to confirm exact power requirement.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Oct 14, 2012 | American Heat ADK-3 - Electric 6.4KW...
I cannot get my TPI Corp baseboard heater to turn off. It kicks on even when it is not that cool in the room.
If the unit kicks on at too high a temperature, then it is probably the thermostat. If it will not turn off then it is probably the switch that is bad. Since you gave both indications, you could have two components bad. NOTE: Normally calling a technician to repair this item is more expensive than replacing it with a new one yourself.
Jun 18, 2011 | Electric TPI CORP TBS BASEBOARD HEATER...
I need a wireing diagram for two elament electric water heater. Mine runs on 220 volt, my question is what about the common or white wire where do i hook it to or do I not need it when running a 220 circut
Links below show specific wiring diagrams and explain 240V with two hot wires vrs 120V with hot and neutral wires.
Then if you have more questions, add a comment and I will fill in blanks:
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
First diagram will be for your water heater.
http://waterheatertimer.org/B220C.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 17, 2011 | Reliance & 40 Gal Electric Mobile Home...
Disconnect baseboard heater
After confirming that the heater circuit is de-energized, simply go to whatever heater that you want to disconnect, open the junction box, remove the heater wires and cap them off. Twist the remaining circuit wires together, wire nut, replace the juction box cover and on to the next one. There are ways to install a thermostat at each heater too.
Jan 17, 2009 | Electric TPI CORP TBS BASEBOARD HEATER...
Loose power when turing it on
sounds like it is wired incorrectly at the baseboard heater. BUT if it worked correctly before this, then you may have a bad thermastat. Wiring in two baseboards into one thermastat is a bit tricky, each time I do it I have to think it thru before hand to get it right. IF it has never worked right, again you probably have it wired in wrong at the baseboard.
Dec 14, 2008 | Electric TPI CORP TBS BASEBOARD HEATER...
Heating & Cooling Logo
113 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
