Question about Brother MFC 210C All-In-One InkJet Printer
Not printing I've only just recently had my computer repaired but now it wont print and they told me to run the software agin to load it onto my computer but i dont have the disc for some reason and was wondering if there is somewhere i can download this Thank you Eryn Lilley
  • 832 Answers
See brother.com to download the hole driverspackage (156mb).
Posted on Sep 07, 2007
  • 78 Answers
Here is the link: http://tinyurl.com/36lon9 Then click DRIVERS in Step 1 Then Select your operating system in Step 2 Then select your language in Step 3
Posted on Aug 27, 2007
SOURCE:
I am trying to hook a Brother HL-2140 laser printer to a dell computer. I am unable to print since I've recently hook up the new computer. I hooked everything up like how it was on the old...
Re boot the computer with ,( wired or wireless printer?), the printer cable in the USB port in the laptop/desktop, the windows version you have will ID the device and try to load a driver, or Go to printer in the start menu and ADD a PRINTER the software will search for the attached printer. OR use the software that came with the printer, load into the Dell and follow the instructions.
Nov 10, 2012 | Brother HL 2140 Laser Printer
FUJI XEROX CM205fw can't set custom paper size
So I am not the only one encountering the same problem! Printing A4 & DL are great but it simply does not let me print A6 properly no matter how hard I tried to configure the paper size (at the printer settings, printer preferences, the application settings etc)
Can Fuji Xerox fix this?
Apr 26, 2012 | Office Equipment & Supplies
PRINTER HAS INK BUT WONT PRINT
Use the "HP Printing Assistant" software, installed on your computer, to run a few "print-head-cleaning" cycles, to unclog any ink-jets that are _not_ shooting the ink onto the paper.
Jun 06, 2011 | HP Deskjet F340 All-In-One Printer
We installed our new computer and printer..however the printer is not printing out anything. Its working..but no print on the paper. We took the tape off the cartridges. Help!!
Use the HP Printing Assistant software to run a few "print-head-cleaning-cycles",
to s(t)uck ink from the ink-cartridges into the ink-jets, and to unclog any of the ink-jets
that should be shooting the ink onto the paper.
Or, since it is a NEW printer, exercise the WARRANTY to get it repaired/replaced, at no cost to you.
Jan 10, 2011 | HP Photosmart Premium C309g multifunction...
I installed my printer software and it when I try to print it prints jibberish at the top of the page then multiple blank pages agin and again.
Make sure that the drivers are not outdated, corrupt, or incompatible, resulting in disrupting the communication between the printer and the computer.
Always make sure that you are making use of the most recent and latest device drivers, and also that are compatible with your system requirements and specifications, as this can be extremely useful in resolving printer issues.
Oct 22, 2010 | HP PhotoSmart C4280 Laser Printer
Put in new ink cartrages but printer still won't print.
Same problem- & I fixed it!
My printer had all new cartridges and acted like it was printing, but only blank pages came out. Since I had followed all recommended trouble shooting steps, the Epson help center told me I had to take it to a repair center, and most likely replace it, saying that it was probably the actual printing head that was clogged and since it was a non-removable part, couldn't be replaced. Instead, I did this- try it!
-Remove all ink cartridges.
-Dip a cotton ball or q-tip in rubbing alcohol, and drop a couple drops on each ink head (the points sticking up that the ink cartridges stick onto.)
-Dab it dry with another q-tip, then repeat.
-Reinstall cartridges, and voila, it might work!
Mine worked PERFECTLY after this 5 minute procedure, no skips, no blots, nothing. And no repair center, and no new printer! Good luck!
Sep 02, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Can I download the easy print software for my Canon 1610 printer"
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
Canon UK - Easy Printing
Download Library - Canon USA
After downloading is finished, unplug the printer USB and run the software that you downloaded.
The software installer will tell you when to connect USB.
Mar 16, 2009 | Canon Axis 1610 Print Server
Problem installing lexmark 2650 on toshiba a 30 satellite
did you add a printer onto the computer control panel
did you down load the printer driver from the manufacturers web page downloads
Jun 03, 2017 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
HP Photosmart C3180
Do you know if that control panel in you computer for that printer needs to be told that you are printing pictures?
Some models you do by selecting photo paper.
Jul 05, 2008 | HP Photosmart C3180 All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
44 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
